    Wireless card compatibility with pfsense
    27 Posts 8 Posters 18.8k Views
      ntsux
      @doktornotor:
      Uhm, you enable DHCP server on pfSense.
      I have a feeling you're trying to be helpful, rather than condescending.
      I also have a requirement for MSSID, with each instance mapped to a unique VLAN/subnet.    Not sure pfSense can accommodate this with regard to DHCP.
      So, to simplify things, perhaps this would call for a solution where the AP itself is also a router (rather than a bridge), with its WAN NIC on the pfSense LAN subnet.  An extra hop is added, I  guess, but it's internal, so it should be negligible.  This would resolve the DHCP "issue".
      Thanks for your input.
        doktornotor Banned
        Rather depends on the AP wifi and firmware. I can imagine this would be doable with some Atheros-based box and DD-WRT.
          @ntsux:
          Why not? The usual arrangement here would be to have the access point mapping each virtual access point to a different VLAN with all the VLANs trunked to pfSense. pfSense is then configured with those VLANs such that each VAP appears to be a separate interface complete with DHCP server, firewall rules etc.
            ntsux
            @stephenw10:
            @ntsux:
            OK great - then I have some reading to do.  Not quite sure where the .1q trunks are set up in pfsense, and how they correlate to the number of sub-interfaces I will require on the physical NIC (on the pfsense box) associated with the  AP.
              wallabybob
              @ntsux:
              Nowhere as such. If you are using a particular physical interface as a "trunk", go to Interfaces -> (assign), click on the VLANs tab, click on "+" to create a VLAN you wish to add and fill in the details, click Save then click on the Interface assignments tab and click "+" to add the VLAN to the pfSense pool of interfaces. Your VLAN interface will now have an OPTx style name (OPT1, OPT2, etc) and you then go to Interfaces -> OPTx and fill in the details such as IP address etc then go to Firewall -> Rules to add rules to control traffic and then (optionally) go to Services -> DHCP Server to configure DHCP services on the VLAN.
                ntsux
                @wallabybob:
                @ntsux:
                If I am understanding you correctly, this method sounds analogous to a method for creating a sub-interface on the physical NIC in other products.  Therefore, I should create each additional "Optx" interface that I require, ensure that the MAC matches the original physical NIC, and map the isolated VLANs (and the subnets contained within each VLAN) to what I have created in my AP via the trunk.  And then create a suitable policy/rule set for each one I create.
                Having the ability to run a distinct DCHP daemon per sub-interface is an awesome option!
                Thanks very much! Can't wait to try it out!
                  Sounds like you have the idea.  Have fun! :)
