    Need Help (3 WANs Load Balance and failover)
    7 Posts 3 Posters 2.9k Views
      nassman
      I will setup 3 WANs and 1 LAN on my pfsense server,so i need the Gateways and Groups settings.
      I need the following:
      1- Add 3 Gateways in routing.
      2- Load balance between 3 WANs.
         set===>Wan 1 + 2 +3 on tier 1 tier 1 tier 1 , is correct or not?.
      3- if Wan 1 fail, preferred load balance between Wan 2 and Wan 3.
         set===>Wan 1 + 2 +3 on tier 1 tier 2 tier 2 , is correct or not?.
      4- if Wan 2 fail, preferred load balance between Wan 1 and Wan 3.
         set===>Wan 1 + 2 +3 on tier 2 tier 1 tier 2 , is correct or not?.
      5- if Wan 3 fail, preferred load balance between Wan 1 and Wan 2.
         set===>Wan 1 + 2 +3 on tier 2 tier 2 tier 1 , is correct or not?.
      about points 6,7, and 8, i not sure about settings,
      6- if wan 1 and wan 2 fail, preferred wan 3
         set===>Wan 1 + 2 +3 on tier 1 tier 1 tier 2 , is correct or not?
      7- if wan 2 and wan 3 fail, preferred wan 1
        set===>Wan 1 + 2 +3 on tier 2 tier 1 tier 1 , is correct or not?
      8- if wan 3 and wan 1 fail, preferred wan 2
        set===>Wan 1 + 2 +3 on tier 1 tier 2 tier 1 , is correct or not?
      about points 9, i not sure about it, is need or not,
      9- set===>Wan 1 + 2 +3 on tier 1 tier 2 tier 3 , is correct or not?
      i wait; thanks
        brcisna
        Follow this link, and you can make happen what you are wanting to accomplish:
        http://doc.pfsense.org/index.php/Multi-WAN_Version_1.2.x
        Good Luck
        BC
          nassman
          thanks man, but i using 2.0 beta-5, i using it with two WANs, and now i want to add third WAN,
          the link you sent about 1.2.x
          thanks
          • jimpJ Offline
            @nassman:
            Yes. If you just want load balancing, that's really all you need. You don't need additional groups or anything else.
            @nassman:
            Yes. That will only use WAN1, but if it fails, it will fail to balancing 2+3.
            @nassman:
            Yes.
            @nassman:
            Yes.
            @nassman:
            That would balance 1 and 2 and if they both fail, go to 3.
            @nassman:
            Yes, see 6.
            @nassman:
            Yes, see 6.
            @nassman:
            That would prefer only wan1, if it fails, use 2. If 1 and 2 are both down, use 3.
            You can make it that complex if you want, but if you really just want load balancing, you just need one group with 1, 2, 3 all in tier 1.
            The rest only needs to be as complex as you want to make it.
            Do not Chat/PM for help!
              nassman
              thank you jimp,
              if i use one group with 1, 2, 3 all in tier 1, if any WAN fail, will others WANs work with out i add any other groups.
              thanks
              • jimpJ Offline
                That's correct. If one fails it will just balance the other two. If two fail it will use whichever one is left over.
                  nassman
                  thank you very much.
