    Dhcpleases: Could not deliver signal HUP to process because its pidfile does not
    28 Posts 10 Posters 20.5k Views
      tebeve
      2.1-DEVELOPMENT (i386)
      built on Mon Sep 5 04:07:51 EDT 2011
      Unbound 1.4.12_03
      I've got a log full of these now as well… was there ever a fix for this?
        Tikimotel
        I only see this "dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist" message
        a couple of times getting logged after an update and during the package reinstall process.
        It does not flood my log like previous RC2 and RC3's in combination with the unbound package.
        I'm using the last AMD64-RC3 10 September 2011.
        packages:
        • Squid
        • Squidguard
        • Unbound
        For me it was fixed ages ago.
        This is part of my log during/after my last update to the last RC3 build…
        7x the DHCP PID message appears and stops after everything is installed and ready.
        Sep 13 18:11:29 	php: : Not calling package sync code for dependency squidusers of squid because some include files are missing.
        Sep 13 18:11:29 	php: : Not calling package sync code for dependency squidcache of squid because some include files are missing.
        Sep 13 18:11:32 	php: : IPSEC: One or more IPsec tunnel endpoints has changed its IP. Refreshing.
        Sep 13 18:11:33 	login: login on ttyv0 as root
        Sep 13 18:11:33 	squid[47480]: Squid Parent: child process 16905 exited with status 0
        Sep 13 18:11:34 	check_reload_status: Reloading filter
        Sep 13 18:11:35 	php: : SQUID is installed but not started. Not installing "nat" rules.
        Sep 13 18:11:35 	php: : SQUID is installed but not started. Not installing "pfearly" rules.
        Sep 13 18:11:35 	php: : SQUID is installed but not started. Not installing "filter" rules.
        Sep 13 18:11:36 	Squid_Alarm[698]: Squid has exited. Reconfiguring filter.
        Sep 13 18:11:36 	Squid_Alarm[1295]: Attempting restart...
        Sep 13 18:11:37 	squid[2769]: Squid Parent: child process 3257 started
        Sep 13 18:11:40 	Squid_Alarm[5715]: Reconfiguring filter...
        Sep 13 18:11:41 	Squid_Alarm[14989]: Squid has resumed. Reconfiguring filter.
        Sep 13 18:12:14 	check_reload_status: Syncing firewall
        Sep 13 18:12:14 	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such file or directory.
        Sep 13 18:12:16 	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such file or directory.
        Sep 13 18:12:16 	dhcpd: Internet Systems Consortium DHCP Server 4.2.1-P1
        Sep 13 18:12:16 	dhcpd: Copyright 2004-2011 Internet Systems Consortium.
        Sep 13 18:12:16 	dhcpd: All rights reserved.
        Sep 13 18:12:16 	dhcpd: For info, please visit https://www.isc.org/software/dhcp/
        Sep 13 18:12:17 	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such file or directory.
        Sep 13 18:12:17 	dhcpd: Internet Systems Consortium DHCP Server 4.2.1-P1
        Sep 13 18:12:17 	dhcpd: Copyright 2004-2011 Internet Systems Consortium.
        Sep 13 18:12:17 	dhcpd: All rights reserved.
        Sep 13 18:12:17 	dhcpd: For info, please visit https://www.isc.org/software/dhcp/
        Sep 13 18:12:17 	check_reload_status: Reloading filter
        Sep 13 18:12:40 	php: : The command '/sbin/mdmfs -s 200M md15 /tmp/squidGuard' returned exit code '1', the output was 'mdmfs: mount exited with error code 64'
        Sep 13 18:12:40 	php: : The command 'chmod 1777 /tmp/squidGuard' returned exit code '1', the output was 'chmod: /tmp/squidGuard: No such file or directory'
        Sep 13 18:14:19 	php: : The command 'umount -f /tmp/squidGuard' returned exit code '1', the output was 'umount: /tmp/squidGuard: not a file system root directory'
        Sep 13 18:17:06 	check_reload_status: Syncing firewall
        Sep 13 18:17:06 	php: /pkg_edit.php: Reloading Squid for configuration sync
        Sep 13 18:17:07 	check_reload_status: Reloading filter
        Sep 13 18:17:13 	php: /pkg_edit.php: Reloading Squid for configuration sync
        Sep 13 18:17:13 	check_reload_status: Reloading filter
        Sep 13 18:20:07 	sshd[52346]: Accepted keyboard-interactive/pam for root from 192.168.0.50 port 1607 ssh2
        Sep 13 18:20:07 	sshd[52346]: subsystem request for sftp
        Sep 13 19:49:03 	php: /index.php: Successful webConfigurator login for user 'admin' from 192.168.0.50
        Sep 13 21:53:12 	php: /index.php: Successful webConfigurator login for user 'admin' from 192.168.0.50
        Sep 14 17:38:03 	php: /index.php: Successful webConfigurator login for user 'admin' from 192.168.0.50
        Sep 15 18:13:39 	php: /index.php: Successful webConfigurator login for user 'admin' from 192.168.0.50
        p.s.
        I've manually set "192.168.0.1" into the DNS and default Gateway fields in the DHCP server settings.
        And added "192.168.0.1" as a DNS in General Setup. (not using unbound configured as a forwarder)
          tebeve
          hmmm, strange because I'm seeing it all the time now…
          Sep 15 11:49:01	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 15 10:59:30	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 15 10:08:02	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 15 09:32:16	php: /diag_logs.php: Successful login for user 'admin' from: 10.10.xx.xx
          Sep 15 09:13:51	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 15 08:19:53	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 15 07:22:39	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 15 06:28:25	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 15 05:36:07	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 15 04:47:58	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 15 03:52:36	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 15 03:04:41	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 15 02:10:33	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 15 01:21:05	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 15 00:34:00	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 14 23:37:58	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 14 22:52:52	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 14 22:06:46	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 14 21:19:35	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 14 20:22:36	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 14 19:28:52	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 14 18:39:46	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 14 17:43:26	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 14 16:45:17	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 14 15:53:19	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 14 14:55:20	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 14 14:09:27	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 14 13:13:49	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 14 12:17:31	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 14 11:20:28	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 14 10:28:51	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 14 09:41:58	dhclient: Creating resolv.conf
          Sep 14 09:41:58	dhclient: RENEW
          Sep 14 09:31:49	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 14 09:19:47	php: /diag_logs.php: Successful login for user 'admin' from: 10.10.xx.xx
          Sep 14 09:19:38	php: /diag_logs.php: Session timed out for user 'admin' from: 10.10.xx.xx
          Sep 14 08:36:58	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 14 07:47:41	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 14 06:53:26	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 14 05:53:27	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 14 05:06:46	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 14 04:18:57	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 14 03:20:04	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 14 02:21:57	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 14 01:27:54	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 14 00:36:59	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 13 23:51:08	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 13 23:19:07	php: /index.php: Successful login for user 'admin' from: 10.10.xx.xx
          Sep 13 22:59:18	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 13 22:09:54	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 13 21:23:54	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 13 20:30:02	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 13 19:33:11	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 13 18:47:04	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 13 17:48:57	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 13 16:54:35	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 13 15:58:59	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 13 15:01:50	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 13 14:03:27	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 13 13:12:26	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 13 12:22:22	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 13 11:26:57	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 13 10:38:06	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 13 09:40:22	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 13 08:47:22	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 13 07:51:26	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 13 07:04:05	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 13 06:16:17	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 13 05:21:24	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 13 04:33:47	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 13 03:42:19	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 13 02:47:29	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 13 01:58:53	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 13 01:11:23	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 13 00:18:23	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 12 23:27:24	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 12 22:40:10	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 12 21:44:55	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 12 20:51:20	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 12 19:53:20	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 12 19:07:03	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 12 18:07:08	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 12 17:17:39	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 12 16:30:09	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 12 15:30:54	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 12 14:36:12	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 12 13:40:12	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 12 12:41:53	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 12 11:56:04	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 12 10:59:22	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 12 10:12:12	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 12 09:41:58	dhclient: Creating resolv.conf
          Sep 12 09:41:58	dhclient: RENEW
          Sep 12 09:19:51	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 12 08:32:24	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 12 07:39:27	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 12 06:44:02	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 12 05:53:49	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 12 05:07:45	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 12 04:14:16	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 12 03:17:55	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 12 02:24:08	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 12 01:25:07	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 12 00:27:25	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 11 23:40:33	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 11 22:49:12	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 11 22:03:55	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 11 21:12:26	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 11 20:15:01	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 11 19:25:45	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 11 18:38:03	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 11 17:44:21	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 11 16:57:07	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 11 15:58:18	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 11 15:03:54	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 11 14:15:22	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 11 13:23:51	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 11 12:37:54	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 11 11:44:00	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 11 10:50:58	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 11 09:54:48	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 11 09:07:36	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 11 08:19:37	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 11 07:31:39	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 11 06:34:42	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 11 05:37:27	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 11 04:51:51	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 11 03:56:11	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 11 03:02:17	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 11 02:16:15	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 11 01:21:47	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 11 00:29:24	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 10 23:43:45	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 10 22:51:03	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 10 21:53:37	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 10 20:58:13	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 10 20:04:16	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 10 19:14:31	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 10 18:17:00	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 10 17:19:34	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 10 16:23:48	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 10 15:34:53	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 10 14:35:33	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 10 13:43:06	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 10 12:50:47	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 10 11:57:19	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 10 11:02:40	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 10 10:10:27	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 10 09:41:58	dhclient: Creating resolv.conf
          Sep 10 09:41:58	dhclient: RENEW
          Sep 10 09:11:56	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 10 08:26:30	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 10 07:27:43	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 10 06:40:46	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 10 05:50:29	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 10 04:59:43	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 10 04:12:20	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 10 03:17:19	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 10 02:20:14	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 10 01:20:38	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 10 00:25:42	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 9 23:30:28	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 9 22:36:22	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 9 21:49:35	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 9 21:00:54	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 9 20:10:38	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 9 19:18:09	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 9 18:31:45	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 9 17:40:07	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 9 16:49:53	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 9 15:55:52	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 9 15:02:15	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 9 14:04:06	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 9 13:15:46	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 9 12:19:08	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 9 11:19:33	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 9 10:21:44	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 9 09:27:54	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 9 09:25:53	php: /index.php: Successful login for user 'admin' from: 10.10.xx.xx
          Sep 9 08:39:14	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 9 07:51:17	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
          Sep 9 07:13:13	check_reload_status: Syncing firewall
          Sep 9 07:13:04	check_reload_status: Reloading filter
          I've done the same with my local gateway IP for the DNS in DHCP (on both IPv4 & IPv6), tho, I have not done it in General Setup for DNS.
          • jimpJ Offline
            The problem with dhcpleases was fixed long ago - what you are seeing is an issue with running unbound, and should be in a new thread.
            Not sure how that one will be worked around. The DHCP lease registration program is trying to signal dnsmasq about the update but since you're running unbound and not dnsmasq, it can't send a HUP signal.
            The easy way would be to have unbound write its pid file to what dnsmasq was using (presuming that the DNS forwarder is disabled when unbound is on).
            Do not Chat/PM for help!
              tebeve
              Thanks Jim, understood.
              I wasn't having this issue until recently, even with running unbound (that I noticed anyway, or certainly not to this extreme)… I'll start a new thread tho just so warren has a heads up.
              Should I post it under the DHCP & DNS board?
              • jimpJ Offline
                The packages forum would probably be better since it's specific to the unbound package.
                • I Offline
                  irvingpop
                  Guys,
                  I'm seeing the same error message filling up my logs.  Fresh install of pfSense 2.0-RELEASE on ALIX, no Unbound.
                  I found that the dhcpleases tool is running with a specified pidfile of /var/run/dnsmasq.pid
                  root  41403  0.0  0.8  3316  920  ??  Is    4:24PM  0:00.20 /usr/local/sbin/dhcpleases -l /var/dhcpd/var/db/dhcpd.leases -d foo.com -p /var/run/dnsmasq.pid -h /var/etc/hosts
                  But the actual corresponding pidfile is /var/run/dhcpleases.pid
                  cat dhcpleases.pid
                  41403
                  Linking dnsmasq.pid to dhcpleases.pid seems to make the error messages go away.    Probably won't survive a reboot, IIRC.
                  ln -s /var/run/dhcpleases.pid /var/run/dnsmasq.pid
                  Developers, this should be easy to fix in /etc/inc/system.inc, right?
                    jikjik101
                    I also see this error once in a while, although it is not flooding the log.
                    2.0-RELEASE (i386)
                    built on Tue Sep 13 17:28:43 EDT 2011
                    I am not using Unbound.
                    Packages are only squid, squidguard, ligthsquid and imspector.
                    Nov 22 09:02:11 	apinger: Starting Alarm Pinger, apinger(11693)
                    Nov 22 09:02:10 	apinger: Exiting on signal 15.
                    Nov 22 09:02:10 	php: /system_gateways.php: Removing static route for monitor 208.67.220.220 and adding a new route through x.x.x.x
                    Nov 22 09:02:10 	php: /system_gateways.php: Removing static route for monitor 208.67.222.222 and adding a new route through x.x.x.x
                    Nov 22 09:02:10 	check_reload_status: Reloading filter
                    Nov 22 09:02:10 	php: /system_gateways.php: ROUTING: setting default route to x.x.x.x
                    Nov 22 09:02:09 	check_reload_status: Syncing firewall
                    Nov 22 09:02:01 	check_reload_status: Syncing firewall
                    Nov 22 09:01:45 	check_reload_status: Reloading filter
                    Nov 22 09:01:45 	php: /system.php: OpenNTPD is starting up.
                    Nov 22 09:01:45 	dnsmasq[52145]: read /etc/hosts - 396 addresses
                    Nov 22 09:01:44 	dnsmasq[52145]: read /etc/hosts - 396 addresses
                    Nov 22 09:01:44 	dhcpd: For info, please visit https://www.isc.org/software/dhcp/
                    Nov 22 09:01:44 	dhcpd: All rights reserved.
                    Nov 22 09:01:44 	dhcpd: Copyright 2004-2011 Internet Systems Consortium.
                    Nov 22 09:01:44 	dhcpd: Internet Systems Consortium DHCP Server 4.2.1-P1
                    Nov 22 09:01:43 	dnsmasq[52145]: read /etc/hosts - 396 addresses
                    Nov 22 09:01:43 	dnsmasq[52145]: ignoring nameserver 127.0.0.1 - local interface
                    Nov 22 09:01:43 	dnsmasq[52145]: using nameserver 208.67.220.220#53
                    Nov 22 09:01:43 	dnsmasq[52145]: using nameserver 8.8.4.4#53
                    Nov 22 09:01:43 	dnsmasq[52145]: using nameserver 208.67.222.222#53
                    Nov 22 09:01:43 	dnsmasq[52145]: using nameserver x.x.x.x#53
                    Nov 22 09:01:43 	dnsmasq[52145]: reading /etc/resolv.conf
                    Nov 22 09:01:43 	dnsmasq[52145]: compile time options: IPv6 GNU-getopt no-DBus I18N DHCP TFTP
                    Nov 22 09:01:43 	dnsmasq[52145]: started, version 2.55 cachesize 10000
                    Nov 22 09:01:43 	dhcpleases: Could not deliver signal HUP to process because its pidfile does not exist, No such process.
                    Nov 22 09:01:42 	dnsmasq[1092]: exiting on receipt of SIGTERM
                    Nov 22 09:01:42 	dnsmasq[1092]: read /etc/hosts - 396 addresses
                    Nov 22 09:01:42 	dhcpd: For info, please visit https://www.isc.org/software/dhcp/
                    Nov 22 09:01:42 	dhcpd: All rights reserved.
                    Nov 22 09:01:42 	dhcpd: Copyright 2004-2011 Internet Systems Consortium.
                    Nov 22 09:01:42 	dhcpd: Internet Systems Consortium DHCP Server 4.2.1-P1
                    Nov 22 09:01:42 	dnsmasq[1092]: ignoring nameserver 127.0.0.1 - local interface
                    Nov 22 09:01:42 	dnsmasq[1092]: using nameserver 208.67.220.220#53
                    Nov 22 09:01:42 	dnsmasq[1092]: using nameserver 8.8.4.4#53
                    Nov 22 09:01:42 	dnsmasq[1092]: using nameserver 208.67.222.222#53
                    Nov 22 09:01:42 	dnsmasq[1092]: using nameserver x.x.x.x#53
                    Nov 22 09:01:42 	dnsmasq[1092]: reading /etc/resolv.conf
                    Nov 22 09:01:40 	dnsmasq[1092]: read /etc/hosts - 396 addresses
                    Nov 22 09:01:40 	check_reload_status: Syncing firewall
