    P2P traffic not going into P2P queue
    30 Posts 7 Posters 14.0k Views
      hoba
      What does your ack queues look like when under load? Try bumping up the ack queue a few percentages. Acks shouldn't get dropped if possible.
        pookguy88
        my ack queues look fine under load… but i'll have another look tonight, i know my qwanacks queue is fine. not too sure how my qlanacks is, I remember that I bumped the qlanacks queue too much once and it choked everything so I had to bring it back down.
          pookguy88
          yep, my ack queues were fine… my states were fine, like under 5000 the only thing that looked out of the ordinary was that the qOthersDownH queue had quite a few drops, like about 100 something...
            pookguy88
            well, i tried moving the http rule to the top of the rule list… maybe that will make a difference... the P2P catch-all rule as at the bottom
              pookguy88
              hoba,
              I seem to have run into that slow down again tonight, what seems to be happening is my qOthersDownH queue doesn't seem to want to 'take' the bandwidth away from my qP2PDown queue when it's maxed. Like it's being blocked or something, it doesn't want to take it's percentage of the bandwidth… any suggestions?? thanks again
              edit: it seems when I reload my rules/queues it seems to clear up the 'blocking'.... like, the shaper works without hiccups when I reload the queues during a P2P download.
                sullrich
                @pookguy88:
                hoba,
                Are you using miniupnp by chance?
                  pookguy88
                  @sullrich:
                  nope… should I be?
                    sullrich
                    Just checking.
                      The Printer Elf
                      Any more ideas on this one?
                      I'm having similar troubles, although possibly not in the usual way that one would expect to use the connection.
                      I have people downloading some pretty hefty files from me, but when that's not the case, I'd like BT to be using the upstream connection as best it can. I'm using μtorrent, it's set to use just one port, and I've currently got the scheduler set to ensure that there is some bandwidth available when I'm actually home and want to use the connection, as I can't seem to get the traffic shaper function the way I desire.
                      I'm quite willing to admit that I could well be being dim, and it's doing exactly what it's designed to do, I just haven't configured it correctly.
                      I've altered the qP2PUp and qP2PDown rules accordingly to reflect the port that μtorrent is targeted at, I've placed them at the top of the rules list, so there should be nothing stopping the traffic getting identified appropriately, and I've lowered the queue priorities and realtime bandwidth as much as is possible.
                      My problem is thus: I have a max upstream b/w of approx 55kB/s, and I've got μtorrent restricted to 50kB/s, yet when someone starts an HTTP download from me, I would expect μtorrent to grind to a halt, and ~55kB/s to be achieved, especially when using a multi-threaded download client, however μtorrent still maintains about a 30kB/s upload speed.
                      I'm open to both chastisement for being dim, and suggestions as to a solution if I'm not
                      What have I missed?!?
                        Borage
                        @The:
                        Many commercial router vendors said that it's impossible to bandwidth limit encrypted P2P traffic. Only one router vendor claims that they can limit encrypted Bittorrent & Obfuscated eMule traffic (don't remember the company name). I've been using MikroTik RouterOS from the beginning, and since some P2P clients implemented encryption, it's now only possible to block the encrypted traffic. I asked the MikroTik vendor and they said that it's impossible to bandwidth limit encrypted P2P traffic.
                        This problem forced me to add rules for all normal traffic, and one for the rest (unknown traffic).
