Problems on Alix 2.0 RC will not start DHCP server on LAN interface
  • I upgraded to the latest 2.0 RC snapshot. 2.0 RC did not recognize
    my pppoe interface at first until I reset all settings to factory defaults.
    My OPT1 interface will not issue DHCP leases.
    Moreover, I do not even think clients can see Pfsesne
    because static ips assigned to clients do not work.
    My Network:
    vr2 WAN ppoe0 –--- vr1 OPT1 ----- vr0 LAN
     WAN                  192.168.2.1      192.168.1.1
                            dhcp server        dhcp server
    ==========OS==============
    Name pfSense.localdomain
    Version 2.0-RC1 (i386)
    built on Sat Feb 26 16:33:51 EST 2011
    Platform nanobsd (2g)
    NanoBSD Boot Slice pfsense1 / ad0s2
    CPU Type Geode(TM) Integrated Processor by AMD PCS
    ==========LOG=============
    dhcpd: For info, please visit https://www.isc.org/software/dhcp/
    Mar 1 11:01:45 dhcpd: All rights reserved.
    Mar 1 11:01:45 dhcpd: Copyright 2004-2010 Internet Systems Consortium.
    Mar 1 11:01:45 dhcpd: Internet Systems Consortium DHCP Server 4.1.1-P1
    Mar 1 19:01:43 check_reload_status: syncing firewall
    Mar 1 11:01:04 dhcpd: For info, please visit https://www.isc.org/software/dhcp/
    Mar 1 11:01:04 dhcpd: All rights reserved.
    Mar 1 11:01:04 dhcpd: Copyright 2004-2010 Internet Systems Consortium.
    Mar 1 11:01:04 dhcpd: Internet Systems Consortium DHCP Server 4.1.1-P1
    Mar 1 19:01:03 check_reload_status: syncing firewall
    Mar 1 10:52:11 dhcpd: For info, please visit https://www.isc.org/software/dhcp/
    Mar 1 10:52:11 dhcpd: All rights reserved.
    Mar 1 10:52:11 dhcpd: Copyright 2004-2010 Internet Systems Consortium.
    Mar 1 10:52:11 dhcpd: Internet Systems Consortium DHCP Server 4.1.1-P1
    Mar 1 18:52:10 check_reload_status: syncing firewall
    Mar 1 10:51:50 dhcpd: For info, please visit https://www.isc.org/software/dhcp/
    Mar 1 10:51:50 dhcpd: All rights reserved.
    Mar 1 10:51:50 dhcpd: Copyright 2004-2010 Internet Systems Consortium.
    Mar 1 10:51:50 dhcpd: Internet Systems Consortium DHCP Server 4.1.1-P1
    Mar 1 18:51:49 check_reload_status: syncing firewall
    Mar 1 18:51:34 check_reload_status: syncing firewall
    Mar 1 10:51:34 syslogd: kernel boot file is /boot/kernel/kernel
    Mar 1 10:51:34 syslogd: exiting on signal 15
    Mar 1 10:39:32 syslogd: kernel boot file is /boot/kernel/kernel
    Mar 1 10:39:32 syslogd: exiting on signal 15
    Mar 1 10:37:33 kernel: vr2: link state changed to UP
    Mar 1 18:37:33 check_reload_status: Linkup starting vr2
    Mar 1 10:34:20 php: : Hotplug event detected for lan but ignoring since interface is configured with static IP (192.168.1.1)
    Mar 1 10:34:19 kernel: vr0: link state changed to UP
    Mar 1 18:34:19 check_reload_status: Linkup starting vr0
    Mar 1 10:33:48 php: : Hotplug event detected for lan but ignoring since interface is configured with static IP (192.168.1.1)
    Mar 1 10:33:47 kernel: vr0: link state changed to DOWN
    Mar 1 18:33:47 check_reload_status: Linkup starting vr0
    Mar 1 10:33:33 kernel: vr2: link state changed to DOWN
    Mar 1 18:33:33 check_reload_status: Linkup starting vr2
    Mar 1 10:32:56 php: : Hotplug event detected for lan but ignoring since interface is configured with static IP (192.168.1.1)
    Mar 1 10:32:55 kernel: vr0: link state changed to UP
    Mar 1 18:32:55 check_reload_status: Linkup starting vr0
    Mar 1 10:32:48 php: : Hotplug event detected for lan but ignoring since interface is configured with static IP (192.168.1.1)
    Mar 1 10:32:47 kernel: vr0: link state changed to DOWN
    Mar 1 18:32:47 check_reload_status: Linkup starting vr0
    Mar 1 18:25:59 check_reload_status: reloading filter
    Mar 1 18:25:56 check_reload_status: syncing firewall
    Mar 1 10:25:33 kernel: vr2: link state changed to UP
    Mar 1 18:25:33 check_reload_status: Linkup starting vr2
    Mar 1 10:21:33 kernel: vr2: link state changed to DOWN
    Mar 1 18:21:33 check_reload_status: Linkup starting vr2
  • Hard to say from that, first guess your OPT interface isn't enabled?
  • I enabled the OP1 interface and added a firewall rule through the GUI.
    Still no go.
    I guess a settings for the dhcp server is not being set in the xml.
    Robert
  • Rebel Alliance Developer Netgate
    What do the settings for the DHCP server look like for opt1? What does /var/dhcpd/etc/dhcpd.conf look like?
  • option domain-name "localdomain";
    option ldap-server code 95 = text;
    option domain-search-list code 119 = text;
    default-lease-time 7200;
    max-lease-time 86400;
    log-facility local7;
    ddns-update-style none;
    one-lease-per-client true;
    deny duplicates;
    ping-check true;
    authoritative;
    subnet 192.168.1.0 netmask 255.255.255.0 {
           pool {
                   range 192.168.1.11 192.168.1.22;
           option routers 192.168.1.1;
           option domain-name-servers 192.168.1.1;
    subnet 192.168.2.0 netmask 255.255.255.0 {
           pool {
                   range 192.168.2.22 192.168.2.25;
           option routers 192.168.2.1;
           option domain-name-servers 192.168.2.1;
    Looks normal to me… Anything blocked in the firewall logs on that interface?
    /var/dhcpd/var/db/
    The one ending in ~ is a backup, not the real leases file.
    Are you low on space on /var maybe?
  • Filesystem           Size    Used   Avail Capacity  Mounted on
    /dev/ufs/pfsense1    913M    136M    704M    16%    /
    devfs                1.0K    1.0K      0B   100%    /dev
    /dev/md0              38M    270K     35M     1%    /tmp
    /dev/md1              58M    7.7M     46M    14%    /var
    /dev/ufs/cf           49M    287K     45M     1%    /cf
    devfs                1.0K    1.0K      0B   100%    /var/dhcpd/dev
  • Packet capture on the OPT1 interface, see if the traffic for either statically assigned hosts, or DHCP requests, gets to it. Check the dhcpd process's command line arguments for the interfaces.
  • Heres the DHCP process's command line arguments;
    I'll do a packet capture.
    dhcpd  18718  0.0  1.6  6752  4024  ??  Ss    1:48PM   0:00.81 /usr/local/sbin/dhcpd -user dhcpd -group _dhcp -chroot /var/dhcpd -cf /etc/dhcpd.conf vr0 vr1
    Strange, I select OPT1 in the Packet Cap GUI and seems like its selecting the WAN interface.
    Just rename the file to .pcap
    Robert
    packetcapture(2).xls
  • @jamesdean:
    that's your WAN traffic, if you picked OPT1 your OPT1 has to be plugged into WAN somehow or bridged to it or something.
  • I never setup a bridge, My wan is connected to vr2 and is working. vr2 (OP1) is working and handing out leases.
    Just my vr1 (LAN) will not hand over leases. I might have to revert back to pfSense 1.2.3. If I cant figure this out tonight.
    Robert
