    In need of help to solve a bandwidth issue
    61 Posts 11 Posters 25.6k Views
    • L Offline
      luke240778
      So i have a 20mb link.. when i look at the Traffic Graph, i often see like the attached screenshot..  its saying that the WAN connection is downloading full at 20mbps.. and that my HOTSPOT which is all my clients, is only using a small amount.. 3-4 mbps..
      As far as i see here, my bandwidth is all being used up but i dont see how??  All my clients are connected on the HOTSPOT interface.. On my pfsense box i just use captive portal MAC pass through and squid transparent proxy.
      Can someone please help here? I am adding more clients everyday and am worried that the bandwidth is somehow getting eaten up.
      traffic_graph.png_thumb
      • Cry HavokC Offline
        Cry Havok
        There have been a number of threads on diagnosing bandwidth usage - I would suggest you start by working through those. What other interfaces do you have and what packages do you have?
        • L Offline
          luke240778
          I have the following packages installed:
          bandwidthd.
          Cron
          darkstat
          iperf
          Lightsquid
          OpenVPN Client Export Utility
          phpSysInfo
          RRD Summary
          squid
          widescreen
          Interfaces i just have WAN, LAN  and an OPT1 which is just my office Wireless network.. which only 2 or 3 people use, very minimal usage on that.
          Ive looked through a bunch of the threads and saw a few that mention maybe a networl switch or something causing problems, but i dont have that at all.. very simple setup here.  The LAN interface is plugged to Ruckus equipment on the roof which serves my WiSP clients.
            tommyboy180
            Are you doing any type of traffic shaping QoS?
            -Tom Schaefer
            SuperMicro 1U 2X Intel pro/1000 Dual Core Intel 2.2 Ghz - 2 Gig RAM
            Please support pfBlocker | File Browser | Strikeback
            • L Offline
              luke240778
              No, nothing at all.
              Just using Captive portal Mac pass through.. and squid as a transparent proxy
                kapara
                pfTop via SSH
                Type the following commands to get ip's with highest throughput utilization…  do not type the commas
                7,  R (Capital R), s, 1
                Another option is install the pflowd package and downloading ManageEngines netflow monitor on a PC or Server on the lan.  Point the pfflowd to the PC with manageengine.  I used to use it alot!!!!
                You get 2 free devices to monitor.  Free phone support for setup too!
                Skype ID:  Marinhd
                • L Offline
                  luke240778
                  Thanks for that .. i am using both these options now.. great
                  Just quickly, that RATE in pftop.. is that in bytes or kilobyes?  So for example 348015 is what?
                    podilarius
                    I think it is in BYTES per sec.
                      dreamslacker
                      If your Squid is set to cache, it is possible that clients have initiated and cancelled downloads which results in Squid still persistently downloading the content for caching purposes though the clients no longer require it.
                      • L Offline
                        luke240778
                        Ah.. interesting… I do indeed have squid setup as a transparent proxy..  I will keep an eye on this.
                        Whilst on the subject of Squid.. Having the swap.state log rotate daily, doesnt affect the actual cache or clients getting content from cache right?  I need all the help i can to conserve bandwidth
                          serialdie
                          @kapara:
                          pfTop via SSH
                          Where do you get pflowd for pfsense from?
                          Is nether in the pkg list or the freebsd repo.
                          TIA!
                            serialdie
                            found it.
                            Thanks!
                            • L Offline
                              luke240778
                              What can i use to see what is actually happening as far as squid possibly downloading or something? I am having this issue more often now.. its becoming a problem to my clients.. for an unknown reason for times throughout the day, for hours at a time my WAN usage is right up at my 20mb limit..  Take a look at attachment, i am in need of assistance for sure..
                              problem.png_thumb
                                tommyboy180
                                Wow! Well if it were my installation I would go back to the basics and remove everything and slowly re-build over time. Try to eliminate potential causes of the issue.
                                Also, get a capture of that traffic so you can find out exactly what that is. If I had to guess without much insight to what is going on I would not eliminate p2p traffic.
                                -Tom Schaefer
                                • L Offline
                                  luke240778
                                  Thanks for that.. starting again and rebuilding from scratch is hard as i really rely on the build up squid cache that is on there (50gb or so)
                                  Wouldn't ptp traffic show up on my LAN interface (where all my clients are) as well as the LAN?  WHen th WAN is like you see in that screenshot, the LAN (clients) is never above say 3-4mb usage..
                                    tommyboy180
                                    True. I forgot that about your post. Let me run this by some of my colleagues at work and see if I can give you a better hint.
                                    -Tom Schaefer
                                      wallabybob
                                      In a pfSense console session run pftop to get dynamic display of current firewall states (connections). Type h too get a display of the options. The R option should sort connections on rate and that should give you some clues about who is using the bandwidth.
                                      • L Offline
                                        luke240778
                                        @tommyboy180:
                                        Thanks for this.. looking forward to what you come up with..
                                        • L Offline
                                          luke240778
                                          @wallabybob:
                                          I have done this, at a time when the WAN says 20mb usage, and below is what i see, i can't understand it well enough to see if it actually gives me an answer or not (i see alot of INBOUND traffic with port 127.0.0.1:3128 (squid Proxy Port).. is that my problem? and what uses that port?)
                                          Getting confused with what In and Out refer to here..
                                          pftop.png_thumb
                                            tommyboy180
                                            Squid uses 3128 by default.
                                            -Tom Schaefer
