    Another Huawei E353 problem … usb_modeswitch not finding device
    4 Posts 2 Posters 2.8k Views
      hvr
      I have been struggeling with this all day and would really appreciate if someone could help me out here …
      First command below shows that VID=0x12d1 and PID=0x14fe, but then usb_modeswitch does not find those ID's and quits with "Nothing to do"
      I don't see any /dev/cu* devices ...
      [2.0.2-RELEASE][admin@pfsense.localdomain]/root/usb_switch(31): usbconfig -d 1.2 dump_device_desc
      ugen1.2: <huawei mobile="" huawei="">at usbus1, cfg=0 md=HOST spd=HIGH (480Mbps) pwr=ON
      bLength = 0x0012
        bDescriptorType = 0x0001
        bcdUSB = 0x0200
        bDeviceClass = 0x0000
        bDeviceSubClass = 0x0000
        bDeviceProtocol = 0x0000
        bMaxPacketSize0 = 0x0040
        idVendor = 0x12d1
        idProduct = 0x14fe
        bcdDevice = 0x0102
        iManufacturer = 0x0002  <huawei>iProduct = 0x0001  <huawei mobile="">iSerialNumber = 0x0000  <no string="">bNumConfigurations = 0x0001
      [2.0.2-RELEASE][admin@pfsense.localdomain]/root/usb_switch(49): usb_modeswitch -c e353.txt -W
      • usb_modeswitch: handle USB devices with multiple modes
      • Version 1.2.1 (C) Josua Dietze 2011
      • Based on libusb0 (0.1.12 and above)
      ! PLEASE REPORT NEW CONFIGURATIONS !
      DefaultVendor=  0x12d1
      DefaultProduct= 0x14fe
      TargetVendor=  0x12d1
      TargetProduct=  0x1506
      TargetClass=    not set
      TargetProductList=""
      DetachStorageOnly=0
      HuaweiMode=0
      SierraMode=0
      SonyMode=0
      QisdaMode=0
      GCTMode=0
      KobilMode=0
      SequansMode=0
      MobileActionMode=0
      CiscoMode=0
      MessageEndpoint=  not set
      MessageContent="55534243123456780000000000000011062000000100000000000000000000"
      NeedResponse=0
      ResponseEndpoint= not set
      InquireDevice enabled (default)
      Success check disabled
      System integration mode disabled
      Looking for target devices …
      No devices in target mode or class found
      Looking for default devices ...
      No devices in default mode found. Nothing to do. Bye.</no></huawei></huawei></huawei>
        hvr
        In Windoze the two ID's are VID 0x12d1, PID 0x14fe … and ... VID 0x12d1, PID 0x1506
        ... am I correct in assuming that this modem should then work fine in pfSense, since other people have reported success for VID 0x12d1, PID 0x1506 modems ... pr is it not that simple? Would two modems with the same VID, PID use the exact same driver or are there other factors?
        If it is already switched to the correct mode, why is it not showing a /dev/cu.. device?  Please help.
          wallabybob
          You might get a better result if you try using a snapshot build of pfSense 2.1 which has more up to date device drivers than pfSense 2.0.x. (pfSense 2.0.x is based on FreeBSD 8.1. pfSense 2.1 is based on FreeBSD 8.3.)
            hvr
            Thanks wallabybob!
            I now have the following under /dev
            [2.1-BETA1][admin@pfsense.localdomain]/root(6): ls /dev/cu*
            /dev/cuaU0      /dev/cuaU0.lock /dev/cuaU1.init /dev/cuaU2      /dev/cuaU2.lock
            /dev/cuaU0.init /dev/cuaU1      /dev/cuaU1.lock /dev/cuaU2.init
            … and have setup PPP interfaces, which actually go as far as to show me dBm and signal % values ... but under status>system logs the following is showing ...
            ppp: [opt1_link0] CHAT: +CGDCONT=1,"IP","internet"
            ppp: [opt1_link0] CHAT: Detected Hayes compatible modem.
            ppp: [opt1_link0] CHAT: The modem responded with "ERROR" to the command "AT&F&C1&D2E0S0=0M1" at ModemCmd: label.
            ppp: [opt1_link0] MODEM: chat script failed
            ppp: [opt1_link0] Link: DOWN event
            ppp: [opt1_link0] LCP: Down event
            … also ...
            [2.1-BETA1][admin@pfsense.localdomain]/root(8): usbconfig -d 1.2 dump_device_desc show_ifdrv
            ugen1.2.0: umodem0: <huawei 0="" 2="" huawei="" mobile,="" class="" 0,="" rev="" 2.00="" 1.02,="" addr="">ugen1.2.1: umodem1: <huawei 0="" 2="" huawei="" mobile,="" class="" 0,="" rev="" 2.00="" 1.02,="" addr="">ugen1.2.2: umodem2: <huawei 0="" 2="" huawei="" mobile,="" class="" 0,="" rev="" 2.00="" 1.02,="" addr="">ugen1.2.3: umass0: <huawei 0="" 2="" huawei="" mobile,="" class="" 0,="" rev="" 2.00="" 1.02,="" addr="">ugen1.2.4: umass1: <huawei 0="" 2="" huawei="" mobile,="" class="" 0,="" rev="" 2.00="" 1.02,="" addr="">bLength = 0x0012
              bcdUSB = 0x0200
              idVendor = 0x12d1
              idProduct = 0x1c05
              bcdDevice = 0x0102
            … should umodem* not be u3g* in the above?
            Thanks again for the help, it at least feels like I'm getting somewhere.</no></huawei></huawei></huawei></huawei></huawei></huawei></huawei></huawei>
