    2.0 Problem with 1:1 / NAT Reflection / need help or suggestions please
    3 Posts 2 Posters 3.8k Views
      caldwell
      Current setup is WAN (.157) and LAN interface.
      WAN has a Virtual IP of .158.
      Have set 1:1 NAT to point .158 to an internal 192.168.5.5 address.
      Have rules on the WAN interface allowing access to port 443 for .158 -> internal IP.
      Have NO/zero NAT Port Forwards set up.
      Outside users can connect to .158 and get the internal web server.
      Internal users try to hit the external IP, the pfsense -apparently- is redirecting the request correctly.  The firewall log shows a connection from user1 to 192.168.5.5 with TCP:S.  If we review the web server log, it shows a connection from the IP address of the FIREWALL, not the user1 IP address.
      Then the connection never goes any further.
      I have UNCHECKED
      ->Advanced
        -> NAT
            -> Disable NAT Reflection for port forwards
      I have UNCHECKED
      ->Advanced
        -> NAT
      ->Advanced
        -> NAT
            -> Disable NAT Reflection for 1:1 NAT
      I have CHECKED
      ->Advanced
        -> NAT
            -> Automatically create outbound NAT rules which assist inbound NAT rules that direct traffic back out to the same subnet it originated from.
      I have tried deleting the 1:1 NAT to see if it would "create" the outbound NAT rules automatically.  No dice.  I've tried rebooting different times in between steps.  No dice.
      I don't know what to check or how to proceed further with this.
      What am I missing, what can I change, or how can I further debug this?
      Thanks!
        caldwell
        (ping)
        Anybody?
          Supermule Banned
          Download snapshot from 18 jan 02:47.
          It was the first beta that worked for me regarding NAT reflection….
