    Question/looking For Help Or pointer to right Location for info
    3 Posts 2 Posters 1.4k Views
      hevreka
      Hello All And Thanks For Reading This.
      I Know I Have Seen a Help Page Somewhere About how you put a forward for LAN IP:PORT to Specific WAN IP:PORT
      Here Is My Setup and My Problem:
      Internet1 To Modem1 in Bridage Mode (DHCP from ISP) To Router 1 With PPPoE
      Internet2 To Modem2 in Bridage Mode (DHCP from ISP) To Router 2
      Router 1 IP 192.168.20.1 To IP 192.168.20.2 "WAN1" Pfsense
      Router 2 IP 192.168.30.1.To IP 192.168.30.2 "WAN2" Pfsense  Same Pc As Above
      Now To My Problem I Want to connect to Router 1 and 2 from LAN (To Configure or Check logs)
      by IP 192.168.0.1 Port 8100 (for Router 1) and IP 192.168.0.1 Port 8200 (for Router 2) on Pfsense PC
      My Best And Warmest Regards
      Hevreka
        You don't say which version of pfSense you are using.
        I have found this method to be very quick and easy under 1.2.3:
        http://doc.pfsense.org/index.php/How_can_i_access_my_PPPoE_Modem_on_WAN
        A simple method under 2.0 (and a far more complex method for 1.2.3) is listed here:
        http://doc.pfsense.org/index.php/Accessing_modem_from_inside_firewall
          hevreka
          Thank You
          That Was It What I Was Missing =)
          My Best Regards
          Hevreka
