    PfSense newbie configuration problem
    43 Posts 5 Posters 15.5k Views
    • V Offline
      vdecristofaro
      @podilarius:
      Okay … in advanced setup -> uncheck the option to disable firewalling. Save and apply.
      Done!
      @podilarius:
      Then head to firewall -> advanced outbound NAT and select auto. Save and apply.
      Do you mean the tab Firewall/NAT on the Advanced Setup page?
      I went to System - > Advanced Setup and then to the Firewall/NAT tab.
      These are my settings now
      @podilarius:
      After that, head to firewall -> rules -> LAN. Setup a rule to allow any protocol with source LAN subnet to Any/Any. Save and apply.
      Here it is!
      @podilarius:
      Then go to Services -> DHCP and enable that on LAN. give is a range like 192.168.83.50-250. save and apply.
      reboot the FW.
      Done!
      @podilarius:
      Get on a machine behind the FW and trace route to www.google.com and see how far your get.
      I have tried. Now i am able to traceroute any public server. I can see that, respect to traceroute when done from the HOST, now the first hop is the pfSense router itself. Very good. Unfortunately anyway I am not able to navigate on the internet. I have used Fiddler to see what's going on and I can see that the request terminate with HTTP 502 - Connection Failed.
      I suspect that is the proxy server…
        podilarius
        @vdecristofaro:
        Yes I do. Not the Advanced in system setup.
        Error 502 does seem to be a proxy stopping the connection (lists as bad gateway).
        Check your DNS settings on the FW to make sure you websites are resolving correctly. Can you get to a page that other Clients can get to as well?
        • V Offline
          vdecristofaro
          @podilarius:
          @vdecristofaro:
          For other reasons this morning I was trying to install wget.
          So from the pfSense box  I've choosen "8 - Shell" and then:
          • Went to /etc/csh.cshrc to setup http_proxy, https_proxy and ftp_proxy environment variables
          • restarted the box
          • Again to the shell I have tried to install wget with the command /usr/sbin/pkg_add -r wget
          The result really surprised me.
          Error: Unable to get to ftp://ftp.freebsd.org/......: No address record
          pkg_add: Unable to fetch 'ftp://ftp.freebsd.org/.....' by URL
          this seems to be a nameserver problem. Right? my resolv.conf file seems to have right values anyway
          domain localdomain
          nameserver 127.0.0.1
          nameserver 10.182.209.132
          nameserver 10.254.49.133
          nameserver 8.8.8.8
          nameserver 8.8.4.4
          I dont understand what the "domain" entry and the "nameserver 127.0.0.1" are for, but I guess their presence shall not be a problem….Do I am right?
            Ok here is the thing - you mention your in a large network right.
            Large networks quite often do a few things for security reasons.  1 they normally only allow a proxy internet access, so to get to the internet you have to use that proxy.  Direct internet access is blocked - only the proxy is allowed internet access.
            2 they normally block dns, your local dns you point to - ie those 10.182 and 10.254 IPs more than likely don't even resolve public domains.  quick enough to check, using nslookup or dig - do a query to them directly for outside something, www.google.com, ftp.freebsd.org, etc.  Along with not allowing the local nameservers to resolve public domains they normally do not allow you to query outside dns, ie the those googledns you have there at 8.8.8.8
            This is common practice for corp networks.  Why you would need to run a router/firewall inside your corp network without support and details from corp IT is beyond me.
            But unless you bounce off your corp proxy is more than likely your never getting off the corp network.
            So does your workstation have internet access?  If so look to see what proxy your browser is pointing to.
            you state
            "Now i am able to traceroute any public server"
            Lets see this!  And what are you using for your dns?  You doing this from your PC or pfsense?  Please post the details of where you doing this traceroute ip address, gateway and nameserves - along with the full trace to www.google.com – here is example
            C:\Windows\system32>tracert www.google.com
            Tracing route to www.google.com [74.125.225.210]
            over a maximum of 30 hops:
              1     2 ms    <1 ms    <1 ms  pfsense.local.lan [192.168.1.253]
              2    28 ms    28 ms    29 ms  c-24-13-176-1.hsd1.il.comcast.net [24.13.176.1]
              3    13 ms    10 ms    11 ms  te-1-2-ur07.mtprospect.il.chicago.comcast.net [68.85.131.149]
              4    11 ms    11 ms     9 ms  te-8-4-ur08.mtprospect.il.chicago.comcast.net [68.86.187.202]
              5    16 ms    15 ms    15 ms  te-1-2-0-5-ar01.area4.il.chicago.comcast.net [68.87.230.53]
              6    15 ms    23 ms    23 ms  pos-3-10-0-0-cr01.350ecermak.il.ibone.comcast.net [68.86.93.181]
              7    12 ms    14 ms    16 ms  pos-1-8-0-0-pe01.350ecermak.il.ibone.comcast.net [68.86.87.166]
              8    21 ms    12 ms    13 ms  66.208.228.202
              9    13 ms    13 ms    28 ms  209.85.254.128
             10    13 ms    13 ms    27 ms  72.14.237.130
             11    25 ms    23 ms    24 ms  209.85.241.22
             12    66 ms    33 ms    34 ms  72.14.239.49
             13    32 ms    34 ms    37 ms  216.239.46.149
             14    33 ms    33 ms    34 ms  209.85.251.111
             15    34 ms    34 ms    33 ms  den03s06-in-f18.1e100.net [74.125.225.210]
            Trace complete.
            • stephenw10S Online
              For the record you can just use fetch instead of wget and it's already installed.
              Also the pkg source location is now out of date for 2.0.1 so you have to specify the full path to the file. E.g.
              pkg_add -r ftp://ftp-archive.freebsd.org/pub/FreeBSD-Archive/ports/i386/packages-8.1-release/Latest/wget.tbz
              Also if ftp is blocked upstream you can use http instead:
              pkg_add -r http://ftp-archive.freebsd.org/pub/FreeBSD-Archive/ports/i386/packages-8.1-release/Latest/wget.tbz
                podilarius
                what johnpoz says is very true of corporate networks. I would use a DNS server other than corporate if I was going to try to get around security. Most likely they have it so that only certain IP or users can even get to the internet. Can you get to local web servers? They may even have a captive portal or something.
                • V Offline
                  vdecristofaro
                  @johnpoz:
                  Right!
                  @johnpoz:
                  I dont really know how to read dig results but here is the result of that command when executed inside the pfSense VM
                  @johnpoz:
                  The reason is quick explained. I dont mind about the firewall. I have several VM (5/6) that resemble networks and that I use to develop software solutions. Having a software router for those "virtual labs", which is the only thing I need, has a couple of advantages for me. First of all I have a network lab that is really very similar to the production environment. In addition having 5/6 VM running inside my laptop, every one with two NIC (1 for internal network and one for the internet, will completely jeopardize my host NIC…
                  For those reasons I just thought that having a "software router" would be a solution. Maybe this solution does not apply on the network where I am now and will work without any further configuration if I would have DIRECT access to the Internet.
                  @johnpoz:
                  Yes. I can browse the internet from my host using a proxy. I have statically (in /etc/csh.cshrc) setup the same proxy inside the pfSense.
                  but unfortunately, even if I follow stephenw10 suggestion I cannot get to the record because of the same "No address record" error.
                  @johnpoz:
                  you state
                  Well I have just posted the result of doing dig in the pfSense VM. So let's see how the host and the VM in the Virtual network behaves.
                  When I execute nslookup from the host PC I get these results
                  C:\>nslookup www.google.com
                  Server:  usdnsl201-ficus.usinet.it
                  Address:  10.182.209.132
                  Non-authoritative answer:
                  Addresses:  2a00:1450:400c:c06::6a
                            74.125.132.106
                            74.125.132.147
                            74.125.132.99
                            74.125.132.103
                            74.125.132.104
                            74.125.132.105
                  Finally this is the result when I execute nslookup from a windows PC/server inside the virtual network
                  1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.ip6.arpa
                          primary name server = 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.
                          responsible mail addr = (root)
                          serial  = 0
                          refresh = 28800 (8 hours)
                          retry   = 7200 (2 hours)
                          expire  = 604800 (7 days)
                          default TTL = 86400 (1 day)
                  Server:  UnKnown
                  Address:  ::1
                  Addresses:  2a00:1450:400c:c06::63
                            74.125.132.106
                            74.125.132.147
                            74.125.132.99
                            74.125.132.103
                            74.125.132.104
                            74.125.132.105
                    Well your vm there it asked itself for dns on the ipv6 loopback, so is then forwarding or looking up direct from roots?
                    Same thing with your pfsense - it asked its dns forwarding process for that address, you don't actually know which dns server it asked for that.  I believe it asks all of them and uses the one that answers first?  Or does it ask in order?  There was a thread back a while back that went over this - but I don't recall the details on that.
                    So clearly you can do outside dns queries - but if your having to use a proxy to actually get outbound access, the ability to do dns doesn't help much ;)
                    Now in
                    System: Advanced: Miscellaneous
                    There is a way to point to an upstream proxy to allow pfsense access - but not sure on how that actually functions, does that mean that need to be using proxy on pfsense?  Or does pfsense just route all that traffic to that proxy?
                    • V Offline
                      vdecristofaro
                      @johnpoz:
                      Now in
                      I did already setup proxy as you're suggesting. Me too, I dont have idea on how this works. In the next days I will try this setup in a network with direct access just to verify that in effect this can be a problem caused by the presence of the proxy.
                      For now, I would like to thank all the people that spent some of it's time trying to help.
                        There is no need to add the proxy information to pfSense, you only need to do that as a convenience for machines behind pfSense and to enable the box itself to have web access. You can just add the proxy to the clients behind pfSense as would for boxes in front it. You won't be able to update from the webgui.
                        It maybe that the upstream proxy has a problem with NATed clients connecting to it perhaps by design. It would seem reasonable for your network admin to not won't people running their own routers.
                          How would proxy know they are natted?  Shouldn't all the traffic look like it is coming from pfsense wan interface that is on the network just like a normal client?
                            Multiple clients logging in with the same credentials? Too many simultaneous sessions?
                            I'm speculating. I agree it seems unlikely.
                            • V Offline
                              vdecristofaro
                              @stephenw10:
                              Well even if I remove the proxy informations I am not able to navigate the web from the pfSense machine.
                              This continue to appear very strange to me and I am still convinced of a configuration problem….
                              Look at this screenshot (taken from the pfSense machine) to understand why I am saying this...
                              How it is possible that I can do nslookup without any problem and getting "No address record" when using fetch??
                                podilarius
                                If you do a fetch with the IP, does it work? (fetch http://173.194.65.105)
                                I think generally you want to be file specific with fetch so you don't get to much. Perhaps:
                                fetch http://files.chi.pfsense.org/jimp/foo/shiny/ehrmagerd/pfSense-Full-Update-2.0.2-RELEASE-i386-20121004-1028.tgz
                                  If you have removed the upstream proxy settings from pfSense then this won't work. Assuming the network admin has blocked non proxied http access.
                                    So do you need a proxy to get out??  This has been verified right?  Have you set this for fetch to use?
                                    I believe you can view this with the echo of the $HTTP_PROXY variable
                                    echo $HTTP_PROXY
                                    HTTP_PROXY: Undefined variable.
                                    also what is in your /etc/resolv.conf file
                                    Do you have any limitation on dns in any of your rules or the dns server your trying to use?
                                    This proxy on your network - how is it implemented.  Do you have to set it explicit, is wccp used?  Is a transparent proxy?  Is there any sort of captive portal setup where you have to auth or agree to something before you get access using the proxy?
                                    • V Offline
                                      vdecristofaro
                                      @podilarius:
                                      @stephenw10:
                                      Yes I have removed the configuration. But I am just trying to get to the internet from the pfsense shell…
                                      @johnpoz:
                                      echo $HTTP_PROXY
                                      @johnpoz:
                                      There is an internal DNS server in a Windows 2008 VM which is running at 192.168.83.11 and which serves the clients of the virtual network 192.168.83.0.
                                      On this server I also have configured to forward queries to 192.168.83.1 (the pfSense router). As you can see from the previous screenshot, the pfSense router has DNS of my host network in resolve.conf.
                                      I dont really know how to verify if there are any limitations.
                                      The proxy it is a Squid 2.7v9 with Basic Authentication. On our client pc's we can configure it directly using the sintax I've used above or even with a wpad autoconfiguration script which provides load balancing. It does'nt make any difference for the clients.
                                      It is not a transparent proxy. We dont have wccp.
                                        So from that http_proxy output fetch would be using that proxy to resolve dns would it not?  When using a proxy, normally proxy does the dns lookup.  Looks like your putting username and password in the proxy url.
                                        Does your proxy allow that? Have you tried this method with fetch
                                        HTTP_PROXY=http://proxy.example.com:8080
                                          HTTP_PROXY_AUTH=basic:*:<user>: <pwd>You sure pfsense is even resolving the fqdn you have in there for your proxy?  If its an internal fqdn, why are you hiding it?</pwd></user>
                                        • V Offline
                                          vdecristofaro
                                          @johnpoz:
                                          Right! I was almost sure but unfortunately I have just verified that the pfsense VM does not resolve the name of the proxy server.
                                          This is just very strange because the wan configuration is exactly the same as my host machine (!!!).
                                          I did change the HTTP_PROXY environment variable to use the IP address instead of the name and now "fetch" works :)
                                          @johnpoz:
                                            HTTP_PROXY_AUTH=basic:*:<user>:</user>
                                          Both methods works
                                          @johnpoz:
                                          pfSense was not resolving the name (that is understandable for me). I am hiding the name of the server just because of the privacy. In that name there are reference to the name of the customer I am working for and I do not wish to cause any problem to anyone…
                                          Now that I am able to browse the web from the router itself I am still unable to browse the web from internal network guests which are simply configured to have the router IP as their gateway...
                                            podilarius
                                            Well it cannot be simply pointing a server to a router an expecting it to work when there is a proxy involved. The proxy setup you did was just for pfSense to get version information and packages installed. This is not for everything else behind it. If you want to do that, you are going to have to setup pfSense with Squid to be a proxy itself, and a transparent one at that. Alternatively, you can just setup the proxy the same as everything else, even the same as pfSense, and pfsense will route traffic on port 3128 to that proxy.
                                            Hope that made since.
