Help with load balancing and multi-WAN
I need HELP…..i'm start work with pfsense......and i need load balancing with multiwan connection and failover connection i follow the HOWTO of the official page.....but when traceroute all the trafic go with the first modem...and when disconnect the first modem he failover dosen't work......
same probleme :-\
thanks the problem resolv…..
For others who may land on this thread, you probably just needed to define the load balancer gateway on that first firewall rule. All your LAN traffic would match that rule and use the default gateway, and your second rule would never be hit. So the easiest thing to do would be to delete that second rule, edit the first, and set the gateway there.
