    Transmeta crusoe longrun power manage module for FB8.1
    3 Posts 2 Posters 2.4k Views
      chunlinyao
      I run pfsense on a HP T5700 thin client box.Which has a Transmeta TM5800 CPU.
      I want to use the longrun feature of crusoe cpu instead of powerd.FreeBSD 8.1 support longrun by compile with options CPU_ENABLE_LONGRUN, but that require recompile the kernel.I can rebuild a custom pfsense.But I think maybe a kld module is better.I found Tamotsu HATTORI's work  http://home.att.ne.jp/delta/athlete/longrun/longrun_e.html.But It is slightly out of date.So I convert the longrun.c in FreeBSD src to a module.
      The binary package for FB81 at http://bitbucket.org/chunlinyao/longrun/downloads/longrun-FB81.2011.1.1.tbz
      Here is source code. https://bitbucket.org/chunlinyao/longrun/overview
        Kampfwurst
        Hello
        I have also a bought  a ThinClient with the Transmeta Crusoe TM5800-CPU. Maybe you can explain how to install the power manage module??
        best regards Christoph
          Kampfwurst
          maybe someone can help me to install the longrun plugin.
