    Possible Wrap LED Solution
    11 Posts 5 Posters 12.5k Views
    • E Offline
      ealvar
      Well, I've been fiddling around with my WRAP and PFSense and I noticed that only the first LED does anything.
      After looking around a bit I found an easy way to control the LED functions.
      echo 1 > /dev/led/led2    <- Turns LED 2 on
      echo 0 > /dev/led/led2    <- Turns LED 2 off
      echo f_x_> /dev/led/led2    <- Flashes LED 2 at intervals where x=1-9.  1 is fastest 9 is slowest.
      The question I have is how to use this functionality.
      I've been mucking around trying to figure out where I can use this information to turn on the 2nd LED when a PPPOE connection is established.
      Is this useful info at all?
      E
        hoba
        Indeed it is! Thanks for that hint  ;D
        • E Offline
          ealvar
          Ok…
          So, is it possible to turn on LED 2 when PPPOE is established?
          I'm an intermediate linux guy, not a BSD guy... where's the PPPOE script?
          E
            sullrich
            Look in /usr/local/sbin/ppp-linkup IIRC
            • E Offline
              ealvar
              Cool!
              Now I need to figure out how to remount the filesystem RW.
              Thanks,
              E
                sullrich
                Run /etc/rc.conf_mount_rw
                  MdeWendt
                  Hello E,
                  very good work. Do you find a way to read out the switch of the WRAP board?
                  Martin
                    jonr800
                    Well I coded up a few PHP scripts to take advantage of the LED's. They're very rough.  I'm sure for some of the things I could pull from the config.xml, but that just seemed like a lot of work / extra overhead.
                    The following will ping your gateway and something else of your choice.  If both return a ping LED 2 gets lit.  If the GW returns a ping but the other IP does not (internet down), then it flashes LED2.  Otherwise LED 2 get turned off.
                    #!/usr/local/bin/php -q
                      $gateway = "xxx.xxx.xxx.xxx";
                      $external = "yahoo.com";
                      $gwping=exec("/sbin/ping -c 1 -i 1 $gateway");
                      $extping=exec("/sbin/ping -c 1 -i 1 $external");
                      if(strlen($gwping)>1 && strlen($extping)>1)
                        exec("/bin/echo 1 > /dev/led/led2");
                      else
                        if(strlen($gwping)>1 && strlen($extping)<=1)
                          exec("/bin/echo f5 > /dev/led/led2");
                        else
                          exec("/bin/echo 0 > /dev/led/led2");
                    The next one tests for how many pptp users are connected.  If there are users connected then it turns LED3 on.  I was debating having it flash faster for more users, but meh.
                      exec("/sbin/ifconfig -a", $a);
                      $pptpusers = 0;
                      foreach($a as $val)
                        if(preg_match("/^ng.*UP/", $val))
                          $pptpusers++;
                      if($pptpusers > 0)
                        exec("echo 1 > /dev/led/led3");
                      else
                        exec("echo 0 > /dev/led/led3");
                    I set cron to run these every few minutes.
                      hoba
                      Nice, there are a lot of things to think about to be used with the LEDs. As the soekris only has 1 LED (which is labeled Error I think) we might want to have one LED indicating non acknowledged alerts in 1.1. However, the wrap has more LEDs and assigning different functions to these might be handy too (like dropdowns in the gui what which LED is indicating).
                      Feel free to make further suggestions and codesnippets here:
                      http://forum.pfsense.org/index.php?topic=398.0
                        sullrich
                        This is pretty neat, but can you extend this a little more and make it work with config.xml ?  If so, I'll commit.
                          jonr800
                          I know I can get it to pull the gateway from config.xml for the inernet connection test.  Should I add an entry in config.xml for the external site or just leave it yahoo?  I guess a DNS server would also work.
                          I only have my WRAP for a few days this week before it's shipped off to a client.  Having a lot of fun with it though. :)
