    Problem with installation on Nokia IP120
    1 Posts 1 Posters 1.4k Views
      koukobin
      Hello,
      I have a Nokia IP120 . I removed the HDD and placed a CF reader and a CF card 1GB.
      The Pfsense booted fine. I assigned the interfaces and then i halted the system and i removed the CF card and attached it on PC and run the Freesbie Live CD.
      I managed to mount the device (it was the ad4s3 if i remember correct. I also was able to mount some other partitions but they didnt have the correct config.xml though.) and made the necessary modifications (i.e. <spoofmac>01:02:03:04:05:AB</spoofmac> for the fxp0 - LAN and <spoofmac>01:02:03:04:05:BA</spoofmac> for the fxp1 - WAN).
      I followed the instructions from these links: http://socalfreenet.org/nokiaip110 and http://wiki.m0n0.ch/wikka.php?wakka=NokiaBoxesSpoofMac
      After that, placed the cf card again back to IP120 and from shell (through hyperterminal) i typed ifconfig -a i noticed that the fake MAC address were assigned correctly. But still no luck. I am not able to connect to device through webgui neither ping the ip address of the LAN.
      I tried to TCPDUMP the ping requests from my pc and had the following message:
      IP truncated-ip - 2 bytes missing! 192.168.1.100 > pfSense.local
      Has anyone seen that ?
      Any idea is welcome.
