    243 Posts 24 Posters 225.6k Views 1 Watching
    • X Offline
      xbipin
      lets just leave it to the developers to decide, what they can do is provide the drivers separately to install so every1 dont need to use this
      • V Offline
        vtas
        I have this issue and it occurs more frequently since updating to 2.0.3-RELEASE (i386).
        I doubt a switch is going to make any difference in my case because I am running pfsense in a VM that effectively has an always up (virtual) switch, connected to a physical Intel E1000 card port patched straight into a routerboard (all gear on battery) so I am not getting disconnected because of a layer 1 issue.
        I'm a bit lost at how to proceed. Running a script to tear down the interface and bring it back up if it's up and experiencing no throughput (but it is present) seems like the best bet
        • X Offline
          xbipin
          thats the only way to get back the link going, if u read few posts back, some1 did design a script for this and it actually worked, atleast to some extend
          y dont everyone add some amount to this so some1 can develop a fix for this, probably a newer driver might solve it
          • V Offline
            vtas
            @xbipin:
            Thanks for the tip about the script. How can the bounty be added to apart from just making a note in my post?
            • X Offline
              xbipin
              just make a post with ur amount, few of the developers r following this thread so they will know of it
                ronjns
                I had similar issue with FreeBSD 9.1 RELEASE and pppoe('8'). The fix was to 'enable echo' in ppp.conf.
                echo
                    Default: Disabled.  When this option is enabled, ppp will send
                    LCP ECHO requests to the peer at the frequency defined by
                    echoperiod''.  Note, LQR requests will supersede LCP ECHO     requests if enabled and negotiated.  See set lqrperiod'' below
                    for details.
                Prior to ppp version 3.4.2, echo'' was considered enabled if     lqr was enabled and negotiated, otherwise it was considered dis-     abled.  For the same behaviour, it is now necessary to enable
                    lqr echo'' rather than just ``enable lqr''.
                http://www.freebsd.org/cgi/man.cgi?query=ppp&sektion=8
                  senser
                  I am wondering if this thread is about fixing the issue that I have (excuse my ignorance, but this thread is quite long):
                  When I unplug the cable to my DSL modem (Alix, pfSense 2.1) and plug it back in, I cannot establish the pppoe connection again (a reboot will fix it, haven't tried anything else, sorry). If I disable the pppoe connection in pfSense prior to reconnecting the cable, I can establish the pppoe connection again.
                  We use the mighty pf, we cannot be fooled.
                  • X Offline
                    xbipin
                    any1 tried enabling echo if it solves it or no?
                    • E Offline
                      eri--
                      Ok coming back to this after some time.
                      I think i have solved the issue here and tomorrow snapshots should have a fix.
                      Can you test and let me know?
                      • X Offline
                        xbipin
                        ok ill try it out and revert back, can u post the link to the commit?
                        • E Offline
                          eri--
                          https://github.com/pfsense/pfsense-tools/commit/4d298135387ef551ccc6eff62a1705059956c64e
                          https://github.com/pfsense/pfsense/commit/9510780ffa41bf1b19989b418e9a356702ba5576
                          • X Offline
                            xbipin
                            brilliant, almost after 2.5 years its solved now, plz send me ur paypal id for payment in PM
                            • X Offline
                              xbipin
                              the bug has appeared in 2.2 RC again and pppoe wont reconenct at all untill u reboot it, log is the same, just endless loops of connection attempts
                              • E Offline
                                eri--
                                This should work as before or better in 2.2-RC++
                                • X Offline
                                  xbipin
                                  @ermal:
                                  well after the last changes u made the situation is same for me, if i unplug or modem goes down and up, then it wont connect at all in hours also, only way to make it connect is reboot.
                                  • X Offline
                                    xbipin
                                    here r the logs with the latest snap
                                    Jan 13 10:20:24 	ppp: [wan_link0] LCP: no reply to 2 echo request(s)
                                    Jan 13 10:20:34 	ppp: [wan_link0] LCP: no reply to 3 echo request(s)
                                    Jan 13 10:20:44 	ppp: [wan_link0] LCP: no reply to 4 echo request(s)
                                    Jan 13 10:20:54 	ppp: [wan_link0] LCP: no reply to 5 echo request(s)
                                    Jan 13 10:20:54 	ppp: [wan_link0] LCP: peer not responding to echo requests
                                    Jan 13 10:20:54 	ppp: [wan_link0] LCP: state change Opened --> Stopping
                                    Jan 13 10:20:54 	ppp: [wan_link0] Link: Leave bundle "wan"
                                    Jan 13 10:20:54 	ppp: [wan] Bundle: Status update: up 0 links, total bandwidth 9600 bps
                                    Jan 13 10:20:54 	ppp: [wan] IPCP: Close event
                                    Jan 13 10:20:54 	ppp: [wan] IPCP: state change Opened --> Closing
                                    Jan 13 10:20:54 	ppp: [wan] IPCP: SendTerminateReq #4
                                    Jan 13 10:20:54 	ppp: [wan] IPCP: LayerDown
                                    Jan 13 10:20:55 	ppp: [wan] IFACE: Delete route 0.0.0.0/0 2.48.4.1 failed: No such process
                                    Jan 13 10:20:55 	ppp: [wan] IFACE: Down event
                                    Jan 13 10:20:55 	ppp: [wan] IFACE: Rename interface pppoe0 to pppoe0
                                    Jan 13 10:20:55 	ppp: [wan] IPV6CP: Close event
                                    Jan 13 10:20:55 	ppp: [wan] IPV6CP: state change Stopped --> Closed
                                    Jan 13 10:20:55 	ppp: [wan] IPCP: Down event
                                    Jan 13 10:20:55 	ppp: [wan] IPCP: LayerFinish
                                    Jan 13 10:20:55 	ppp: [wan] Bundle: No NCPs left. Closing links...
                                    Jan 13 10:20:55 	ppp: [wan] IPCP: state change Closing --> Initial
                                    Jan 13 10:20:55 	ppp: [wan] IPV6CP: Down event
                                    Jan 13 10:20:55 	ppp: [wan] IPV6CP: state change Closed --> Initial
                                    Jan 13 10:20:55 	ppp: [wan_link0] LCP: SendTerminateReq #3
                                    Jan 13 10:20:55 	ppp: [wan_link0] LCP: LayerDown
                                    Jan 13 10:21:00 	ppp: [wan_link0] LCP: SendTerminateReq #4
                                    Jan 13 10:21:02 	ppp: [wan_link0] LCP: state change Stopping --> Stopped
                                    Jan 13 10:21:02 	ppp: [wan_link0] LCP: LayerFinish
                                    Jan 13 10:21:02 	ppp: [wan_link0] PPPoE: connection closed
                                    Jan 13 10:21:02 	ppp: [wan_link0] Link: DOWN event
                                    Jan 13 10:21:02 	ppp: [wan_link0] LCP: Down event
                                    Jan 13 10:21:02 	ppp: [wan_link0] LCP: state change Stopped --> Starting
                                    Jan 13 10:21:02 	ppp: [wan_link0] LCP: LayerStart
                                    Jan 13 10:21:02 	ppp: [wan_link0] Link: reconnection attempt 1 in 4 seconds
                                    the system log does show the interface a down and then later a linkup message but it just wont reconnect and more interesting is y does the below fail
                                    bear in mind that FTTH modem the isp has given here, when u connect the wan cable coming out of it to any machine, by default it wont get any ip at all, in windows it would try and then fail and revert to 169.x.x.x, the machine would just say cable connected but no ip on it, not even any private ip
                                    • E Offline
                                      eri--
                                      I am interested on your system log not your ppp logs.
                                      • X Offline
                                        xbipin
                                        here u go, included both the logs
                                        system log
                                        Jan 15 10:07:38 	syslogd: kernel boot file is /boot/kernel/kernel
                                        Jan 15 10:07:46 	kernel: vr1: link state changed to DOWN
                                        Jan 15 10:08:43 	check_reload_status: Restarting ipsec tunnels
                                        Jan 15 10:08:43 	check_reload_status: Restarting OpenVPN tunnels/interfaces
                                        Jan 15 10:08:43 	check_reload_status: Reloading filter
                                        Jan 15 10:08:46 	php-fpm[56184]: /rc.openvpn: OpenVPN: One or more OpenVPN tunnel endpoints may have changed its IP. Reloading endpoints that may use WAN.
                                        Jan 15 10:08:46 	php-fpm[56184]: /rc.openvpn: OpenVPN: Resync client1 ExpressVPN
                                        Jan 15 10:08:49 	php-fpm[56184]: /rc.openvpn: OpenVPN ID client1 PID 20721 still running, killing.
                                        Jan 15 10:08:49 	kernel: ovpnc1: link state changed to DOWN
                                        Jan 15 10:08:50 	check_reload_status: Reloading filter
                                        Jan 15 10:08:53 	php-fpm[41289]: /rc.dyndns.update: phpDynDNS (firewall.domain.com): No change in my IP address and/or 25 days has not passed. Not updating dynamic DNS entry.
                                        Jan 15 10:08:55 	php: rc.kill_states: rc.kill_states: Removing states for IP 86.99.125.32/32
                                        Jan 15 10:08:55 	check_reload_status: Rewriting resolv.conf
                                        Jan 15 10:08:59 	php-fpm[55844]: /rc.filter_configure_sync: Could not find IPv4 gateway for interface (wan).
                                        Jan 15 10:09:00 	php-fpm[55844]: /rc.filter_configure_sync: Could not find IPv4 gateway for interface (wan).
                                        Jan 15 10:09:02 	check_reload_status: Linkup starting vr1
                                        Jan 15 10:09:02 	kernel: vr1: link state changed to UP
                                        Jan 15 10:09:07 	php-fpm[56184]: /rc.filter_configure_sync: Could not find IPv4 gateway for interface (wan).
                                        Jan 15 10:09:08 	php-fpm[56184]: /rc.filter_configure_sync: Could not find IPv4 gateway for interface (wan).
                                        Jan 15 10:09:15 	check_reload_status: Restarting ipsec tunnels
                                        Jan 15 10:09:20 	check_reload_status: updating dyndns wan
                                        ppp logs
                                        Jan 15 10:08:34 	ppp: [wan_link0] LCP: no reply to 3 echo request(s)
                                        Jan 15 10:08:44 	ppp: [wan_link0] LCP: no reply to 4 echo request(s)
                                        Jan 15 10:08:54 	ppp: [wan_link0] LCP: no reply to 5 echo request(s)
                                        Jan 15 10:08:54 	ppp: [wan_link0] LCP: peer not responding to echo requests
                                        Jan 15 10:08:54 	ppp: [wan_link0] LCP: state change Opened --> Stopping
                                        Jan 15 10:08:54 	ppp: [wan_link0] Link: Leave bundle "wan"
                                        Jan 15 10:08:54 	ppp: [wan] Bundle: Status update: up 0 links, total bandwidth 9600 bps
                                        Jan 15 10:08:54 	ppp: [wan] IPCP: Close event
                                        Jan 15 10:08:54 	ppp: [wan] IPCP: state change Opened --> Closing
                                        Jan 15 10:08:54 	ppp: [wan] IPCP: SendTerminateReq #4
                                        Jan 15 10:08:54 	ppp: [wan] IPCP: LayerDown
                                        Jan 15 10:08:55 	ppp: [wan] IFACE: Delete route 0.0.0.0/0 2.48.4.1 failed: No such process
                                        Jan 15 10:08:55 	ppp: [wan] IFACE: Down event
                                        Jan 15 10:08:55 	ppp: [wan] IFACE: Rename interface pppoe0 to pppoe0
                                        Jan 15 10:08:55 	ppp: [wan] IPV6CP: Close event
                                        Jan 15 10:08:55 	ppp: [wan] IPV6CP: state change Stopped --> Closed
                                        Jan 15 10:08:55 	ppp: [wan] IPCP: Down event
                                        Jan 15 10:08:55 	ppp: [wan] IPCP: LayerFinish
                                        Jan 15 10:08:55 	ppp: [wan] Bundle: No NCPs left. Closing links...
                                        Jan 15 10:08:55 	ppp: [wan] IPCP: state change Closing --> Initial
                                        Jan 15 10:08:55 	ppp: [wan] IPV6CP: Down event
                                        Jan 15 10:08:55 	ppp: [wan] IPV6CP: state change Closed --> Initial
                                        Jan 15 10:08:55 	ppp: [wan_link0] LCP: SendTerminateReq #3
                                        Jan 15 10:08:55 	ppp: [wan_link0] LCP: LayerDown
                                        Jan 15 10:08:58 	ppp: [wan_link0] LCP: SendTerminateReq #4
                                        Jan 15 10:09:00 	ppp: [wan_link0] LCP: state change Stopping --> Stopped
                                        Jan 15 10:09:00 	ppp: [wan_link0] LCP: LayerFinish
                                        Jan 15 10:09:00 	ppp: [wan_link0] PPPoE: connection closed
                                        Jan 15 10:09:00 	ppp: [wan_link0] Link: DOWN event
                                        Jan 15 10:09:00 	ppp: [wan_link0] LCP: Down event
                                        Jan 15 10:09:00 	ppp: [wan_link0] LCP: state change Stopped --> Starting
                                        Jan 15 10:09:00 	ppp: [wan_link0] LCP: LayerStart
                                        Jan 15 10:09:00 	ppp: [wan_link0] Link: reconnection attempt 1 in 1 seconds
                                        Jan 15 10:09:01 	ppp: [wan_link0] Link: reconnection attempt 1
                                        Jan 15 10:09:01 	ppp: [wan_link0] PPPoE: Connecting to ''
                                        Jan 15 10:09:05 	ppp: Multi-link PPP daemon for FreeBSD
                                        Jan 15 10:09:05 	ppp: process 67927 started, version 5.7 (root@pfsense-22-i386-builder 13:22 18-Nov-2014)
                                        Jan 15 10:09:05 	ppp: caught fatal signal TERM
                                        Jan 15 10:09:05 	ppp: [wan] IFACE: Close event
                                        Jan 15 10:09:05 	ppp: [wan] IPCP: Close event
                                        Jan 15 10:09:05 	ppp: [wan] IPV6CP: Close event
                                        Jan 15 10:09:05 	ppp: waiting for process 6370 to die...
                                        Jan 15 10:09:06 	ppp: waiting for process 6370 to die...
                                        Jan 15 10:09:07 	ppp: [wan] Bundle: Shutdown
                                        Jan 15 10:09:07 	ppp: [wan_link0] Link: Shutdown
                                        Jan 15 10:09:07 	ppp: process 6370 terminated
                                        Jan 15 10:09:07 	ppp: web: web is not running
                                        Jan 15 10:09:07 	ppp: [wan] Bundle: Interface ng0 created
                                        Jan 15 10:09:07 	ppp: [wan_link0] Link: OPEN event
                                        Jan 15 10:09:07 	ppp: [wan_link0] LCP: Open event
                                        Jan 15 10:09:07 	ppp: [wan_link0] LCP: state change Initial --> Starting
                                        Jan 15 10:09:07 	ppp: [wan_link0] LCP: LayerStart
                                        Jan 15 10:09:07 	ppp: [wan_link0] PPPoE: Connecting to ''
                                        Jan 15 10:09:16 	ppp: [wan_link0] PPPoE connection timeout after 9 seconds
                                        Jan 15 10:09:16 	ppp: [wan_link0] Link: DOWN event
                                        Jan 15 10:09:16 	ppp: [wan_link0] LCP: Down event
                                        Jan 15 10:09:16 	ppp: [wan_link0] Link: reconnection attempt 1 in 3 seconds
                                        Jan 15 10:09:19 	ppp: [wan_link0] Link: reconnection attempt 1
                                        Jan 15 10:09:19 	ppp: [wan_link0] PPPoE: Connecting to ''
                                        Jan 15 10:09:28 	ppp: [wan_link0] PPPoE connection timeout after 9 seconds
                                        Jan 15 10:09:28 	ppp: [wan_link0] Link: DOWN event
                                        Jan 15 10:09:28 	ppp: [wan_link0] LCP: Down event
                                        Jan 15 10:09:28 	ppp: [wan_link0] Link: reconnection attempt 2 in 4 seconds
                                        Jan 15 10:09:32 	ppp: [wan_link0] Link: reconnection attempt 2
                                        Jan 15 10:09:32 	ppp: [wan_link0] PPPoE: Connecting to ''
                                        Jan 15 10:09:41 	ppp: [wan_link0] PPPoE connection timeout after 9 seconds
                                        Jan 15 10:09:41 	ppp: [wan_link0] Link: DOWN event
                                        Jan 15 10:09:41 	ppp: [wan_link0] LCP: Down event
                                        Jan 15 10:09:41 	ppp: [wan_link0] Link: reconnection attempt 3 in 2 seconds
                                        Jan 15 10:09:43 	ppp: [wan_link0] Link: reconnection attempt 3
                                        Jan 15 10:09:43 	ppp: [wan_link0] PPPoE: Connecting to ''
                                        Jan 15 10:09:52 	ppp: [wan_link0] PPPoE connection timeout after 9 seconds
                                        Jan 15 10:09:52 	ppp: [wan_link0] Link: DOWN event
                                        Jan 15 10:09:52 	ppp: [wan_link0] LCP: Down event
                                        Jan 15 10:09:52 	ppp: [wan_link0] Link: reconnection attempt 4 in 4 seconds
                                        Jan 15 10:09:56 	ppp: [wan_link0] Link: reconnection attempt 4
                                        Jan 15 10:09:56 	ppp: [wan_link0] PPPoE: Connecting to ''
                                        Jan 15 10:10:05 	ppp: [wan_link0] PPPoE connection timeout after 9 seconds
                                        Jan 15 10:10:05 	ppp: [wan_link0] Link: DOWN event
                                        Jan 15 10:10:05 	ppp: [wan_link0] LCP: Down event
                                        Jan 15 10:10:05 	ppp: [wan_link0] Link: reconnection attempt 5 in 2 seconds
                                        • E Offline
                                          eri--
                                          From what i see seems mpd does not exit and the new instance is started.
                                          Probably need modification to kill the first the run the other one.
                                          • X Offline
                                            xbipin
                                            is there some easy fix or patch which i can test for now?
