Incoming traffic on vlan not recognized
Then something must be wrong on my side.
I still get that I'm on the latest version…. let's do the update by hand.Updated without problems.
This afternoon I will test the PCP issue. -
I can confirm that the issue has been fixed.
I will do more elaborate testing this weekend with different PCP's and PCP combinations.
For now it looks promising.@ndre
Confirmed. '2.1-BETA0 (amd64) built on Fri Aug 31 11:22:13 EDT 2012' seems to work.
Thanks to everyone involved!
What exactly went wrong?Update: the web interface for special rules for 802.1p still does not save different values. So shifting pcp on incoming/outgoing packets is still unsupported (through the gui).
Have you tried turning off VLAN_HWTAGGING ???
I have an Atom based machine with 2 Intel NICs and vlans don't work until I turn this feature off.
I had to put this in a cronjob:
ifconfig em0 | grep -q VLAN_HWTAG && ifconfig em0 -vlanhwtag ifconfig em1 | grep -q VLAN_HWTAG && ifconfig em1 -vlanhwtagWorth a try….
I have an Atom based machine with 2 Intel NICs and vlans don't work until I turn this feature off.I had to put this in a cronjob:
ifconfig em0 | grep -q VLAN_HWTAG && ifconfig em0 -vlanhwtag ifconfig em1 | grep -q VLAN_HWTAG && ifconfig em1 -vlanhwtagThis is an issue that should be investigated …
What is the exact model of your Intel NIC (output of dmesg) and your mainboard ?
I brought it up before ( http://forum.pfsense.org/index.php/topic,52224.0.html ) and made a bug report asking for an option to turn off hardware vlan tagging.
http://redmine.pfsense.org/issues/2577
I would welcome some follow-up, but don't want to hijack this thread.
Well, This is the output of dmesg regarding to my nics:
em0: <intel(r) 1000="" pro="" network="" connection="" 7.3.2="">port 0xcc00-0xcc1f mem 0xfe7e0000-0xfe7fffff,0xfe7dc000-0xfe7dffff irq 18 at device 0.0 on pci3
em0: Using MSIX interrupts with 3 vectors
em0: [ITHREAD]
em0: [ITHREAD]
em0: [ITHREAD]
pcib4: <acpi pci-pci="" bridge="">irq 19 at device 28.3 on pci0
pci4: <acpi pci="" bus="">on pcib4
em1: <intel(r) 1000="" pro="" network="" connection="" 7.3.2="">port 0xdc00-0xdc1f mem 0xfe8e0000-0xfe8fffff,0xfe8dc000-0xfe8dffff irq 19 at device 0.0 on pci4
em1: Using MSIX interrupts with 3 vectors
em1: [ITHREAD]
em1: [ITHREAD]
em1: [ITHREAD]
em2: <intel(r) 1000="" pro="" legacy="" network="" connection="" 1.0.4="">port 0xec00-0xec3f mem 0xfebe0000-0xfebfffff,0xfebc0000-0xfebdffff irq 18 at device 4.0 on pci6
em2: [FILTER]
em3: <intel(r) 1000="" pro="" legacy="" network="" connection="" 1.0.4="">port 0xe880-0xe8bf mem 0xfeb80000-0xfeb9ffff,0xfeb60000-0xfeb7ffff irq 19 at device 6.0 on pci6
em3: [FILTER]
em4: <intel(r) 1000="" pro="" legacy="" network="" connection="" 1.0.4="">port 0xe800-0xe83f mem 0xfeb20000-0xfeb3ffff,0xfeb00000-0xfeb1ffff irq 16 at device 7.0 on pci6em0 and em1 are the on-board nics. em2..5 are the nics on the expansion board.
VLAN_HTWAG is off by default. I checked again to be sure.
@ndre</intel(r)></intel(r)></intel(r)></intel(r)></acpi></acpi></intel(r)>
@avink:
@ndre
In this thread you gave the output of your ifconfig and it clearly shows you have VLAN_HWTAGGING enabled.
How did you disable it, then?
There's no option inside pfsense to do this.
That's why I made the feature request which was rejected.[2.1-BETA0][admin@firewall]/root(9): ifconfig -a em0: flags=8943 <up,broadcast,running,promisc,simplex,multicast>metric 0 mtu 1500 options=5219b <rxcsum,txcsum,vlan_mtu,vlan_hwtagging,vlan_hwcsum,tso4,wol_magic,vlan_hwfilter,vlan_hwtso>ether 00:30:18:a2:bd:13 inet6 fe80::230:18ff:fea2:bd13%em0 prefixlen 64 scopeid 0x6 nd6 options=3 <performnud,accept_rtadv>media: Ethernet autoselect (1000baseT <full-duplex>) status: active em0_vlan4: flags=8943 <up,broadcast,running,promisc,simplex,multicast>metric 0 mtu 1500 options=103 <rxcsum,txcsum,tso4>ether 00:30:18:a2:bd:13 inet6 fe80::76f0:6dff:fe80:9448%em0_vlan4 prefixlen 64 scopeid 0x13 nd6 options=1 <performnud>media: Ethernet autoselect (1000baseT <full-duplex>) status: active vlan: 4 vlanpcp: 0 parent interface: em0</full-duplex></performnud></rxcsum,txcsum,tso4></up,broadcast,running,promisc,simplex,multicast></full-duplex></performnud,accept_rtadv></rxcsum,txcsum,vlan_mtu,vlan_hwtagging,vlan_hwcsum,tso4,wol_magic,vlan_hwfilter,vlan_hwtso></up,broadcast,running,promisc,simplex,multicast>
