Multi LAN, one DHCP and one static mapping. Problem
Question
Is there any way to have one pfsense with two subnets both active on the same psysical local network?
And then create rules so some DHCP enabled computers go into one subnet and the rest as default goes into the other subnet?This is what I have tried with no luck
Pfsense: Subnets and interfaces
vr1 = WAN
vr0 = LAN 192.168.24.1/24 - DHCP NOT enabled.
vr2 = OPT1 192.168.25.1/24 - DHCP enabledPfsense: Client setup
CLIENT_01: No rules
CLIENT_02: No rules
CLIENT_03: Static mapping for MAC address to 192.168.24.200Client setup
CLIENT_01 : setup with static IP 192.168.24.205
CLIENT_02 : set up to get IP from DHCP
CLIENT_03 : set up to get IP from DHCPSetup LAN
4 switches, 130 clients.
Both LAN and OPT1 goes into the same switch so clients on any ports/switch can connect to one of the two subnets.Result / problem
Good result:
CLIENT_01 will go into the network on the LAN interface (192.168.24.x) as configured on the client
CLIENT_02 get a DHCP address from OPT1 as espected (192.168.24.x)Bad result:
CLIENT_03 also gets an DHCP address even though I added a static mapping for LAN interface (192.168.24.200)I can see it in the DHCP listed as "offline" at the bottom of the page with the statip mapped LAN address. But searching for the MAC address I also see it listed with a DHCP address from the OPT1.
to sum up…
I look for a way to fix this problem or do the same thing in a different way.
