• HEADS UP: 2.1-RC0 Branched, you MUST fix your update URL.
    Pinned Locked
    15
    18k Views
    Thanks, I was wondering why I was't seeing new builds.
  • Want 2.1 to be released faster? Help test feedback tickets!
    Pinned Locked
    12
    15k Views
    K
    Seems so - But not to fear.  We can start a new thread and nag the devs incessantly about things we want in 2.2
  • Tracking 2.1 snapshot changes
    Pinned Locked
    10k Views
    To see what is the latest commit contained in the build: [2.1-BETA1][admin@xxx]/etc(15): cat /etc/version.lastcommit 990fa101b6a2ce09e813a8d58f0f43178e54fc45 Then use this number to display the commit in GitHub: https://github.com/pfsense/pfsense/commit/990fa101b6a2ce09e813a8d58f0f43178e54fc45 Other interesting data about the build state is in these files: [2.1-BETA1][admin@xxx]/etc(18): ls -l /etc/version* -rw-r--r--  1 root  wheel  10 Feb  3 08:52 /etc/version -rw-r--r--  1 root  wheel  29 Feb  3 09:08 /etc/version.buildtime -rw-r--r--  1 root  wheel  41 Feb  3 09:08 /etc/version.lastcommit -rw-r--r--  1 root  wheel   4 Feb  3 08:52 /etc/version_base -rw-r--r--  1 root  wheel   4 Feb  3 08:52 /etc/version_kernel
  • HEADS UP: OpenSSL 1.0.1_4 (1.0.1c), OpenVPN, and ipsec-tools, and others.
    Pinned Locked
    20
    17k Views
    F
    Dont know if this has been reported. Trying to create a new Internal-CA Key Length 4096 Hash SHA512 Days 3650 CountryCode: Mil Fill in the rest of the fields and you will get this error message. The following input errors were detected: openssl library returns: error:0D07A097:asn1 encoding routines:ASN1_mbstring_ncopy:string too long If you dont choose Mil you can create an internal CA. FWIW.
  • TESTING NEEDED: Multiple DHCP pools within a subnet
    Pinned Locked
    28
    26k Views
    jimpJ
    @WetWilly: Is "Multiple DHCP pools outside of subnet" Anywhere on the roadmap? Or is there any smooth way to a DHCP-range outside of LAN interface subnet? It's closer to being possible, but not going to happen any time soon (maybe 2.2, if someone has the time or funding for it). There is no way to do DHCP for another subnet on an interface currently. That's a question for another thread, though.
  • Pinned Locked
    28
    32k Views
    jimpJ
    Locking this thread for now, separate threads are better from here on. The purpose of this thread was for problems specific to 2.1 – meaning, package X worked on 2.0.x, but not 2.1. Most of those have been fixed, but packages that were broken on 2.0.x are also likely broken on 2.1 (e.g. stunnel, vhosts, freeswitch) and that's beyond the scope of what this thread is meant to deal with. I was originally doing triage trying to fix what I could on things to get things in decent shape, but we're at the point now where the package maintainers for items with remaining issues need to step up and fix what few things are left. In the cases where there are no active package maintainers for certain packages, someone with the time/knowledge may have to take them on.
    7k Views
    dont work anymore with OpenVPN gateway still getting Gathering Data…
  • Gitsync
    Pinned Locked
    13k Views
    jimpJ
    Yes, the GUI version only does so after a firmware update. The CLI version can be done at any time.
  • 2.0.1 IS NOT 2.1
    Pinned Locked
    11k Views
  • Snapshots are back!
    Pinned Locked
    54
    58k Views
    jimpJ
    Please start new, separate, threads for issues, rather than trying to pile on this old thread.
  • Welcome to the 2.1 board
    Pinned Locked
    19k Views
    jimpJ
    @johnpoz: Curious should maybe the ipv6 be a sub section of this? Actually, no, there were some rudimentary ipv6 functions outside of 2.1, and there will continue to be ipv6-specific issues even after 2.1 is released and this board goes into lockdown.
  • Not possible to set Gateway IP on IPv4 OpenVPN interface
    Locked
    14
    27k Views
    updating this thread in case anyone else runs across it (someone linked to it from elsewhere). The problem noted in the last post here is this: https://redmine.pfsense.org/issues/3475 which is fixed in 2.1.1
  • Snapshots offline for a bit
    Locked
    49
    41k Views
    K
    Rick Roll - Totally reminds me of when I had more hair…  ;D Meditation is working to attain my goals. [image: MyMethod.jpg] [image: MyMethod.jpg_thumb]
  • IPv6 dhcp not starting
    18
    13k Views
    O
    ok now dhcp6c doesn't crash, .. however the ipv6 routes are not working /usr/local/sbin/dhcp6c -f -d -D -c /var/etc/dhcp6c_wan.conf -p /var/run/dhcp6c_pppoe0.pid pppoe0 makes them work though, .. if i do sockstat -46lp546, it shows a lot of dhcp6c clients on that port and also a php and sh script. however they keep cycling, as if they crash constantly
  • MOVED: bandwidthd problem
    Locked
  • OpenVPN in 2.1RC1 not working as advertised
    Locked
    7k Views
    K
    This sounds exactly like what openvpn will do if its not installed with right-click, run as admin…
  • Optimizing rc.bootup
    Locked
    19
    12k Views
    I
    Hi ermal, thanks for your quick answer. Yes we are doing quite much on the system, but as we are sitting in Nepal we have no chance at the moment to get an other one with more RAM. We striped down to the minimum of services we need but still have problems. And i doubt our charity can pay for commercial support. Could you explain why you think this fix is unpredictable? By default it does not do anything, just if the administrator enters values in the "Maximum delay time" field it will be active. I agree with you that the problem is PHP and not the services them self. But even more that is an argument for me to use the sleeping solution as an temporary fix. We basically wait till the one php process is finished before we start a new one. Controlling the PHP forking would be of course a much better way of solving this problem. But as you told your self it's to late to have that change in 2.1. That would mean there would be no solution till 2.2 comes. What about having a workaround in 2.1 and going for a proper solution in 2.2?
  • OpenVPN Client says connected but server has no status
    Locked
    The server side is in a WAIT state. But the VPN link is up and running. Very annoying. I guess I will just create a cron job to check and restart the links.
  • RRD graphs shows spikes after rebooting
    Locked
    AhnHELA
    Have you reset RRD Data from the Settings tab in RRD Graphs?  Might have gotten corrupted.
  • UPnP & Chromecast
    Locked
    22
    50k Views
    I figured out my issue. And to be totally clear: this had nothing to do with pfsense. It wasn't "client isolation" in my WAP, per se, but the fact that my Cisco Aironet WAP was interfering with multicasting.  I found the solution here: http://forums.androidcentral.com/google-chromecast/301720-issue-chromecast-cisco-aironet-1140-a.html (i.e., disabling igmp snooping). Thanks for all the suggestions; they were helpful in tracking down the real issue.
