    Problems with traffic shaper
    5 Posts 2 Posters 2.4k Views
    • _ Offline
      _igor_
      With the last update i get
      [filter_load]There were error(s) loading the rules: pfctl: should have one default queue on pppoe0pfctl: errors in altq config The line in question reads [ should have one default queue on pppoe0pfctl]:
      No internet connection to outside.
      Disabling the shaper resolves the problem. What can i do here?
      The shaper worked perfect over the last week, so i'm a bit confused.
      • E Offline
        eri--
        Possibly you have removed the default queue option from the queues nothing else.
        • _ Offline
          _igor_
          Uh, no.
          I had default queue at qOthersDefault and qP2P. That was the error. So is this a feature or possibly a bug? If more than 1 default queue is ticked, there should be a warning. Or maybe better, if a queue is made default queue, all other default queue entries should be resetted to be non default.
          thanks much for that hint, ermal!
          • E Offline
            eri--
            Well it shouldn't be possible to select default multiple times afaik.
            Can you please open a bug in redmine.pfsense.org for this and assign to me.
            • _ Offline
              _igor_
              Done. Its the following bug report:
              http://redmine.pfsense.org/issues/1193
