    PfSense to Sonicwall PRO 230 IPSec phase 2 proposals? (How to turn on HMAC?)
    3 Posts 1 Posters 3.0k Views
      agrikk
      I am trying to build a VPN tunnel between a Sonicwall PRO 230 and a pfSense box and I'm having a problem finding a compatible set of Phase 2 Proposals.
      Here are my options on the Sonicwall box:
      The problem is that the Phase two settings on the sonicwall all include an HMAC authentication package that I cannot find where to turn on within pfSense.
      Can anyone point me to where HMAC settings are stored on pfsense, or tell me a good set of phase 1 / phase 2 IPSec proposals that will work between these two devices?
        agrikk
        At least I assume it's an incompatile phase 2 authentication.
        What phSense shows in its log:
          agrikk
          IN the intrest of completion, I got the two to connect by the folllowing:
          Open TCP port 500 on the WAN port of pfSense in the firewall then:
          Both:
          Phase one Main Mode / Group 2 / 3DES / SHA1
          **SonicWall:**Phase two ESP / 3DES / HMAC / SHA1 (PFS Off)
          **pfSense:**Phase two ESP / 3DES / Blowfish / SHA1 (PFS Off)
