Yate telephony engine on pfsense 2.1 ($ plz quote)
i386
im using pfsense on the alix box using nanobsd
i386
can you try to install this package before?
pkg_add -r http://e-sac.siteseguro.ws/packages/8/All/cyrus-sasl-2.1.26_2.tbz
All not found messages point to an existing package on repo, I'm not sure what is happening
I'll install a testing vm for it.
still a bunch of errors and not founds
[2.1-BETA1][root@firewall.xbipin]/root(2): pkg_add -r http://e-sac.siteseguro.ws /packages/8/All/cyrus-sasl-2.1.26_2.tbz Fetching http://e-sac.siteseguro.ws/packages/8/All/cyrus-sasl-2.1.26_2.tbz... Do ne. Fetching http://e-sac.siteseguro.ws/packages/8/All/db41-4.1.25_4.tbz... Done. *** Added group `cyrus' (id 60) *** Added user `cyrus' (id 60) You can use sasldb2 for authentication, to add users use: saslpasswd2 -c username If you want to enable SMTP AUTH with the system Sendmail, read Sendmail.README NOTE: This port has been compiled with a default pwcheck_method of auxprop. If you want to authenticate your user by /etc/passwd, PAM or LDAP, install ports/security/cyrus-sasl2-saslauthd and set sasl_pwcheck_method to saslauthd after installing the Cyrus-IMAPd 2.X port. You should also check the /usr/local/lib/sasl2/*.conf files for the correct pwcheck_method. [2.1-BETA1][root@firewall.xbipin]/root(5): pkg_add http://e-sac.siteseguro.ws/pa ckages/8/All/yate-4.3.0.p1.tbz Fetching http://e-sac.siteseguro.ws/packages/8/All/yate-4.3.0.p1.tbz... Done. Fetching http://e-sac.siteseguro.ws/packages/8/All/expat-2.0.1_2.tbz... Done. Fetching http://e-sac.siteseguro.ws/packages/8/All/openldap-sasl-client-2.4.26.t bz... Done. pkg_add: warning: package 'openldap-sasl-client-2.4.26' requires 'cyrus-sasl-2.1 .25_1', but 'cyrus-sasl-2.1.26_2' is installed ************************************************************ The OpenLDAP client package has been successfully installed. Edit /usr/local/etc/openldap/ldap.conf to change the system-wide client defaults. Try `man ldap.conf' and visit the OpenLDAP FAQ-O-Matic at http://www.OpenLDAP.org/faq/index.cgi?file=3 for more information. ************************************************************ Fetching http://e-sac.siteseguro.ws/packages/8/All/jpeg-8_3.tbz... Done. Error: Unable to get http://e-sac.siteseguro.ws/packages/8/All/jbigkit-1.6.tbz: Not Found Error: Unable to get http://e-sac.siteseguro.ws/packages/8/All/tiff-4.0.3.tbz: N ot Found Fetching http://e-sac.siteseguro.ws/packages/8/All/pwlib-1.12.0_7,1.tbz... Done pkg_add: warning: package 'pwlib-1.12.0_7,1' requires 'cyrus-sasl-2.1.25_1', but 'cyrus-sasl-2.1.26_2' is installed Fetching http://e-sac.siteseguro.ws/packages/8/All/openh323-1.19.0.1_5.tbz... Done kg_add: warning: package 'openh323-1.19.0.1_5' requires 'cyrus-sasl-2.1.25_1', but 'cyrus-sasl-2.1.26_2' is installed Fetching http://e-sac.siteseguro.ws/packages/8/All/spandsp-devel-0.0.6.p21.tbz.. . Done. pkg_add: could not find package jbigkit-1.6 ! pkg_add: could not find package tiff-4.0.3 ! pkg_add: pkg_add of dependency 'spandsp-devel-0.0.6.p21' failed! Fetching http://e-sac.siteseguro.ws/packages/8/All/opencore-amr-0.1.3.tbz... Don e. Fetching http://e-sac.siteseguro.ws/packages/8/All/libogg-1.2.2,4.tbz... Done. Fetching http://e-sac.siteseguro.ws/packages/8/All/speex-1.2.r1_3,1.tbz... Done Fetching http://e-sac.siteseguro.ws/packages/8/All/gsm-1.0.13.tbz... Done. Error: Unable to get http://e-sac.siteseguro.ws/packages/8/All/alsa-lib-1.0.26.t bz: Not Found -
i get a lot of these during reboot
Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/2009062 6/ldap.so' - Shared object "libsasl2.so.2" not found, required by "libldap-2.4.s o.8" in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/2009062 6/ldap.so' - Shared object "libsasl2.so.2" not found, required by "libldap-2.4.s o.8" in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/2009062 6/ldap.so' - Shared object "libsasl2.so.2" not found, required by "libldap-2.4.s o.8" in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library '/usr/local/lib/php/2009062 6/ldap.so' - Shared object "libsasl2.so.2" not found, required by "libldap-2.4.s o.8" in Unknown on line 0 -
i was just checkng the yate setup file and it consists of this folder which isnt required actually, its for running yate as client, like a dialer.
share/yate/skins
any fix?
any fix?
I'm still testing a install procedure, freebsd ports were updates, I'll try to publish it ASAP.
any update?
still waiting for this
You know what we all humans have.
any update on this?
