Help with Multi LAN on single WAN
I have 3 NICs.
1x Wan
1x Lan - 192.168.0.x / 24
1x Opt -192.168.1.x /24 <- using for lan.Lan works fine. i can ping and surf
On the Opt NIC, on the 192.168.2.x /24
-dhcp server enabled
-left gateway to blank (so that it defaults to the default, which is what i left for the Lan)OPT hands out dhcp addresses fine. but cannot get out, ping , or access 192.168.1.x /24
Am i doing something wrong here?
Have you created an outgoing firewall rule for your OPT1 network? At the very least, if you want to let everything through, you'll want to put an allow all outgoing traffic rule in.
I did not know i needed to do that.
But that did the Trick!
Thanks!!
