    Where/How to post Procedure for setting up Dual Wan for current Snapshot?
    32 Posts 6 Posters 12.0k Views
    • V
      Vescovo
      It is perfect! ;D It will be interesting to see how you position it. It is good to get new views. This always improves the documentation.
      • L
        lampie
        I also contributed to the documentation. Added the FTP workaround for multiwan and a little cosmetics :)
        '''''FTP WORKAROUND'''''
        If you want to connect to a FTP server you need to add this workaround to your LAN tab.
        Proto      Source        Port        Destination        Port        Gateway
        TCP        LAN net      *          127.0.0.1          1 - 65535  *
        Now the packets are forwarded correctly and you can connect to an FTP server.
        '''''pORT FORWARDING'''''
        • V
          Vescovo
          Hey Pootle, you positioning was great. The image was just put in line. It is a little tricky to do it but it worth it to show your image! The image will make it easier for the next person. ;D
          Hi Lampie, thanks for you additon.  :)  I know it is hard to add stuff to the DOCO and make it look good! Unfortunately, I did not get a chance to fully test FTP.  My outgoing FTP(passive) has worked with the default rules.  Is the workaround is for Inbound or oubound FTP?  Why is that rule superior to the default LAN -> Wan1 rule in the Firewalls:Rules image?
          • P
            Pootle
            OK, that's good.  I wasn't sure if it was better to link to the picture or put it in line, but you're right, it works well in line.
            Just thinking of doing a short note on running in a VM….
            • L
              lampie
              @Vescovo:
              For active FTP connections (not passive) i needed this rule to make it work. Inbound i still have to test, but that is working out of the box i guess. Without this rule i simply cant make any connection (active) to a FTP server.
              What i also noticed is that rebooting the system makes after you add these LAN rules is the best option. I had some problems with not correctly forwarding ports to a designated IP adress. After a reboot this worked fine.
              • V
                Vescovo
                Thanks Lampie, I have also noticed that a reboot after filter changes appears to always make things work that may not have worked before. I will check out your comments later this week.
                • S
                  sullrich
                  Update to  the latest snapshot.  There are bits in place to make sure check_reload_status is always running now.
                  • P
                    Pootle
                    Dunno if you spotted it yet Vescovo, but I've amended the document page on multi wan to put in proper wikiheaders so you get a content list at the front - makes it easier to find the bit you want….
                    • V
                      Vescovo
                      No I did not. :-[ Let me try it. The change page did not point it out to me. Sounds great. :)
                      I like it. Many, many thanks. ;D Your doco on the Vitual Machine vesion of pfSense is very good.
                      • K
                        krull
                        @Vescovo:
                        Hey Pootle, that's an excellent diagram. Why don't you add it to the DOC example. The only difference is the DOC sets the the WAN1(192.168.0.2) and WAN2(192.168.2.2) and The modem/routers to 192.168.0.254 and 192.168.2.254. If you can make those changes it will be consistent with the rest of the DOC.
                        Hey all,
                        I apologize for diggin up ole posts, but I got a slightly 'on topic' query that needs attention:
                        Looking through the doc.pfsense.org wiki page for LoadBalancing, the modem/routers are stated to have none-routable IPs on them as stated above by Vescovo. What if they were on bridge mode with Static IPs on? Would setting up the Pfsense WAN ports to the designated Static IPs work as good as it is set on the Wiki? (Thus eliminating the need for three consecutive local net to only your LAN Network…)
                        I have a setup based on the wiki's Howto following word by word but substituting the Static IP Addresses instead and I get online connectivity just fine, but for some reason my portforwards are not working and I suspect that it has something to do with the bridge mode of the ADSL modems.
                        Please advice. Thanks a bunch.
                        • P
                          Pootle
                          It should work as you say, and as long as your WAN / WAN2 subnets and addresses are set up OK, it should all work OK.
                          I did try setting my linksys am200 into bridge mode but could not even persuade it to connect, so I gave up and let it NAT
                          Sounds like you have outgoing access working, but are just having trouble with incoming port forwarding.  I use port forwarding in my config OK, but haven't used it with modems in bridge mode.
                          • K
                            krull
                            Thanks Pootle for the reply. Since the Port forwarding section of the LoadBalancing wiki page just states to do the normal Portforwards, I see no problems with the rules I set (Port 80 to internal IP system for example…). I am going to do a run down of it once more (3rd time install...) with a clean slate install of pfsense to see if I miss anything.
                            My goal here is to somehow contribute to the docs as well once everything's working on my setup. Superb work so far with the docs guys! Thanks a bunch.
