    Problem to reach LAN from WLAN
    5 Posts 3 Posters 1.6k Views
      climblinne
      I have the following configuration under PfSense 2.0.1:
      WAN1: Not used until now, will be a static IP address from Wimax connection
      WAN2: ADSL-Router, IP DHCP, 192.168.1.2, Gateway 192.168.1.1, Firewall - default blocking
      LAN: 10.17.60.251, No DHCP, Mask 255.255.255.0, Firewall: Allow *
      WLAN1: 192.168.2.1, DHCP activated, Mask 255.255.255.0, Firewall: Allow *
      WLAN2: 192.168.3.1, DHCP activated, Mask 255.255.255.0, Firewall: Allow * (same wireless card, second AP)
      Internet through WAN2 from LAN, WLAN1 is working.
      Access from LAN to WLAN1  is working.
      Access from WLAN1 to LAN is not working and I don't understand why?
      Actually NAT is set to auto translation. The route list in the status looks correct.
      In the beginning I had the LAN segment at the WAN port and this I could reach from the WLAN port.
      Hopefully anybody can help me…
        heper
        normally a firewall rule on the wlan tab with destination any or lan-subnet should work if the default gateway is used.
        be sure you havent specified a specific gateway on the "allow *" rule
          marvosa
          Are you getting internet on WLAN2?
          So on WLAN2, you have created a 2nd AP configured with the 192.168.3.0/24 subnet on the same card for people to connect to? (a network map would be helpful)
          Can you post the routing table on PFsense?
            climblinne
            @heper:
            I use the default gateway already with all set to "*"
              climblinne
              @marvosa:
              One WLAN should be for internal use and the other one should be later a guest account with internet access only.
              But until now both are full functional with * rules and internet is working for both of them.
              The WAN1 sould be later the main internet connection & WAN2 the backup internet connection. WAN2 i also used later for the guest access. For testing I only have WAN2 connected, because our other router is still active :)
              IPv4
              Destination Gateway Flags Refs Use Mtu Netif Expire
              default 192.168.1.1 UGS 0 7946 1500 vr2
              8.8.8.8 192.168.1.1 UGHS 0 372 1500 vr2
              10.17.60.0/24 link#1 U 0 734 1500 vr0
              10.17.60.251 link#1 UHS 0 0 16384 lo0
              1.2.3.224/30 link#2 U 0 0 1500 vr1 //  not used WAN1 IP modified
              1.2.3.226 link#2 UHS 0 0 16384 lo0 // not used WAN1 IP modified
              127.0.0.1 link#6 UH 0 155 16384 lo0
              192.168.1.0/24 link#3 U 0 20687 1500 vr2
              192.168.1.2 link#3 UHS 0 0 16384 lo0
              192.168.2.0/24 link#9 U 0 4893 1500 ath0_wlan1
              192.168.2.1 link#9 UHS 0 0 16384 lo0
              192.168.3.0/24 link#10 U 0 8444 1500 ath0_wlan2
              192.168.3.1 link#10 UHS 0 0 16384 lo0
