    243 Posts 24 Posters 225.8k Views 1 Watching
    • E Offline
      eri--
      diff --git a/etc/inc/interfaces.inc b/etc/inc/interfaces.inc
      index cd709a9..e388498 100644
      --- a/etc/inc/interfaces.inc
      +++ b/etc/inc/interfaces.inc
      @@ -1810,6 +1810,8 @@ EOD;
              /* fire up mpd */
      +       if (isvalidpid("{$g['varrun_path']}/" . escapeshellarg($ppp['type']) . "_{$interface}.pid"))
      +               killbypid("{$g['varrun_path']}/" . escapeshellarg($ppp['type']) . "_{$interface}.pid");
              mwexec("/usr/local/sbin/mpd5 -b -k -d {$g['varetc_path']} -f mpd_{$interface}.conf -p {$g['varrun_path']}/" .
                      escapeshellarg($ppp['type']) . "_{$interface}.pid -s ppp " . escapeshellarg($ppp['type']) . "client");
      • X Offline
        xbipin
        well the patch works in one situation and doesnt in other, suppose if ftth modem is up and running and i pull wan plug cable from it to pfsense and then replug after sometime then connection comes back up, the other situation in which if i reset the ftth modem or power off that and repower on then while the modem is initializing, after in a few seconds the interface shows linkup and then mpd starts reconnecting but then it goes on for ever and never reconnects.
        in summary, if modem is up and running and interface goes through link down and link up then it connects fine but suppose if the modem is rebooting then the interface link down and link up happens soon enough and mpd tries to reconnect but till then the modem isnt yet completely up and in that mpd never reconnects, even then when modem is completely up and i pull wan cable and reconnect then also it never reconnects unless pfsense is rebooted.
        • X Offline
          xbipin
          i think mpd doesnt completely exit before a new one is created or something like that, probably it needs to completely exit and detach from interface before a new one is created
          system log
          Jan 16 13:39:43 	kernel: vr1: link state changed to DOWN
          Jan 16 13:40:42 	check_reload_status: updating dyndns WAN
          Jan 16 13:40:42 	check_reload_status: Restarting ipsec tunnels
          Jan 16 13:40:42 	check_reload_status: Restarting OpenVPN tunnels/interfaces
          Jan 16 13:40:42 	check_reload_status: Reloading filter
          Jan 16 13:40:44 	php-fpm[4437]: /rc.openvpn: OpenVPN: One or more OpenVPN tunnel endpoints may have changed its IP. Reloading endpoints that may use WAN.
          Jan 16 13:40:44 	php-fpm[4437]: /rc.openvpn: OpenVPN: Resync client1 ExpressVPN
          Jan 16 13:40:48 	php-fpm[4437]: /rc.openvpn: OpenVPN ID client1 PID 20369 still running, killing.
          Jan 16 13:40:48 	kernel: ovpnc1: link state changed to DOWN
          Jan 16 13:40:48 	php: rc.kill_states: rc.kill_states: Removing states for IP 2.48.5.170/32
          Jan 16 13:40:48 	check_reload_status: Reloading filter
          Jan 16 13:40:48 	check_reload_status: Rewriting resolv.conf
          Jan 16 13:40:55 	php-fpm[4374]: /rc.filter_configure_sync: Could not find IPv4 gateway for interface (wan).
          Jan 16 13:40:56 	php-fpm[4374]: /rc.filter_configure_sync: Could not find IPv4 gateway for interface (wan).
          Jan 16 13:40:59 	kernel: vr1: link state changed to UP
          Jan 16 13:40:59 	check_reload_status: Linkup starting vr1
          Jan 16 13:41:03 	php-fpm[4437]: /rc.filter_configure_sync: Could not find IPv4 gateway for interface (wan).
          Jan 16 13:41:04 	php-fpm[4437]: /rc.filter_configure_sync: Could not find IPv4 gateway for interface (wan).
          Jan 16 13:41:11 	check_reload_status: Restarting ipsec tunnels
          Jan 16 13:41:16 	check_reload_status: updating dyndns wan
          ppp log
          Jan 16 13:40:17 	ppp: [wan_link0] LCP: no reply to 2 echo request(s)
          Jan 16 13:40:27 	ppp: [wan_link0] LCP: no reply to 3 echo request(s)
          Jan 16 13:40:37 	ppp: [wan_link0] LCP: no reply to 4 echo request(s)
          Jan 16 13:40:47 	ppp: [wan_link0] LCP: no reply to 5 echo request(s)
          Jan 16 13:40:47 	ppp: [wan_link0] LCP: peer not responding to echo requests
          Jan 16 13:40:47 	ppp: [wan_link0] LCP: state change Opened --> Stopping
          Jan 16 13:40:47 	ppp: [wan_link0] Link: Leave bundle "wan"
          Jan 16 13:40:47 	ppp: [wan] Bundle: Status update: up 0 links, total bandwidth 9600 bps
          Jan 16 13:40:47 	ppp: [wan] IPCP: Close event
          Jan 16 13:40:47 	ppp: [wan] IPCP: state change Opened --> Closing
          Jan 16 13:40:47 	ppp: [wan] IPCP: SendTerminateReq #4
          Jan 16 13:40:47 	ppp: [wan] IPCP: LayerDown
          Jan 16 13:40:48 	ppp: [wan] IFACE: Delete route 0.0.0.0/0 2.48.4.1 failed: No such process
          Jan 16 13:40:48 	ppp: [wan] IFACE: Down event
          Jan 16 13:40:48 	ppp: [wan] IFACE: Rename interface pppoe0 to pppoe0
          Jan 16 13:40:48 	ppp: [wan] IPV6CP: Close event
          Jan 16 13:40:48 	ppp: [wan] IPV6CP: state change Stopped --> Closed
          Jan 16 13:40:48 	ppp: [wan] IPCP: Down event
          Jan 16 13:40:48 	ppp: [wan] IPCP: LayerFinish
          Jan 16 13:40:48 	ppp: [wan] Bundle: No NCPs left. Closing links...
          Jan 16 13:40:48 	ppp: [wan] IPCP: state change Closing --> Initial
          Jan 16 13:40:48 	ppp: [wan] IPV6CP: Down event
          Jan 16 13:40:48 	ppp: [wan] IPV6CP: state change Closed --> Initial
          Jan 16 13:40:48 	ppp: [wan_link0] LCP: SendTerminateReq #3
          Jan 16 13:40:48 	ppp: [wan_link0] LCP: LayerDown
          Jan 16 13:40:52 	ppp: [wan_link0] LCP: SendTerminateReq #4
          Jan 16 13:40:54 	ppp: [wan_link0] LCP: state change Stopping --> Stopped
          Jan 16 13:40:54 	ppp: [wan_link0] LCP: LayerFinish
          Jan 16 13:40:54 	ppp: [wan_link0] PPPoE: connection closed
          Jan 16 13:40:54 	ppp: [wan_link0] Link: DOWN event
          Jan 16 13:40:54 	ppp: [wan_link0] LCP: Down event
          Jan 16 13:40:54 	ppp: [wan_link0] LCP: state change Stopped --> Starting
          Jan 16 13:40:54 	ppp: [wan_link0] LCP: LayerStart
          Jan 16 13:40:54 	ppp: [wan_link0] Link: reconnection attempt 1 in 1 seconds
          Jan 16 13:40:55 	ppp: [wan_link0] Link: reconnection attempt 1
          Jan 16 13:40:55 	ppp: [wan_link0] PPPoE: Connecting to ''
          Jan 16 13:41:01 	ppp: Multi-link PPP daemon for FreeBSD
          Jan 16 13:41:01 	ppp: process 14494 started, version 5.7 (root@pfsense-22-i386-builder 13:22 18-Nov-2014)
          Jan 16 13:41:01 	ppp: caught fatal signal TERM
          Jan 16 13:41:01 	ppp: [wan] IFACE: Close event
          Jan 16 13:41:01 	ppp: [wan] IPCP: Close event
          Jan 16 13:41:01 	ppp: [wan] IPV6CP: Close event
          Jan 16 13:41:01 	ppp: waiting for process 5956 to die...
          Jan 16 13:41:02 	ppp: waiting for process 5956 to die...
          Jan 16 13:41:03 	ppp: [wan] Bundle: Shutdown
          Jan 16 13:41:03 	ppp: [wan_link0] Link: Shutdown
          Jan 16 13:41:03 	ppp: process 5956 terminated
          Jan 16 13:41:03 	ppp: web: web is not running
          Jan 16 13:41:03 	ppp: [wan] Bundle: Interface ng0 created
          Jan 16 13:41:03 	ppp: [wan_link0] Link: OPEN event
          Jan 16 13:41:03 	ppp: [wan_link0] LCP: Open event
          Jan 16 13:41:03 	ppp: [wan_link0] LCP: state change Initial --> Starting
          Jan 16 13:41:03 	ppp: [wan_link0] LCP: LayerStart
          Jan 16 13:41:03 	ppp: [wan_link0] PPPoE: Connecting to ''
          Jan 16 13:41:12 	ppp: [wan_link0] PPPoE connection timeout after 9 seconds
          Jan 16 13:41:12 	ppp: [wan_link0] Link: DOWN event
          Jan 16 13:41:12 	ppp: [wan_link0] LCP: Down event
          Jan 16 13:41:12 	ppp: [wan_link0] Link: reconnection attempt 1 in 4 seconds
          Jan 16 13:41:16 	ppp: [wan_link0] Link: reconnection attempt 1
          Jan 16 13:41:16 	ppp: [wan_link0] PPPoE: Connecting to ''
          Jan 16 13:41:25 	ppp: [wan_link0] PPPoE connection timeout after 9 seconds
          Jan 16 13:41:25 	ppp: [wan_link0] Link: DOWN event
          Jan 16 13:41:25 	ppp: [wan_link0] LCP: Down event
          Jan 16 13:41:25 	ppp: [wan_link0] Link: reconnection attempt 2 in 4 seconds
          Jan 16 13:41:29 	ppp: [wan_link0] Link: reconnection attempt 2
          Jan 16 13:41:29 	ppp: [wan_link0] PPPoE: Connecting to ''
          Jan 16 13:41:38 	ppp: [wan_link0] PPPoE connection timeout after 9 seconds
          Jan 16 13:41:38 	ppp: [wan_link0] Link: DOWN event
          Jan 16 13:41:38 	ppp: [wan_link0] LCP: Down event
          Jan 16 13:41:38 	ppp: [wan_link0] Link: reconnection attempt 3 in 3 seconds
          Jan 16 13:41:41 	ppp: [wan_link0] Link: reconnection attempt 3
          Jan 16 13:41:41 	ppp: [wan_link0] PPPoE: Connecting to ''
          Jan 16 13:41:50 	ppp: [wan_link0] PPPoE connection timeout after 9 seconds
          Jan 16 13:41:50 	ppp: [wan_link0] Link: DOWN event
          Jan 16 13:41:50 	ppp: [wan_link0] LCP: Down event
          Jan 16 13:41:50 	ppp: [wan_link0] Link: reconnection attempt 4 in 4 seconds
          Jan 16 13:41:54 	ppp: [wan_link0] Link: reconnection attempt 4
          Jan 16 13:41:54 	ppp: [wan_link0] PPPoE: Connecting to ''
          Jan 16 13:43:43 	ppp: [wan_link0] Link: DOWN event
          Jan 16 13:43:43 	ppp: [wan_link0] LCP: Down event
          Jan 16 13:43:43 	ppp: [wan_link0] Link: reconnection attempt 14 in 1 seconds
          Jan 16 13:43:44 	ppp: [wan_link0] Link: reconnection attempt 14
          Jan 16 13:43:44 	ppp: [wan_link0] PPPoE: Connecting to ''
          Jan 16 13:43:53 	ppp: [wan_link0] PPPoE connection timeout after 9 seconds
          Jan 16 13:43:53 	ppp: [wan_link0] Link: DOWN event
          Jan 16 13:43:53 	ppp: [wan_link0] LCP: Down event
          Jan 16 13:43:53 	ppp: [wan_link0] Link: reconnection attempt 15 in 1 seconds
          Jan 16 13:43:54 	ppp: [wan_link0] Link: reconnection attempt 15
          Jan 16 13:43:54 	ppp: [wan_link0] PPPoE: Connecting to ''
          Jan 16 13:44:03 	ppp: [wan_link0] PPPoE connection timeout after 9 seconds
          Jan 16 13:44:03 	ppp: [wan_link0] Link: DOWN event
          Jan 16 13:44:03 	ppp: [wan_link0] LCP: Down event
          Jan 16 13:44:03 	ppp: [wan_link0] Link: reconnection attempt 16 in 4 seconds
          Jan 16 13:44:07 	ppp: [wan_link0] Link: reconnection attempt 16
          Jan 16 13:44:07 	ppp: [wan_link0] PPPoE: Connecting to ''
          Jan 16 13:44:16 	ppp: [wan_link0] PPPoE connection timeout after 9 seconds
          Jan 16 13:44:16 	ppp: [wan_link0] Link: DOWN event
          Jan 16 13:44:16 	ppp: [wan_link0] LCP: Down event
          Jan 16 13:44:16 	ppp: [wan_link0] Link: reconnection attempt 17 in 2 seconds
          Jan 16 13:44:18 	ppp: [wan_link0] Link: reconnection attempt 17
          Jan 16 13:44:18 	ppp: [wan_link0] PPPoE: Connecting to ''
          • E Offline
            eri--
            Try putting a sleep(5) after the killbypid call.
            • X Offline
              xbipin
              @ermal:
              ill try that but i think the if statement doesnt come out true so probably its not killing mpd because the logs appear same before and after the patch plus even with modem up  after some while and i try cable unplug and replug it still wont work
              • X Offline
                xbipin
                i tried sleep as well as that if statement i put in some logging and it seems that if statement never turns out to be true so the kill command isnt executed
                  doktornotor Banned
                  @xbipin:
                  i tried sleep as well as that if statement i put in some logging and it seems that if statement never turns out to be true so the kill command isnt exucuted
                  Did you try leaving out the PID check and running sigkillbyname() or killbyname() instead? (Don't think checking PIDs is the best idea around in similar messy state.)
                  • X Offline
                    xbipin
                    @doktornotor:
                    @xbipin:
                    can u provide a replacement line for the below as im not aware of the possible functions created
                      doktornotor Banned
                      You can try
                      killbyname("mpd5");
                      or
                      sigkillbyname("mpd5", "TERM");
                      or
                      sigkillbyname("mpd5", "KILL");
                      • X Offline
                        xbipin
                        tried all 3 but once modem is rebooted and up and running, nothing helps, tried unplugging wan cable also with each of the commands but all still same, only get it to work is reboot pfsense
                        there is something that happens at reboot which makes it reconnect that doesnt happen when modem goes down and comes up again, probably the nic powering down and up makes it successfully connect at pfsense reboot. it would be great to disable the nic using software and then enabling it
                          doktornotor Banned
                          So… is that command executed at all? (You mentioned you tried logging.)
                          • X Offline
                            xbipin
                            i removed the logging and put in the command, im assuming its running it because i see the interface going down and up a multiple times now, no idea if thats supposed to happen
                              doktornotor Banned
                              Well, so… put the logging back? :) (That, and adding the sleep in between...)
                              • X Offline
                                xbipin
                                tried it and that command is executed but it seems somewhere else something is creating another mpd instance or something like that, also in system log i get messages like some package is already running so not starting another instance so i believe that command is doing few other bad things than actually doing good because the situation still is same, it wont reconnect
                                  doktornotor Banned
                                  @xbipin:
                                  Perhaps we are finally getting somewhere here. Posting the real logs could help.
                                  • X Offline
                                    xbipin
                                    the part about some other mpd starting is actually the netgraph thing which has multiple instances, ill try some more and get the logs shortly as this is a production box so need to get some work done for now
                                    • X Offline
                                      xbipin
                                      here u go
                                      system log
                                      Jan 17 14:38:16 	syslogd: kernel boot file is /boot/kernel/kernel
                                      Jan 17 14:38:42 	kernel: vr1: link state changed to DOWN
                                      Jan 17 14:39:29 	check_reload_status: updating dyndns WAN
                                      Jan 17 14:39:29 	check_reload_status: Restarting ipsec tunnels
                                      Jan 17 14:39:29 	check_reload_status: Restarting OpenVPN tunnels/interfaces
                                      Jan 17 14:39:29 	check_reload_status: Reloading filter
                                      Jan 17 14:39:33 	php-fpm[77652]: /rc.openvpn: OpenVPN: One or more OpenVPN tunnel endpoints may have changed its IP. Reloading endpoints that may use WAN.
                                      Jan 17 14:39:33 	php-fpm[77652]: /rc.openvpn: OpenVPN: Resync client1 ExpressVPN
                                      Jan 17 14:39:33 	php-fpm[74920]: /rc.dyndns.update: phpDynDNS (firewall.domain.com): No change in my IP address and/or 25 days has not passed. Not updating dynamic DNS entry.
                                      Jan 17 14:39:33 	check_reload_status: Reloading filter
                                      Jan 17 14:39:33 	kernel: ovpnc1: link state changed to DOWN
                                      Jan 17 14:39:49 	php: rc.kill_states: rc.kill_states: Removing states for IP 86.99.127.163/32
                                      Jan 17 14:39:49 	check_reload_status: Rewriting resolv.conf
                                      Jan 17 14:39:51 	php-fpm[74920]: /rc.filter_configure_sync: Could not find IPv4 gateway for interface (wan).
                                      Jan 17 14:39:57 	check_reload_status: Linkup starting vr1
                                      Jan 17 14:39:57 	kernel: vr1: link state changed to UP
                                      Jan 17 14:39:59 	php-fpm[77522]: /rc.linkup: REACHED HERE BEFORE KILL COMMAND AND SLEEP
                                      Jan 17 14:40:04 	php-fpm[77522]: /rc.linkup: REACHED HERE AFTER KILL COMMAND AND SLEEP
                                      Jan 17 14:40:14 	check_reload_status: Restarting ipsec tunnels
                                      Jan 17 14:40:19 	check_reload_status: updating dyndns wan
                                      ppp log
                                      Jan 17 14:39:18 	ppp: [wan_link0] LCP: no reply to 2 echo request(s)
                                      Jan 17 14:39:28 	ppp: [wan_link0] LCP: no reply to 3 echo request(s)
                                      Jan 17 14:39:38 	ppp: [wan_link0] LCP: no reply to 4 echo request(s)
                                      Jan 17 14:39:48 	ppp: [wan_link0] LCP: no reply to 5 echo request(s)
                                      Jan 17 14:39:48 	ppp: [wan_link0] LCP: peer not responding to echo requests
                                      Jan 17 14:39:48 	ppp: [wan_link0] LCP: state change Opened --> Stopping
                                      Jan 17 14:39:48 	ppp: [wan_link0] Link: Leave bundle "wan"
                                      Jan 17 14:39:48 	ppp: [wan] Bundle: Status update: up 0 links, total bandwidth 9600 bps
                                      Jan 17 14:39:48 	ppp: [wan] IPCP: Close event
                                      Jan 17 14:39:48 	ppp: [wan] IPCP: state change Opened --> Closing
                                      Jan 17 14:39:48 	ppp: [wan] IPCP: SendTerminateReq #4
                                      Jan 17 14:39:48 	ppp: [wan] IPCP: LayerDown
                                      Jan 17 14:39:49 	ppp: [wan] IFACE: Delete route 0.0.0.0/0 2.48.4.1 failed: No such process
                                      Jan 17 14:39:49 	ppp: [wan] IFACE: Down event
                                      Jan 17 14:39:49 	ppp: [wan] IFACE: Rename interface pppoe0 to pppoe0
                                      Jan 17 14:39:49 	ppp: [wan] IPV6CP: Close event
                                      Jan 17 14:39:49 	ppp: [wan] IPV6CP: state change Stopped --> Closed
                                      Jan 17 14:39:49 	ppp: [wan] IPCP: Down event
                                      Jan 17 14:39:49 	ppp: [wan] IPCP: LayerFinish
                                      Jan 17 14:39:49 	ppp: [wan] Bundle: No NCPs left. Closing links...
                                      Jan 17 14:39:49 	ppp: [wan] IPCP: state change Closing --> Initial
                                      Jan 17 14:39:49 	ppp: [wan] IPV6CP: Down event
                                      Jan 17 14:39:49 	ppp: [wan] IPV6CP: state change Closed --> Initial
                                      Jan 17 14:39:49 	ppp: [wan_link0] LCP: SendTerminateReq #3
                                      Jan 17 14:39:49 	ppp: [wan_link0] LCP: LayerDown
                                      Jan 17 14:39:52 	ppp: [wan_link0] LCP: SendTerminateReq #4
                                      Jan 17 14:39:54 	ppp: [wan_link0] LCP: state change Stopping --> Stopped
                                      Jan 17 14:39:54 	ppp: [wan_link0] LCP: LayerFinish
                                      Jan 17 14:39:54 	ppp: [wan_link0] PPPoE: connection closed
                                      Jan 17 14:39:54 	ppp: [wan_link0] Link: DOWN event
                                      Jan 17 14:39:54 	ppp: [wan_link0] LCP: Down event
                                      Jan 17 14:39:54 	ppp: [wan_link0] LCP: state change Stopped --> Starting
                                      Jan 17 14:39:54 	ppp: [wan_link0] LCP: LayerStart
                                      Jan 17 14:39:54 	ppp: [wan_link0] Link: reconnection attempt 1 in 3 seconds
                                      Jan 17 14:39:57 	ppp: [wan_link0] Link: reconnection attempt 1
                                      Jan 17 14:39:57 	ppp: [wan_link0] PPPoE: Connecting to ''
                                      Jan 17 14:40:04 	ppp: Multi-link PPP daemon for FreeBSD
                                      Jan 17 14:40:04 	ppp: process 91898 started, version 5.7 (root@pfsense-22-i386-builder 13:22 18-Nov-2014)
                                      Jan 17 14:40:04 	ppp: web: web is not running
                                      Jan 17 14:40:04 	ppp: [wan] Bundle: Interface ng1 created
                                      Jan 17 14:40:04 	ppp: [wan] IFACE: ioctl(ng1, SIOCSIFNAME): File exists
                                      Jan 17 14:40:04 	ppp: mpd_wan.conf:11: Error in 'set iface name pppoe0'
                                      Jan 17 14:40:04 	ppp: [wan_link0] Link: OPEN event
                                      Jan 17 14:40:04 	ppp: [wan_link0] LCP: Open event
                                      Jan 17 14:40:04 	ppp: [wan_link0] LCP: state change Initial --> Starting
                                      Jan 17 14:40:04 	ppp: [wan_link0] LCP: LayerStart
                                      Jan 17 14:40:04 	ppp: [wan_link0] PPPoE: Connecting to ''
                                      Jan 17 14:40:13 	ppp: [wan_link0] PPPoE connection timeout after 9 seconds
                                      Jan 17 14:40:13 	ppp: [wan_link0] Link: DOWN event
                                      Jan 17 14:40:13 	ppp: [wan_link0] LCP: Down event
                                      Jan 17 14:40:13 	ppp: [wan_link0] Link: reconnection attempt 1 in 4 seconds
                                      Jan 17 14:40:17 	ppp: [wan_link0] Link: reconnection attempt 1
                                      Jan 17 14:40:17 	ppp: [wan_link0] PPPoE: Connecting to ''
                                      Jan 17 14:40:26 	ppp: [wan_link0] PPPoE connection timeout after 9 seconds
                                      Jan 17 14:40:26 	ppp: [wan_link0] Link: DOWN event
                                      Jan 17 14:40:26 	ppp: [wan_link0] LCP: Down event
                                      Jan 17 14:40:26 	ppp: [wan_link0] Link: reconnection attempt 2 in 2 seconds
                                      Jan 17 14:40:28 	ppp: [wan_link0] Link: reconnection attempt 2
                                      Jan 17 14:40:28 	ppp: [wan_link0] PPPoE: Connecting to ''
                                      Jan 17 14:40:37 	ppp: [wan_link0] PPPoE connection timeout after 9 seconds
                                      Jan 17 14:40:37 	ppp: [wan_link0] Link: DOWN event
                                      Jan 17 14:40:37 	ppp: [wan_link0] LCP: Down event
                                      Jan 17 14:40:37 	ppp: [wan_link0] Link: reconnection attempt 3 in 2 seconds
                                      Jan 17 14:40:39 	ppp: [wan_link0] Link: reconnection attempt 3
                                      Jan 17 14:40:39 	ppp: [wan_link0] PPPoE: Connecting to ''
                                      Jan 17 14:40:48 	ppp: [wan_link0] PPPoE connection timeout after 9 seconds
                                      Jan 17 14:40:48 	ppp: [wan_link0] Link: DOWN event
                                      Jan 17 14:40:48 	ppp: [wan_link0] LCP: Down event
                                      Jan 17 14:40:48 	ppp: [wan_link0] Link: reconnection attempt 4 in 3 seconds
                                      Jan 17 14:40:51 	ppp: [wan_link0] Link: reconnection attempt 4
                                      Jan 17 14:40:51 	ppp: [wan_link0] PPPoE: Connecting to ''
                                      Jan 17 14:41:00 	ppp: [wan_link0] PPPoE connection timeout after 9 seconds
                                      Jan 17 14:41:00 	ppp: [wan_link0] Link: DOWN event
                                      Jan 17 14:41:00 	ppp: [wan_link0] LCP: Down event
                                      Jan 17 14:41:00 	ppp: [wan_link0] Link: reconnection attempt 5 in 1 seconds
                                      Jan 17 14:41:01 	ppp: [wan_link0] Link: reconnection attempt 5
                                      Jan 17 14:41:01 	ppp: [wan_link0] PPPoE: Connecting to ''
                                      Jan 17 14:41:10 	ppp: [wan_link0] PPPoE connection timeout after 9 seconds
                                      Jan 17 14:41:10 	ppp: [wan_link0] Link: DOWN event
                                      Jan 17 14:41:10 	ppp: [wan_link0] LCP: Down event
                                      Jan 17 14:41:10 	ppp: [wan_link0] Link: reconnection attempt 6 in 1 seconds
                                      Jan 17 14:41:11 	ppp: [wan_link0] Link: reconnection attempt 6
                                      Jan 17 14:41:11 	ppp: [wan_link0] PPPoE: Connecting to ''
                                      Jan 17 14:41:20 	ppp: [wan_link0] PPPoE connection timeout after 9 seconds
                                      Jan 17 14:41:20 	ppp: [wan_link0] Link: DOWN event
                                      Jan 17 14:41:20 	ppp: [wan_link0] LCP: Down event
                                      Jan 17 14:41:20 	ppp: [wan_link0] Link: reconnection attempt 7 in 3 seconds
                                      Jan 17 14:41:23 	ppp: [wan_link0] Link: reconnection attempt 7
                                      Jan 17 14:41:23 	ppp: [wan_link0] PPPoE: Connecting to ''
                                      Jan 17 14:41:32 	ppp: [wan_link0] PPPoE connection timeout after 9 seconds
                                      Jan 17 14:41:32 	ppp: [wan_link0] Link: DOWN event
                                      Jan 17 14:41:32 	ppp: [wan_link0] LCP: Down event
                                      Jan 17 14:41:32 	ppp: [wan_link0] Link: reconnection attempt 8 in 4 seconds
                                      the part about netgraph in ppp log
                                      • E Offline
                                        eri--
                                        Probably you get the error about the name since pfSense names itself the iface.
                                        Since mpd5 latest has that included inside probably need to check removing the name.
                                        • X Offline
                                          xbipin
                                          inspite of that error, pppoe still doesnt reconnect, probably tearing down the interface and bringing it back up using a down and up command would solve this.
                                          • E Offline
                                            esseebee
                                            I know all of the network professionals are going to roll their eyes at this question.  So, forgive my ignorance.  Would a work around be to put my ADSL modem back into router mode, then put my Pfsense firewall in the DMZ with a second public IP address on it?  This would allow the modem to authenticate with PPPoE without affecting anything else.  Please be gentle with your thoughts  ;D
