Interface problem within installation
Im trying to install the pfsense on vmware but when i prompt to enter the interface names auto dedection doesnt work. then i hit the ctrl d it says that valid interfaces are Ie0 and Ie1. Then i write one of this at that wan interface prompt it still doesnt accept. And i cant go on and complete the installation. So what can be bthe problem? -
First thought, the interface names are all lower case letters so it will be: ie0 or ie1.
Second thought, the ie(4) interface is ancient and slow though probably compatible with almost anything. Can you not get vmware to present some other type of NIC?
It's not ie it's le (lower case L). You should only use e1000 type NICs in VMware though (which are em).
