    In need of help to solve a bandwidth issue
    61 Posts 11 Posters 20.6k Views
    • Cry HavokC Offline
      Cry Havok
      In and Out are interface related - so a download will generally be In on WAN and Out on LAN (and so on).
      • L Offline
        luke240778
        Right, just saw that in my squid config.  So, what i am not understanding is this… if it is possibly ptp traffic, wouldnt that show up on the Traffic Graph also on the LAN interface, where all my clients are connected?  This high WAN usage issue to me seems like i am leaking bandwidth somehow, somewhere.. cause the LAN interface is always quite low in usage, but just the WAN is max'd. Does that pftop output make any sense to you?
          Cry Havok
          Have you looked at the reverse DNS (rDNS) and WhoIS of the highest volume remote nodes? The top 2 I picked both related to Google services.
          What is 192.168.10.240, since it seems associated with some of the highest transfers, through Squid.
          • L Offline
            luke240778
            @Cry:
            192.168.10.240 is one of my clients.. who according is limited to maximum 2mb/1mb.. as are all my clients
            Here is a current snapshot of my pftop… currently my WAN is showing 20mb usage..  I have no idea what is going down... all my clients are limited via captive portal to 2mb, and are also limited on my AP (wireless cliente connecting via antenna).. when this shows 20mb usage, my LAN (192.168.10.0) is showing 4mb usage
            20mb.png_thumb
              Cry Havok
              Three of your top 4 lines refer to 65.54.93.42 (cds39.mia9.msecn.net.). I don't know what that is - does it make sense to you?
              • L Offline
                luke240778
                No.. not at all..  Currently it is chewing up 20mb.. and that IP is no longer there in the pftop output.
                • L Offline
                  luke240778
                  Also, i should add that this just became more confusing.. i thought it would be some clients doing alot of ptp or torrenting or something, but i just completely turned all the clients off for 10 minutes and the bandwidth never changes, was still max'd at 20mb with no one using the box..
                    Metu69salemi
                    Try to change admin passwords and disable outbound ssh connection for testing
                    • L Offline
                      luke240778
                      Ok, just changed passwords and disabled SSH.. will report back in a little while
                      • L Offline
                        luke240778
                        Ok, so its currently back up stuck at 20mb usage..  this just makes no sense.. the LAN traffic is only 2mb usage..  Can i have been hacked or something?  Is it even possible that squid or something else is using up all the bandwidth?
                          podilarius
                          @luke240778:
                          Did you try and disabling squid and see if that cuts the bandwidth down?
                          • L Offline
                            luke240778
                            Thats the only thing i havent already done.. as i am a little worried if this will delete my cache or something?  Cache is something that i really need running as i havent got a great deal of bandwidth..  If its ok to disable it and then re-enable it then i'll give it shot
                              podilarius
                              It has been a long time since I used squid. I don't think I remember if it clears it or not.
                              • L Offline
                                luke240778
                                Just quickly.. what do you mean by 'disable' squid?  I dont see a disable check bo like some other packages have.. do you mean just stop int binding to the interface? Mine currently binds to my LAN and OPT1 interface, and not my WAN interface..
                                  podilarius
                                  Sorry, just stopping it will disable it until reboot or until you start it again.
                                  • L Offline
                                    luke240778
                                    Any idea how to STOP it? i have just done it a few times via the dashboard 'Services" widget, but it keeps just turning itself back on..
                                      Cry Havok
                                      Stop it and then remove the package. That will certainly keep it stopped ;)
                                      • L Offline
                                        luke240778
                                        Um.. removing it is definately what i want to do.. i need squid running.. i am just trying to stop it so i can see if it is the problem, then i'll have to work out how to fix it..
                                        As far as i know, squid is the only way i can cache alot of my clients usage and save bandwidth, that i desperately need to.. cause the costs of Bandwidth here in Brazil is really high.. need all the help i can get to save on bandwidth
                                        • L Offline
                                          luke240778
                                          @luke240778:
                                          Um.. removing it is definately not what i want to do.. i need squid running.. i am just trying to stop it so i can see if it is the problem, then i'll have to work out how to fix it..
                                            podilarius
                                            There should be a disable or enable check box in the config. check or uncheck it depending, save, and then stop the service. Once BW has seen to gone down, or stay the same, then reverse the steps.
