    Mini PCI express wireless card for hostap mode
    22 Posts 4 Posters 7.5k Views
      woni
      Thanks for response.
      I have tried all antenna (1,2,3) but only 2 is working with the named limitation.
      So, I think, I buy two antennas, connect their and give feedback.
      And sure, I had rebooted after every change.
        woni
        Now, I have build in 2 further antennas. So I have one external and two internal antennas. Without luck. Nothing changed.
        It seems, only antenna 2 is working. It doesn't matter, what I configure. In example the channel: I configure 10 but the system comes up with 1.
        Further, I have recognized that the signal strength is always going down and up.
        I have configuered a <shellcmd>to restart ath0_wlan0 after bootup. This solves the behavior and the channel is 10 which I have configured.
        I think, there is a problem in startup. I would like to try a complete reconfigure-script after startup, but I don't know how.
        Any help woukd be fine.</shellcmd>
