    Help on load balancing arplookup 210.213.215.254 failed: host is not on local ne
    48 Posts 11 Posters 27.7k Views
      sai
      dotdash
      @dotdash:
      wan 100.200.200.110
      subnet mask 255.255.255.255
      gateway 100.200.200.254
      Its a bit early in the morning here, but your subnet mask looks way wrong. The WAN and its gateway should be on the same subnet, and so the arplookup error seems to be reasonable. Try a subnet of 255.255.255.0
        hoba
        @sai:
        dotdash
        @dotdash:
        wan 100.200.200.110
        Its a bit early in the morning here, but your subnet mask looks way wrong. The WAN and its gateway should be on the same subnet, so try a subnet of 255.255.255.0
        No, pppoe just works this way.
          cheeky
          @hoba
          Still waiting for the final resolution to this problem, i'm still using now the original 1.0.1 with no problem.
          Thank you very much.
          :D ;D ::)
            ndelong
            If it helps, I'm in a similar situation (fail-over not working due to arp messages):
            WAN1: PPPoE w/"static" DHCP /32
            WAN2: Static
            Running 1.0.1-SNAPSHOT-03-08-2007
            Getting these messages:
            kernel: arplookup 204.213.240.xxx failed: host is not on local network
            kernel: arpresolve: can't allocate route for 204.213.240.xxx
            Anything I can do to help? Send logs, etc?
              sullrich
              Try adding static routes for these hosts or check the routing table to ensure they are correct.
              netstat -rn
              Also I recall LB not working with pppoe but I could be wrong here.
                databeestje
                that would be a yes
                I think we add a route for the gateway on the underlying interface instead of the ng0 device.
                Which would result in this iirc.
                  ndelong
                  Our firewall started off with PPPoE on the WAN interface connected to an old Westel modem. We added a cable connection w/static IP months later and are currently testing LB/FO. Both connections work fine independently of each other - even with the load balancing pools created. As soon as we create any rules on the LAN interface that reference the LB or FO gateways, we get intermittent connectivity and those arp messages. Unfortunately, I'm not on that customer's site, so my netstat -rn is shows the routes with LB/FO rules disabled:
                  Destination        Gateway            Flags    Refs      Use  Netif Expire
                  default            204.213.240.129    UGS         0  7510236    ng0
                  74.92.60.116/30    link#4             UC          0        0    em3
                  74.92.60.118       00:13:f7:22:ae:b0  UHLW        1   432194    em3   1043
                  127.0.0.1          127.0.0.1          UH          0        0    lo0
                  192.168.1          link#3             UC          0     3236    em2
                  204.213.240.253    lo0                UHS         0        0    lo0
                  Would a temporary workaround be to connect the Westel modem to a Linksys router (to handle the PPPoE) and configure static RFC1918 IP's between the pfSense box and the Linksys?
                  • dotdashD Offline
                    dotdash
                    A similar situation was discussed here: http://forum.pfsense.org/index.php/topic,4100.0.html
                    Quick summary:
                    You could use 1.0.1 release and PPPoE on pfSense's WAN.
                    You could double nat, but that sucks.
                    If you have multiple publics (static block), have a router (another pfSense with LAN bridged to WAN??) do the PPPoE and configure pfSense with a straight public IP.
                      databeestje
                      Setup a modem with pppoe bridging so you can just use dhcp or static with a public ip on the pfsense box.
                      Still have not found time to troubleshoot this.
                        ndelong
                        My main issue with reverting back to straight 1.0.1 is that the traffic I need to handle requires FO rather than LB. The traffic is such that if the recipient detects even one packet coming from a different source IP, they'll can the entire connection.
                        At a different site I have a Westell 6100 modem/router that appears to handle the pppoe & pass the static info on to the pfsense box. I'm going to see if I can replicate that configuration at this particular site.
                        databeestje - If you don't have time to troubleshoot, keep tossing ideas my way & I'll do my best to see what information I can gather for you. It would be awesome if we can get native PPPoE + Cable LB/FO working - poorman's enterprise!
                          databeestje
                          as of 22-03-2007 pppoe is still not supported/fixed.
                          Considering my vacation next week this is unlikely to change soon.
                          You can however use the old style configuration as a workaround. e.g. Not the interface name, but the gateway address. This requires manual config mangling and a filter reload.
                          so replace "wan" with you wan gateway IP in the relevant config section, etc. Please confirm that works with a pppoe connection before we troubleshoot this any further.
                          e.g. edit file config.xml, search for the load balancer section. Gateway goes left, monitor ip goes right.
                          Save that, reboot, see if it works.
                          Old style configuration will trigger some logging warnings though.
                            cheeky
                            Have tested using the above procedure, duan wan load balancing now working using PPPOE account in WAN.
                            ;D ;D ;D
                              databeestje
                              i'm one week further now. And i have a hunch.
                              Can you give me the contents of /var/etc/slbd.conf for the working and the non working configuration?
                              You will also need to clarify the ip configuration. E.g. which IP is the local address, which is the gateway and which is the monitor ip.
                              This would really help tracking this problem down, thank you.
                                rafael.cardoso
                                databeestje, load balance with ppoe works now?
                                Thank you!
                                Respect is Everything!
                                  databeestje
                                  Not untill Mr Cheeky or someone else with a not working pppoe config sends me the items I specified in my previous post.
                                  I lack a broken PPPoE connection to test this. Because I have tested this with one connection I had access too and it just worked.
                                    techatdd
                                    @databeestje:
                                    I have the same issue.
                                    Can you please give me the exactly way for the work around. I will provide you with the informations you needed then.
                                      techatdd
                                      @techatdd:
                                      @databeestje:
                                      I just read the other post: http://forum.pfsense.org/index.php/topic,4542.0.html
                                      Is this already fixed?
                                        cheeky
                                        This problem still exist using the latest 1.2 snapshots.
                                        You have to manually edit the lood balancing pools (replace wan, opt1, etc with the real ip address of the gateway. :( :( :(
                                          sullrich
                                          LB works fine now with PPPoE.
                                            cheeky
                                            Have tried the latest ISO of Pfsense-Beta-1-testing, this problem on LB using PPPOE on WAN still exist. Using the WAN gateway as a default gateway (single gateway), no problem. But if you include it on any pool that is LB or failover, error appears.
                                            Again, manually editing the pools replacing WAN with the real IP corrects the problem.
