Traffic Graph for LAN and WAN showing outside IP Addresses
HI Phil,
As you can see from the attached, the bandwidth indicators are correct for ALL WAN and LOCAL LAN, but when ALL LAN is selected and LOCAL WAN, the bandwidth usage indicators are reversed and are not in sync with the graph.
Gifs attached, Just ignore me if I'm getting too "German" about the way things are displayed.
Thanks, Jits.
@jits - I work with a few Germans, so I have learnt to cope with their OCD ways ;) In the programming business OCD is good.
I think this pull request will fix up the In/Out confusion - https://github.com/bsdperimeter/pfsense/pull/477
The table is actually showing BW from and to each IP address listed. The meaning of In/Out flips depending on which side of the interface the IP is. So From/To are better column labels. -
Just updated today, I did wonder why all the external ip addresses and hostnames are showing up now, very strange.
I do like that we can select hostnames though.
Is a fix coming?
thanks
The fix is already comitted, but there hasn't been a snapshot build for a few days now. In the meantime, while we wait for the snapshot builds to resume, you can use gitsync to get it.
after the march 1st snaps im not able to see any ip address in list
![CropperCapture[1].jpg](/public/_imported_attachments_/1/CropperCapture%5B1%5D.jpg)
I just upgraded to 2.1-BETA1 (i386) built on Mon Mar 11 08:59:46 EDT 2013 and it seems fine for me. The "rate" utility that generates the bandwidth by IP data just does a quick sample of the traffic. When the bandwidth is very low, it is quite easy for the short sample to not get much of a decent "average", or to see nothing much at all. Start something downloading for real and you should see it clearly.
i tried on another machine same latest snap and that one shows so how can one machine show the ips and the other not, what could be wrong?
It works in the newest updated. But it isn't as simple to use as before.
I wish it would default to the previous configuration, and if you want to see external IPs then select that.
Listing a bzillion external IPs/hostnames coming and going isn't that visually helpful as it changes so fast.
I believe ermal is going to work on the In/Out sides of the display, so that the numbers for both local and remote IPs will match the In/Out convention of the graph.
The default for the table could easily be changed to "Filter: Local" - maybe people could give votes here for what they would prefer as the defaults? or a "Save" button could be put on the page that would save the current settings to the config and it would load those when it starts (more effort for that)? -
the table that shows in/out the ips just come and go too fast and if ur specifically monitoring a few local ips then they keep jumping up and down so y not simply keep the ip list static, meaning as soon as there is traffic from some ip, list it permanently and then just keep refreshing its in/out packets and suppose this ip stop communication for like 30 seconds then remove it from list
Does it make sense that external IPs/host names are displayed, especially when LAN interface is selected?
This same issue is present in PRERELEASE builds of 2.0.3 (see http://forum.pfsense.org/index.php/topic,58203.msg324782.html#msg324782). I note a few commits have been made to the master branch in response to this issue, although I'm not quite able to follow what is what. If any of these commits fix the original issue, can they be backported to RELENG_2_0 before 2.0.3 gets released?
I fixed so it accounts properly for the local subnet without showing the not local ips.
The "rate" utility is now back to the old behaviour, only showing local/internal IP addresses and is good for releasing 2.0.3. Whatever happens next, we need to be careful not to mess up the 2.0.n behaviour.
With no remote addresses returned by "rate", the "Filter: All/Local/Remote" box on the GUI is no longer useful/relevant.
I actually liked being able to see the external IP addresses. Combined with the option to display the FQDN (of IPs that have a reverse-lookup available) it often meant that I could quickly see what site a big BW user is downloading from. Of course it doesn't always work - if the IP has no reverse lookup then you have to do some work yourself on the raw IP if you want to get an idea what it is. The "Filter" option lets you suppress this output if you wish.
It would be easy enough to make "rate" take an extra parameter to make it spit out external IPs also. Then that could be invoked from the 2.1 code and not break the 2.0.n behaviour.
What do others think? Do you think having the external IP display option is useful? -
Why not let the user choose his preferred display mode by remembering the last chosen selection and using it by default until a different one is chosen.
That requires a config write, which would not be ideal to do every time the user changes one of the dropdown selections. Adding a "Save Settings" button is probably the way to go.
Agreed…
