    "Mini" system for 150/65Mbps connection
    22 Posts 8 Posters 7.2k Views
    • F Offline
      Fmstrat
      Hi All,
      Tacking on one final question before I make the decision between the larger Jetway machine with Intel NICs and the smaller Fit-PC with Realtek. The specs for the Fit-PC show:
      6W at low CPU load
      8W at full CPU load
      1W at standby
      While all I can see about the Jetway (http://www.newegg.com/Product/Product.aspx?Item=N82E16856107095) is a 60W power brick. Given the Atom 1.1ghz vs 1.8ghz in each, power consumption will likely be near the same between the two boxes regardless, right?
      Thanks!
      Ben
        podilarius
        I would imagine that if you use powerd, you could keep the power usage low.
