    Need help: How to activate Layer7 P2P Blocker?
    26 Posts 12 Posters 29.7k Views
    • E Offline
      eri--
      Nah the rules does not match like that.
      You have to make it match so divert can continue.
        Cino
        What would be the best way to get it to match? I changed the rule to use LAN has the interface and dest port 110. I was still able to access it.
        pass  on {  em2  } inet proto tcp  from any to any port 110  divert 41786 flags S/SA keep state ( max-packets 5  )  label "USER_RULE"
        		 <rule><id><type>pass</type>
        			<interface>lan</interface>
        			<ipprotocol>inet</ipprotocol>
        			 <tag><tagged><direction>any</direction>
        			<floating>yes</floating>
        			 <max><max-src-nodes><max-src-conn><max-src-states><statetimeout><statetype>keep state</statetype>
        			 <os><protocol>tcp</protocol>
        			<source>
        				 <any><destination><any><port>110</port></any></destination>
        			 <descr><l7container>testblocking</l7container></descr></any></os></statetimeout></max-src-states></max-src-conn></max-src-nodes></max></tagged></tag></id></rule>
          heper
          so, whats the conclusion ?
          does it work or not ? i've only tried like 10 mins to get it working but haven't thus far
            Cino
            I do have good news about Layer 7 blocking, I was able to block all pop3 traffic from leaving my box. I still have to do more testing but progress is being made :-) Thanks Ermal!!!!
              root2020
              How did you fix it?
                Cino
                I didn't fix it. Ermal did… Update to the lastest snapshot and give it try
