    Bandwidthd problem
    48 Posts 28 Posters 51.3k Views
      arriflex
      Alternatively, bandwidthd since version 2 can log to an external postgresql database. To test, I just set up bandwidthd on a local linux server with postgesql to catch bandwidthd logs from my Alix based nanobsd install of pfsense. I was able to get the linux install of bandwidthd working using postgresql for storage after a fair amount of newbie fanagling.
      Presumably using bandwidthd as a 'forwarder' sort of like pfflowd instead of hosting the php and data files locally on a compact flash installation should conceivably alleviate some of the issues?
      Unfortunately, I am unable to persist changes to the bandwidthd.conf file for obvious reasons. How does one properly modify config files that are subject to the pfsense GUI?
      arri
      ps. Sullrich attached the readme file from bandwidthd here: http://forum.pfsense.org/index.php/topic,2117.msg23881.html#msg23881 note the section on database support for more information.
        phil.davis
        The bandwidthd package consists of the bandwidthd tbz/pbi of the "real" software, plus the pfSense PHP and xml in GitHub at:
        https://github.com/pfsense/pfsense-packages/tree/master/config/bandwidthd
        That code generates the conf file and controls the start/stop…
        If you can give it an option to pass the data to another system, feel free to mod the code and submit a pull request. That would certainly be beneficial for nanoBSD CF installs.
          arriflex
          Phil, I am going to attempt to respond to your suggestion and would very much appreciate some guidance regarding my progress in a new thread: http://forum.pfsense.org/index.php/topic,64790.msg351425.html#msg351425
          arri
            nirovulf
            Try change<url>/bandwidthd" target="_blank</url>->```
            <url>/bandwidthd/index.html" target="_blank</url>
            After that I can watch statistics normally :)
              phil.davis
              @nirovulf - what browser+version+settings are you using?
              I am using Firefox (23.0.1). That displays the index.html automatically, without needing it specified. We can easily put your change into the bandwidthd package, as it should not do any harm. I would just like to know what environment causes the problem.
                nirovulf
                phil.davis
                I use Firefox 19.0.2, pfsense version: 2.0.3-RELEASE (i386)
                built on Fri Apr 12 10:22:21 EDT 2013
                FreeBSD pfsense.router 8.1-RELEASE-p13 FreeBSD 8.1-RELEASE-p13 #0: Fri Apr 12 10:47:01 EDT 2013 root@snapshots-8_1-i386.builders.pfsense.org:/usr/obj.pfSense/usr/pfSensesrc/src/sys/pfSense_SMP.8 i386
                Settings: interface - LAN, checked output_cdf, recover_cdf, draw_graphs; Meta Refresh set to 120. All other settings are default
                  phil.davis
                  I am a bit surprised that your Firefox does not go looking for index.html by default. But anyway, it is safer for all old/new/whatever browsers if we explicitly specify index.html like you suggest.
                  Pull request: https://github.com/pfsense/pfsense-packages/pull/483
                  30 minutes after that is committed you should be able to reinstall bandwidthd XML and it will work.
                    cboy2
                    How about editing /usr/local/etc/rc.d/bandwidthd.sh to point at /usr/pbi/bandwidthd-amd64/bandwidthd/bandwidthd instead of /usr/local/bandwidthd/bandwidthd?
                      phil.davis
                      @cboy2:
                      This code in bandwidthd.inc "should" select/use the new PBI-based directory names based on the pfSense version (>2.0 means it has PBI) and 32 or 64-bit install.
                      // Check pfSense version
                      $pfs_version = substr(trim(file_get_contents("/etc/version")),0,3);
                      switch ($pfs_version) {
                        case "1.2":
                        case "2.0":
                          define('PKG_BANDWIDTHD_BASE', '/usr/local/bandwidthd');
                          break;
                        default:
                          define('PKG_BANDWIDTHD_BASE', '/usr/pbi/bandwidthd-' . php_uname("m") . '/bandwidthd');
                      // End: Check pfSense version
                      I don't have a 64-bit install to try. What happens now on pfSense 2.1-RELEASE 64-bit?
                      Post the bandwidthd.sh that it makes, then hopefully I can see what happens.
                        cboy2
                        `#!/bin/sh
                        This file was automatically generated
                        by the pfSense service handler.
                        rc_start() {
                        rc_stop() {
                        /usr/bin/killall bandwidthd
                        case $1 in
                        start)
                        rc_start
                        stop)
                        rc_stop
                        restart)
                        rc_stop
                        rc_start
                        esac`   I've had this issue on two different 64 bit systems and one 32 (all I have tried) all running 2.1 or a RC thereof.
                          phil.davis
                          Now I really looked at the code! It has never worked for a 2.1 PBI-based full install.
                          Edit /usr/local/pkg/bandwidthd.inc to change line 324 from:
                          to
                          {$bandwidthd_base_dir}/bandwidthd
                          like in this GitHub change: https://github.com/phil-davis/pfsense-packages/commit/c918257082611cc9d9e9f9987a0a317d629885d7
                          That should make it understand full installs for 2.0.n and 2.1 in both i386 and amd64.
                          Then save your bandwidthd settings again and check that bandwidth.sh has better code, and that bandwidthd actually works.
                          If all is well, I will submit the pull request.
                          • F Offline
                            freehood4all
                            @kalu:
                            Hello every one
                            I have the latest pfsense build installed:
                            2.1-DEVELOPMENT (i386)
                            built on Wed May 2 08:30:27 EDT 2012
                            FreeBSD 8.3-RELEASE
                            installed the latest bandwidthd
                            "bandwidthd 2.0.1.3"
                            and it always shows me Please start bandwidthd to populate this directory.
                            I searched in this forum and was not able to find a proper solution
                            kalu
                            To anyone running into "Please start bandwidthd to populate this directory."
                            First check to see if it's running:
                            ps auxwww | grep -i bandwidthd
                            If it's running check the directory:
                            ls -al /usr/local/www/bandwidthd
                            lrwxr-xr-x  1 root  wheel    43 Sep 16 12:41 /usr/local/www/bandwidthd -> /usr/pbi/bandwidthd-amd64/bandwidthd/htdocs
                            I can see that the actual files aren't being written there.
                            Check this directory:
                            ls -al /usr/local/bandwidthd/htdocs/
                            If you see files in there, all you need to do is make the correct link
                            rm /usr/local/www/bandwidthd
                            ln -s /usr/local/bandwidthd/htdocs/ /usr/local/www/bandwidthd
                            Note: I ended up installing bandwidthd from pkg_add because I ran into issues originally, so my way is definitely non-standard.  And this probably only affects people who updated through the 2.1 beta, RC development cycle.  I'm sure stable has this working out of the box.
                              pkrnjevic
                              Just a comment freehood4all's note:
                              "Note: I ended up installing bandwidthd from pkg_add because I ran into issues originally, so my way is definitely non-standard.  And this probably only affects people who updated through the 2.1 beta, RC development cycle.  I'm sure stable has this working out of the box."
                              If I read your note right, you suggest that stable versions shouldn't have this problem.
                              I updated from a recently installed 2.0.3Release to 2.1Release, and definitely do have this problem.
                              Phil.davis describes a fix (previous comment in this thread) that mostly works, except for missing icons.
                                walkman
                                Hi, I noticed that this only happens when I use firfox, not chrome or IE.
                                • X Offline
                                  xerxes
                                  @freehood4all:
                                  This one works for me.. Thanks.
                                    smilodon
                                    This last method did not work for me.
                                    I also upgraded.. from 2.0.3 to 2.1 and had bandwidthd previously installed.
                                    So for me this was the fix:
                                    #First remove the package via GUI.
                                    killall bandwidthd #Just incase it still runs.
                                    find / -name "bandwidthd" #You get a list of files and directories related to Bandw.D.
                                    #Now delete all of them..
                                    rm -rf /directory/you/find
                                    #I also removed these.., which seem to be packages..
                                    /root/var/db/pbi/installed/bandwidthd-2.0.1_5-i386
                                    /root/var/db/pbi/.hashqueue/bandwidthd-2.0.1_5-i386
                                    Now install it again via GUI and it worked for me.
                                      cboy2
                                      @phil.davis:
                                      to
                                      #!/bin/sh
                                      # This file was automatically generated
                                      # by the pfSense service handler.
                                      rc_start() {
                                      	// /usr/local/bandwidthd/bandwidthd
                                      rc_stop() {
                                      case $1 in
                                      	start)
                                      		rc_start
                                      	stop)
                                      		rc_stop
                                      	restart)
                                      		rc_stop
                                      		rc_start
                                      esac
                                      Should the commented out line use # instead of //? ( // /usr/local/bandwidthd/bandwidthd)
                                      edit: I believe the // issue was my doing as I commented that line out without verifying it wasn't a standalone line.
                                        cboy2
                                        I can confirm that uninstalling the package leaves the old directory intact (/usr/local/bandwidthd) and that removing this directory prior to reinstalling makes the new install function as expected.
                                        The difference appears to be that /usr/local/bandwidthd/bandwidthd is now a symlink to /usr/pbi/bandwidthd-amd64/bandwidthd/bandwidthd, the bandwidthd.inc line 324 is the same.
                                          williamspinto
                                          To resolve this problem (php: /pkg_edit.php: The command '/usr/local/etc/rc.d/bandwidthd.sh stop' returned exit code '1', the output was 'No matching processes were found') on start the bandwidth on new version of pfsense 2.1 and new version off bandwidth 2.0.1 i do just removed the directory "/usr/local/bandwidthd" and reinstalled a bandwidth. Its work fine to me.
                                          Ps.: My english is not good. :( hehe
                                            rsleegers
                                            @kalu:
                                            I ran through the troubleshooting and confirmed BandwidthD was running, but when clicking on Services, BandwidthD, the Access BandwidthD, a new page/tab opens to https://192.168.0.1/bandwidthd/index.html with the same error (using Firefox).
                                            If I change the URL to https://192.168.0.1/bandwidthd/ then the summary page appears as expected. It would appear the link is not set correctly, or the index page should be deleted when proper data is found. I'm using the output_cdf method.
