    Speed Limited to about 28 Mbps?
    30 Posts 8 Posters 10.2k Views
    • K
      Klaws
      @wallabybob:
      Perhaps your pfSense is running out of puff and occasionally dropping packets forcing a TCP timeout and consequent loss of throughput.
      In that case, the traffic graph should show the "ramp pattern" - thoughput steadily increasing, then abruptly dopping down, then ramping up again…and so on.
      Does the traffic graph show a (sort of) flat 28Mbps line or does it show much variance?
      • H
        hackin8
        Thanks for the suggestion - I am still on 2.0.1 - have been waiting for 2.0.3 to be finalised before updating.
        As I am running a live production server would be reluctant to upgrade unless a real chance of resolving problem.
        Does anyone have any confirmation that changng PPPoE MTU has been "fixed" in 2.0.2?
        • stephenw10S
          I was looking at the 2.0.2 release notes.
          @http://doc.pfsense.org/index.php/2.0.2_New_Features_and_Changes:
          Properly obey MTU set on Interface page for PPP type WANs.
          • H
            hackin8
            Klaws - attached image is from speedtest.net - peaking at about 29Mbps. It did (on this run) tail off a little at the end - but this doesn't usually happen.  It is not flat-lining (indiocating a limiter / throttling) but neither is it saw-tooth (running out of resources etc).  Although the PC I am running pfS on is quite limited - I did previously try with a much more powerful PC - but the results were identical.
            Pattern is pretty much the same each time, although I find with firefox I get about 26-28 and with IE9 I get 30-32 when connected through pfS. when using same PC with PPPoE direct to vdsl modem I get 75-77 and 68-72 respectively.
            stephenw10 - thanks for that, I think I will try upgrading to 2.0.3 but first I thought I would try direct PPPoE and changing MTU from 1480 to 1492 to see if that makes any difference.
            I am still not really convinced that MTU is the problem - but it is the only thing I can think that might make a difference.
            Will report back on trials - unless any other suggestions in the meantime….
            speedtest.png_thumb
            • stephenw10S
              I have to doubt it's an mtu issue too. As I said my own fttc connection works fine with the default settings. I'm using the BT supplied Huawei HG612.
              • H
                hackin8
                StephenW10 - thanks for the comments - I also have the HG612. Default settings in 2.0.1 - no packages installed
                I believe you have 40Mbps fttc - what speed do you get from speedtest.net using that line only?
                I have 80Mbps - one thing I have noticed this evening is that manually selecting another test server on speedtest I can get up to 39-41Mbps.
                It seems that the normal auto-selected server (lowest ping is Maidenhead Xilo) cannot go faster than about 30.
                Selecting any of 5 other close servers (London) does give me a faster rate of around 40.
                Better, but still not as good as the 75-77 I can get when connecting the modem directly via PPPoE.
                I haven't been able to do any further testing this evening - will have a try tomorrow.
                • K
                  Klaws
                  You might try to run a packet capture on pfSense - I guess that if there are MTU/fragmentation issues, you should see corresponding ICMP messages.
                  Edit: I just remembered to have heard that some modems filter these ICMP packets. So absense of such ICMP messages might not automatically mean that the MTU is okay…
                  Edit 2: Wait, there might be an easier way to check the MTU. On Windows,
                    ping google.com -l 1472 -f
                  will send an ICP Echo Request with a size of 1500 bytes (1472 bytes payload plus 18 bytes ICMP/IPv4 overhead).
                  • S
                    solignis
                    I have heard of a similar problem before on other appliances, mainly the Untangle UTM appliances.
                    The problem the folks using Untangle were experiencing was related to the type of NIC they were using. The realtek nics and other "cheap" nics heavily leverage the system to do most of the calculation for network traffic. There is supposed to be some theoretical celing to the these NICs and its +/- 20mbps. Once people replace the realteks with server class NICs like Intel Pro1000 PT the problems were resolved.
                    Disclaimer The above statement is not my own words, it was an idea I read on the Untangle forums Disclaimer
                    I wonder if this type of situation could be your problem? Have you tried a decent hardware based NIC?
                    P.S. Oh yeah I probably should also mention that Untangle is based on Debian Linux and NOT FreeBSD so a problem with Untangle might now carry over to pfSense.
                    • H
                      hackin8
                      Well, I tried direct PPPoE to PC.  Changed MTU from 1480 (Win7 default) to 1492 - no difference in speed. So I guess MTU is not the issue.
                      solignis - thanks for the suggestion - that at least is another path to follow.  I had a look at the Pro1000 PT - but it is for PCI-E (which I don't have) and in any case is more than the price of my whole setup!!
                      I have three different NIC's I am using - 1 is built in (fxp = Intel etherexpress Pro?) plus two PCI NIC's detected as re (Realtek 8169) and rl (Realtek 8139) I have checked - all interfaces are running at full duplex - they appear to work fine but I could quite believe that the combination of an "underpowered" PC with a cheap NIC could create issues.
                      I have tried swapping them around - including with the fxp on the affected WAN but no combination works. (Of course with fxp on WAN I have to use one of the Realteks for the LAN - so maybe still an issue?)
                      I would like to try another NIC but frankly don't know how to determine what might be better?  For example would the Intel Pro100S be any better than the cheap ones I have? Any other suggestion for a suitable PCI card that I could pick up a cheap used one on Ebay?
                      Thanks again for the suggestion - at least something else to try!!
                      • stephenw10S
                        I would be suprised to see the Realtek nics limiting to this extent. I have seen very low quality nics limit connection speed to, say, 80Mbps where an Intel card will get 95Mbps+.
                        To rule this out use your fxp nic as WAN and test the download directly to the pfSense box as you did earlier.
