    OpenNTPD works well few days and then not sync
    29 Posts 7 Posters 14.6k Views
    • jimpJ Offline
      That may be possible. If you pkg_add -r that and it works with those keywords, it would certainly be worth adding in.
      FYI- checked in a bunch more fixes this afternoon for various issues I found, it's fairly solid now.
      If we can get the interface bindings to go that'll be the icing on the cake.
      As an added bonus, this ntpd support ipv6, openntpd did not.
      Do not Chat/PM for help!
        dominique.fournier
        Just a little html error need to be corrected in status_ntpd.php :
        Tally code
        Server
        Ref ID
        Stratum
        Type
        When
        Poll
        Reach
        Delay
        Offset
        Jitter
        should be :
        Tally code
        Server
        Ref ID
        Stratum
        Type
        When
        Poll
        Reach
        Delay
        Offset
        Jitter
        BTW, ntpd works well and stay synchronized since one hour. I will check for the long term. Thanks !!!
        2.1 (amd64)
        • jimpJ Offline
          That's already been corrected.
            dhatz
            A question about a somewhat related topic: When there is a large time skew, is it possible to sync time without rebooting pfsense (which invokes ntpdate on startup) ?
            I run pfsense in a VM and suspend/hibernate the host PC every evening, which results in several hours time diff when the PC wakes up the next morning. Unfortunately in this scenario ntpd won't sync to the correct time, even after pfsense has been running for several hours.
            I could create a cron job to periodically run ntpdate -s xyz, but maybe pfsense offers a better way which I haven't found yet.
            • jimpJ Offline
              On new snaps (not out yet) or 2.0.2 you can run /usr/local/sbin/ntpdate_sync_once.sh
              That will kill ntpd, run ntpdate to force a sync, then restart ntpd.
              I suppose I could add a button to Status > NTP to invoke that.
                podperson
                On latest Snap, nano i386, D510MO.ย  Would not stay synced without use of JimP script.
                Changed /var/etc/ntpd.conf.
                On server lines, removed iburst, set minpoll 6 maxpoll 6.
                Staying within 1 ms for 12 hours now.
                • jimpJ Offline
                  The values after the server line were pulled from FreeBSD's defaults. Not sure why yours needed to be changed that much.
                  What was the clock doing when you said it wouldn't stay in sync?
                  We may need to have a settings page to tweak those values if the defaults don't work for everyone.
                    maxpoll 6 is pretty aggressive.. This is talking to ntp server every 64 seconds.. This really should not be required, normally maxpoll will work its way up to 9, or 1024 seconds.
                    Normally you should not have to make changes to these settings.
                    • jimpJ Offline
                      OK, locking this topic for now so it doesn't attract more random ntp issues, this thread originally was for OpenNTP losing sync which is very far away from tweaking ntpd.
                      I may split some older posts from this topic off into separate threads since there are still interesting things in them, but they have diverged from the original topic.
