    Multi-WAN with Fallback: Incoming connection routing issue
    1 Posts 1 Posters 1.1k Views
    • O Offline
      OScoder
      Summary: Packets going out wrong WAN
      System:
      WANs
      • GW1: IP: 172.16.1.100/24, Gateway 172.16.1.1, Marked as default GW
      • GW3: IP: 172.17.1.200/24, Gateway 172.17.1.1
      LANs
      • Servers: 10.1.0.0/8
      • VoIP: 10.2.0.0/8
      Routing: Two groups implementing fallback
      • preferGW1: GW1 is Tier 1 and GW3 is Tier 2
      • preferGW3: GW3 is Tier 1 and GW1 is Tier 2
      LAN Firewall Rules
      • LAN Servers: gateway is preferGW1
      • LAN VoIP: gateway is preferGW3
      Manual Outbound NAT Rules:
      • Interface GW1: Source any, other fields *
      • Interface GW3: Source any, other fields *
      What works:
      • All connections initiated behind by LAN clients work correctly and select correct WAN port depending upon traffic source (e.g., VoIP or data or link failure fallback).
      • All inbound HTTP and SSH connections to pfSense services when GW1 IP is used.  I.E., "ssh 172.16.1.100" from an external IP.
      What fails:
      All incoming HTTP and SSH connections to pfSense services when GW3 IP is used.  I.E., "ssh 172.17.1.200" from an external IP works.
      • Packet arrives on GW3 with source IP w.x.y.z, destination IP 172.17.1.200
      • Response packet departs on GW1 with source IP 172.17.1.200, destination IP w.x.y.z.  TCPDUMP at w.x.y.z shows the packet is arriving.
      Curiously, ping requests from w.x.y.z to GW1 and GW3 work.
      I tried opening all ports at w.x.y.z and the TCP connection is still not established.
      Is it possible to force a connection that is established on say GW3 to go out on GW3 irrespective of LAN Firewall GW settings?
