    Do I need a router? ISP Provides WAN and "LAN" ips? (LAN ips are my Public IPs)
    36 Posts 6 Posters 26.6k Views
      phorce1
      Not sure if this will work as intended and it might need extra work on your end as opposed to just putting a router in the middle.
      em0 – WAN -- .82.218
                Gateway .82.217 (default)
      em1 -- .32.226
                No gateway
      em2 -- .32.227
                No gateway
      em3 -- .32.227
                No gateway
      Go to Firewall-->NAT-->Outbound and set it to MANUAL.
      Delete the rules that show up (auto-generated rules that make the /27 get NATed to the WAN address)
      At this point your /27 is "live" on em1 to em7
      Set the CARPs (or PARPs) back up the way you had them working before but use the em1 - em7 .32.2xx addresses.
      This is the point where I lose it completely. My setup is simple public IP straight passthrough so I have no clue how to work with CARP. But from this point (NAT off) you should be able to connect the private address ranges to individual interfaces and create MANUAL NAT rules from private IP range ---> single public IP. the public IP will be passed through the WAN gateway intact.
      Somebody beat me with a wet noodle if I'm too far off base. I can't flesh it out any further due to the fact that I just started using pfSense a few days ago myself.
      I only have two interfaces in my pfsense box or I'd try hanging a private range off of one of my public IP's here as proof of concept.
      Gerald
        gderf
        You could pick from the rather extensive list here:
        http://en.wikipedia.org/wiki/List_of_router_or_firewall_distributions
        I would probably do the most minimal install of any BSD or Linux I was up on since I already have the software lying around. The only things you need are the networking stack and some way to manage it remotely such as sshd. There is always a lot of baggage that comes in with a default install, and it's probably best to do that and try to slim it down later rather than be too stingy going in and wind up with a non-working install.
        If you don't need remote management, you can just use a keyboard and monitor. After a while, you would probably disconnect these until needed again which could be very rarely. Just make sure the BIOS will handle booting all the way in with a missing keyboard.
        The only thing that needs configuring is enabling routing between interfaces, and configuring the two NICs. You might want to port scan the box once it comes up to be sure that no unnecessary services are running. And perhaps verify the actual thruput to be sure it is not a bottleneck.
        I guess none of my other suggestions worked?
        Not being a current pfsense user probably doesn't help much - I'm on m0n0wall these days.
        I seem to remember that the GB-Flash I was using long ago would allow Alias IPs on the WAN that were on another network, so you could have a /30 WAN and Alias the /27 onto it. But I never had a need for that type of setup and the software has long since been filed away and no loner in use.
        Let us know how this works out for you. That huge up-charge for that ISP supplied router is a big incentive to get this done yourself.
          gderf
          @phorce1:
          em1 -- .32.226
                    No gateway
          The above works.
          When you add this
          em2 – .32.227
                    No gateway
          it stops working.
          You can't have two interfaces in the same machine define the same network.
            phorce1
            @gderf:
            @phorce1:
            em1 -- .32.226
                      No gateway
            The above works.
            When you add this
            em2 – .32.227
                      No gateway
            it stops working.
            How about:
            em1 -- .32.225 (/27)
                      no gateway
            em2 -- .32.226
                      Gateway .32.225
            em3 --  .32.227
                      Gateway .32.225
            etc.
              gderf
              Specifying or not specifying a gateway isn't what breaks things.
              Having two or more network adapters defining the same network in the same machine does break things.
              He could split his One /27 into
              Two /28s or
              Four /29s or
              Eight /30s
              or a valid combination of fewer of each of the above, and put them on individual interfaces. These would become different networks so it would be legal and it would work. But that doesn't solve his problem.
                phorce1
                For his purposes breaking it into 8 /30 nets would probably work. He doesn't appear to have that many private networks he wants to NAT out. But he's already shopping for a router to make the /27 available to the pfSense box directly.
                  gderf
                  No, breaking his /27 into any set of smaller networks does not solve his problem because he cannot NAT to them out the WAN from private networks.
                    sierradump
                    @gderf:
                    @phorce1:
                    em1 -- .32.226
                              No gateway
                    The above works.
                    When you add this
                    em2 – .32.227
                              No gateway
                    it stops working.
                    The above doesn't work for me though, as I don't want public IPs on my LAN interfaces :)  I want private IPs 192.168.1.1 /24  etc… I want them NATd to public IPs...
                      gderf
                      I was only pointing out that it can't possibly work at all. The fact that it doesn't solve your problem doesn't matter much if it can't work at all.
                        sierradump
                        Will be building router later to try this out…
                          sierradump
                          @gderf:
                          Right, no I absolutely appreciate your help!  I liked how you know your networking.  I know it wouldn't work but I didn't know the "reasoning" I knew it had to do with the /30 and /27 over the WAN link but didn't know why, now I do :)
                          Thanks!
                            dhatz
                            sierradump, you can always try pfsense commercial support.
                            Anyway, if I understand your requirements correctly, I think pfsense can do what you want, i.e. NAT each internal network (LAN, WLAN etc) to a different public IP from your /27 range (which are different from the /30 that is used for your point-to-point link with your ISP)
                            Try using ProxyARP VIPs and Manual Outbound NAT (AON).
                              sierradump
                              @dhatz:
                              Sad face.  Tried this early on, it sort of worked but had broken functionality.
                                dhatz
                                @sierradump:
                                Broken functionality how?
                                I've tried it in the past and it seemed to work, although I haven't tested it thoroughly or used it in production.
                                  anagh
                                  use isp wan series on wan side and isp lan series i.e first public ip on lan side
                                  open firewall nat click Manual Outbound NAT rule generation and SAVE
                                  delete all  auto generated  nat rule
                                    gderf
                                    @anagh:
                                    This doesn't provide the private IP network interfaces he requires.
