    Need help with dual WAN/ dual LAN failover setup.
    3 Posts 2 Posters 2.9k Views
      Gunther
      My primary connection is over a cable modem which is nice and fast but has been having enough problems lately that I've also installed a DSL feed so I have something to use while the cable company tries to find the source of an intermittant problem.
      What i want to accomplish is to run over the cable modem for everything and then failover to the DSL feed when the cable feed starts acting up.
      It would also be a nice feature if I was able to selectively have individual machines on my lan use the DSL feed as thier primary route to the internet.
      I'm a little lost as how to set this up though.
      I have two lans, the wired one and a wireless…
      LAN interface (em1)
      Status 	up
      MAC address 	00:0e:0c:cf:e0:e8
      IP address 	192.168.8.1
      Subnet mask 	255.255.255.0
      Media 	1000baseTX <full-duplex>In/out packets 	49056/49003 (5.87 MB/10.55 MB)
      In/out errors 	0/0
      Collisions 	0
      WiFi interface (ral0)
      Status 	associated
      MAC address 	00:1f:1f:a8:5c:61
      IP address 	192.168.16.1
      Media 	autoselect mode 11g <hostap>Channel 	4
      SSID 	stomped
      In/out packets 	8802/8283 (1.72 MB/1.43 MB)
      In/out errors 	0/113
      Collisions 	0</hostap></full-duplex>
      The two WAN feeds are as follows…
      WAN interface (em0)
      Status 	up
      DHCP 	up
      MAC address 	00:0e:0c:da:31:82
      IP address 	24.179.178.233
      Gateway 	24.179.178.1
      ISP DNS servers 	4.2.2.2
      4.2.2.3
      Media 	100baseTX <full-duplex>In/out packets 	63911/49378 (30.54 MB/3.89 MB)
      In/out errors 	0/0
      Collisions 	0
      WAN2dsl interface (vr0)
      Status 	up
      DHCP 	up
      MAC address 	00:50:8d:7c:27:69
      IP address 	192.168.0.2
      Gateway 	192.168.0.1
      Media 	100baseTX <full-duplex>In/out packets 	1941/1411 (1.43 MB/211 KB)
      In/out errors 	0/0
      Collisions 	0</full-duplex></full-duplex>
      Everything is working fine over the cable setup, but I'm a little bit at a loss as how to setup the load balancer pools and firewall rules because one of the feeds is acting as a bridge with a DHCP address (the cable feed) and one is through a router  with the 192.168.0.0/24 address (The DSL feed.)
      Any suggestions would be most apreciated.
        Gunther
        Anyone interested in a one time consulting fee to help me get the initial configuration up and working?
        • I Offline
          indesman
          What version of pfSense are you using?  When I set up my 1.2.3 configuration I used a tutorial that I can't find right now.  You might want to check this out:
          http://doc.pfsense.org/index.php/Multi_WAN_/_Load_Balancing  I didn't use this one but it looks similar.
          and I just found this for 2.0 which I'm going to get started on in the morning:
          http://forum.pfsense.org/index.php?topic=28121.0
          Regards,
          Michael
