    VOIP incoming calls problem
    4 Posts 3 Posters 2.7k Views
      Malesefx
      I have around 60 VOIP Polycom Phones, and after I look Pfsense SIP rule settings sticky, I feel like there are still something missing in my end.Because Phones can make outgoing calls however, 5-6 phones out 60 phones work for incoming calls in certain amount of time, then they stop working, then other 5 phones start working then , they stop working.Meaning some random phones work short amount of time for incoming calls then they stop working.
      So Far I configured following NAT settings and also on Rules I put the STATE TYPE to NONE. Obviously I am still missing something.
      Protocol  Source Port Destination    Port              Gateway    Queue
      TCP/UDP *   *   voip         5060 (SIP)     *         none
      TCP/UDP *   *   voip       10000 - 20000 *         none
      TCP/UDP *   *   voip       2222 - 2268   *         none
      TCP/UDP *   *   voip         123 (NTP)     *         none
      voip, defines an alias for the IP address range that phones have.
      I appreciate for your time and answers
        podilarius
        I think the state type needs to stay at Keep State. The phone send a keep alive signal every so often. This is meant for NAT system with state keeping.
          TreeTopFlyer
          Are you using Manual Outbound NAT?
          Is "Firewall Optimization" set to "Conservative"?
          I have 8 sites running Polycom phones and this is all I've ever had to do to get them running.  No added rules.
            podilarius
            I am using both manual outbound NAT, but my optimization is set to normal. I am running Cisco phones. I have heard that polycom phones are more forgiving.
