    Problem with Alpha RTL8187 USB-wifi adapter
    3 Posts 2 Posters 2.3k Views
      pachi
      I am running pfSense from a Live CD so I can test it and get to know it a bit.
      The Alpha RTL8187 USB-wifi adapter will not run correctly; when I try to configure it I get the error message "RF Calibration failed".
      Is there an easy way to correct this?
      I know very little about Linux but my first guess is that it may be a problem with the driver because I have used this adapter with other Linux implementations without problem.
      Since I am running a live CD it might be very difficult to load a different driver….
      Any ideas?
        wallabybob
        It might work better with a pfSense 2.1 snapshot build which is based on FreeBSD 8.3, a more recent release than that used in earlier versions of pfSense.
        @pachi:
        pfSense is based on FreeBSD which is not Linux. FreeBSD is very similar to Linux in some respects, very different in other respects.
          pachi
          @wallabybob:
          Thanks, I did not know that.
          @wallabybob:
          I downloaded the latest version I found in the download page which was 2.0.1.  I guess I'll just wait for v.2.1 to appear and see if the RTL8187 works with it.
          Thanks again.
