    Captive portal still doesn't start automatically on system startup
    30 Posts 12 Posters 10.8k Views
    • F Offline
      freebee
      Thanks for the effort to solve this problem.
        mdmogren
        Still happening in latest build. Anyone have any ideas? Getting frustrated that this is going on so long…
        • E Offline
          eri--
          I will fix this probably by next week.
            wallabybob
            @ermal:
            Excellent. Thanks for the intention.
            • F Offline
              freebee
              Can somebody try this ?.
              Create some script in /usr/local/etc/rc.d like
              ee /usr/local/etc/rc.d/fix_captiveportal.sh
              put this two lines:
              /etc/rc.captiveportal_configure
              /usr/local/sbin/lighttpd -f /var/etc/lighty-visitantes-CaptivePortal-SSL.conf
              Save, do chmod 655  /usr/local/etc/rc.d/fix_captiveportal.sh.
              Reboot.
              OBS: The line /usr/local/sbin/lighttpd -f /var/etc/lighty-visitantes-CaptivePortal-SSL.conf changes on every installation. To see the correct name file, ls /var/etc . Will be something like: lighty--CaptivePortal-SSL.conf (if you use SSL) or lighty--CaptivePortal.conf without SSL.
              In Alix board, patient. 2 minutes (more or less) to everything work. rw on / to write file and chmod take effect.
              This script can be more elaborated and is not the real fix to the problem (can solve temporally i guess).
              • E Offline
                eri--
                Should be fixed on next snapshots.
                • MellowlynxM Offline
                  Mellowlynx
                  @ermal:
                  I hope it's the one built after: Thu Nov 22 09:33:27 EST 2012??
                  In this one it's still not staring as it should :(
                  • E Offline
                    eri--
                    Its this one https://github.com/bsdperimeter/pfsense/commit/3a4b01476620d33b6d6200849231398f82e593c7
                    Probably tomorrow snapshot should have it.
                      mdmogren
                      I can confirm that this works on the snapshot: "built on Thu Nov 22 14:00:25 EST 2012"
                      Have already updated/tested on 5 different routers.
                      Thanks so much! :)
                        bmah
                        Working great now on this version:
                        2.1-BETA0 (i386) built on Thu Nov 22 13:25:28 EST 2012 FreeBSD 8.3-RELEASE-p4
                        (1GB nanobsd i386 on Soekris net5501)
                        Thanks for the fix!
                        Bruce.
