    Q:Installation of small ide flash and extend with hdd for logging & packages
    3 Posts 2 Posters 1.7k Views
      MaxHeadroom
      Hi
      is it possible to install the pfsense to the ide flash, store also the config there but all other write access should go to the hdd
      especialy all logs so i am able to use packages (squid …) ...for a long living ide flash ???
      thanks for your help
        scoop
        Install the "embedded" version through the full installation, or write an embedded (NanoBSD) image to your flash drive. This will automatically minimise writes to your flash drive.
          MaxHeadroom
          hi
          don't want to minimize the write access, i want redirect it to the hdd
          thx
