    Videos and audio not working.. Help plz!!
    24 Posts 3 Posters 26.5k Views
      You need to have the new rules corresponding to the groups at the top of the list since the firewall matches rules on a top down basis.
      It would be a good idea to have a default rule below these to catch anything that isn't matched. You can use the default gateway for this or a loadbalancing gateway.
      Does it look like this is working?
        rohbawa
        Its working ))) Thanks Steve … I am really thank full to you and this forum ... I never expected this type of response ...
        I have implemented the setup partially ... just for now 2 WAN .. actually I couldn't sort out the IP ... I need a little a time for that  may by the end of the today I will manage implement the setup ...
        and other three WANs are working on the old Load Balancing group ...
        One more thing ... I asked you about the configuration of my pfsense earlier that can it handle the through put of 250 Mbps (in other topic) ... you said yes
        But whenever I go to speedtest ... it never crosses 135 Mbps (usually around 120 Mbps) ... is it normal for speedtest .... ( I am using cat 5e wire for gigabit link to GBswitch)
          I have read that speedtest.net does not give an accurate result above 100Mbps but I am unable to test that with my two WANs (20Mb and 40Mb). I can say that it uses both my connections and gives a value usually around 56Mb.
          You can test the connection by manually starting some large downloads on each WAN. It's a PITA though!  :P
            rohbawa
            Hi … I arranged whole setup ... All working good ... Finally everything is settled ... For the time being I am not too worried about the speedtest ... Well I really appreciate your help Steve and this forum ...!!!
