    Session problem on websites (load balancing + sticky connections = state issue?)
    4 Posts 2 Posters 19.3k Views
      CDuv
      I'm having issues with pfSense outgoing connections load balancing (through my 3 WAN Internet connections) and many websites that requires some sort of authentication (via a simple web/HTML form):
      When you try to access the protected page you get redirected to the login form, once credentials sent you get access to the protected pages but only for a few seconds: about 20-25 second (sometimes even less but never more than a minute) after login-in the the next asked page redirects you to the login form.
      I've tried using the "Use sticky connections" option (located in "System: Advanced: Miscellaneous > Load Balancing") but it doesn't work either.
      I've checked connections states (located in "Diagnostics: Show States") and filtered it on one the website's IP (82.165.xx.yy) for which I have the issue and they are all in "FIN_WAIT_2":
      Proto Source -> Router -> Destination State
      tcp 82.165.xx.yy:80 <- 192.168.0.55:55919 FIN_WAIT_2:FIN_WAIT_2
      tcp 192.168.0.55:55919 -> 88.160.aa.bb:53387 -> 82.165.xx.yy:80 FIN_WAIT_2:FIN_WAIT_2
      • 192.168.0.55 is the LAN IP of my computer
      • 88.160.aa.bb is the WAN IP of one of my WAN Internet connection
      • 82.165.xx.yy is the IP of the webserver
      So my guess (and it's seems to be what support@optimalnetworks.c guessed in it's topic: sticky sessions) is that, as states are "FIN_WAIT_2:FIN_WAIT_2", connections are dropped.
      Side note: All three WAN connections are working just fine and, apart from that web-session issue all seems to be good. The websites aren't using HTTPS but simple clear HTTP so I can't create a rule to use my no-loadbalancing gateway group.
      Edit: typo in first paragraph.
      • jimpJ Offline
        Sticky keeps an association between a client IP and a gateway so long as there are active states for that client.
        In https://github.com/bsdperimeter/pfsense/commit/4573641589d50718b544b778cea864cfd725078a I added a GUI field to control the state tracking timeout so that sticky association can be held longer.
        What some people do is direct HTTPS into a failover group instead of load balancing.
        With sticky, what a lot of people don't understand is that the "sticky" relationship binds all connections from a client to a single WAN until all of their states expire, so in effect it changes the firewall behavior from a connection-based load balancer to a client-based one.
        When sticky is enabled, you can view the source tracking table under Diag > States on the Source Tracking tab.
        Do not Chat/PM for help!
        • jimpJ Offline
          If you want to experiment with that setting, you can pull in just that one commit change using the System Patches package
            CDuv
            @jimp:
            This is how I understood the sticky connections works, but as the "Show States" display no active states I think there is somewhere something that "inadvertently" prevents the sticky connections option to achieve it's goal by ending connections (thus becoming in FIN_WAIT_2): it might simply be HTTP "Connection: close" header.
            @jimp:
            I'll give it a try…
            @jimp:
            In this case, the websites aren't served via HTTPS protocol.
            One funny thing I found while testing: some site's backoffice where I was always "kicked" of in 3 or 4 seconds were now working just fine (or at least 10 minutes) after I added the following firewall rule just before my "load balancing" rule:
            TCP 	192.168.0.0/24 	* 	* 	80 (HTTP) 	GW_LoadBalancing 	none
            So my firewall rules are:
            TCP 	LAN net 	* 	* 	443 (HTTPS) 	GW_WanA_FO_WanB 	none
            * 	LAN net 	* 	* 	* 		GW_LoadBalancing	none
            I can't really explain how this could be of any impact as the rule #3 does the same job as the newly added rule #2.
