    Syslog remote logging problem after reboot
    25 Posts 7 Posters 8.5k Views
      athurdent
      Oh, sorry! I meant to say, the change worked for my setup (ALIX Board), it fixes the problem. And thanks for looking into this!
      • jimpJ Offline
        OK, I took the if statement out and updated the comment. Should be in later snapshots.
        Do not Chat/PM for help!
          abrooks
          I've got the same problem with 2.0.3, presumably I could try the same fix?  Thanks, Adrian
          • jimpJ Offline
            @abrooks:
            Yes if the same test/code is there on 2.0.x then the same fix should work.
              abrooks
              Thanks - I'll give it a try in a couple of days and let you know.  Adrian.
