    Snort with NanoBsd Problem - Problem Solved!
    4 Posts 3 Posters 3.2k Views
      dejavudf
      **My System -> pfsense Nanobsd version 1.2.3 Release + 1Gb CF Card + 256Mb Ram + Pentium III 750
      Snort info- > squid  2.7.9_4 platform: 1.2.1
      I try to install squid package and get the error screen below:**
      _Downloading package configuration file… done.
      Saving updated package information... done.
      Downloading squid and its dependencies... done.
      Checking for successful package installation... failed!
      Installation aborted._
      I don't know what to do anymore. I've tried everything. Please, help me out!
      Squid Installation log located in "/var/tmp":
      _Beginning package installation.
      squid-2.7.9 Array
         [0] => tar: +CONTENTS: Not found in archive
         [1] => tar: Error exit delayed from previous errors.
         [2] => pkg_add: tar extract of /var/tmp/apkg_squid-2.7.9.tbz failed!
         [3] => pkg_add: unable to extract table of contents file from '/var/tmp/apkg_squid-2.7.9.tbz' - not a package?
         [4] => pkg_add: 1 package addition(s) failed
      Package WAS NOT installed properly._
      P4 1.5Ghz, DDR 256Mb RAM, 4 NICs (WAN, LAN, DMZ, WIRELESS) and 1Gb CF Card.
      PFSense 1.2.3 Release.
        TheInstaller
        I have same problem and  I get same error:
        This also happens when I try to install imspector. I tried installing Cron and FileManager and they've installed without problems.
        Any ideas whats going on?
        P.S.
        I have pfsense 1.2.3
        • jimpJ Offline
          Can you try this again?
          The package server was on the fritz so it was switched to a different mirror and we had to rebuild a significant amount of the package binaries.
          Do not Chat/PM for help!
            dejavudf
            Problem solved! Thanx! My home network can't not live without pfsense anymore!
