    WG x750e - automatic speed adjustment: mbmon going crazy
    53 Posts 4 Posters 14.0k Views
      Ok, but was your script using mbmon or WGXepc to read the temperature? The difference between them is that mbmon reads reads a whole load of values every time it's run even if you only need one. To get all those values requires setting the SuperIO chip in various modes. It's possible that under certain conditions mbmon leaves the superio chip in some error state. It may be possible to determine what the error state is and recover from it or to avoid it in the first place.
        bigramon
        My script was using only WGXepc.
        Damien
          Damn!
          Well the only thing to do then is try to find out why the SuperIO chip is no longer responding usefully. Quite how to do that though….  ::)
            sthames42
            Did you guys ever resolve this? I have exactly the same problem. Running mbmon returns reasonable temps for a while and suddenly starts reporting this:
            Temp.= 255.0,  0.0,  0.0; Rot.=    0,    0,    0
            Vcore = 4.08, 4.08; Volt. = 4.08, 6.85, 15.50,  6.07,  5.11
            When I cancel mbmon and run it again, I get:
            ioctl(smb0:open): No such file or directory
            No Hardware Monitor found!!
            InitMBInfo: Bad file descriptor
            WGXepc -t reports good temps and then nothing but 255.
            Only way to fix this is to reboot.
            I'm assuming the SuperIO chip got itself hosed somehow. Is there any way to reset or reboot the chip?
            This is on two X-Core 550e boxes and the default SL6N7 Banias chips have been replaced with SL7EP Dothan chips according to https://doc.pfsense.org/index.php/PfSense_on_Watchguard_Firebox#Further_Enhancements_3.
            All dip switches set correctly. No other changes (powerd/speedstep) were made.
              No, or at least I haven't heard from anyone who did. However reading back through the data sheet there appear to be a number of possible things we could try. Since the chip is just giving results that are registers full of all 1s we don't know if it's actually returning anything or if we're even talking to it properly. Though it would seem likely we are because under mbmon the voltage readings continue to come back as reasonable numbers.
              As a rather extreme option it looks like there is a register that can re-initialise the chip, back to it's power on defaults. However I've no way of knowing what registers are configured by the BIOS at boot so the results could be…. unpredictable.  ;)
                sthames42
                Thanks for responding, Steve. I posted a new topic because this one was old and I wasn't sure it was still active. I'm happy to stay in this one.
                This has happened on two boxes but I have another that works fine. I suppose it's possible that two of the Dothan chips I put in these boxes are creating this problem but it seem unlikely it would be two. I'm going to replace the replacement in one of them when another chip and wait for results.
                Is the data sheet you spoke of available electronically? Where can I get it?
                  Yes, it's available in many places such as here.
                  Interacting with the chip manually for test purposes is a PITA.  ::) It involves writing many individual registers to read one value. For example:
                  https://forum.pfsense.org/index.php?topic=43574.msg261279#msg261279
                  The reset register will not require so much though. It would be interesting to install superiotool to see what has stopped and what is still readable when the chip enters it's uncooperative state. We may get a clue.
                    sthames42
                    Thanks, Steve.
                    I replaced the chip and have been running and watching mbmon for an hour. No problems. I guess it's possible I had two bad chips with the same symptoms. If the problem shows up again, I'll try your idea with superiotool. Until then, I'm moving on.
                    Thanks, again.
                      Hard to see how changing the CPU could make much difference. A change in the temperature sensor perhaps?
                      How that would affect the fan control though.
                        sthames42
                        Beats the crap out of me. Been watching mbmon for 2 1/2 hours and still working great.
                        I noticed that when I took out the other chip, I had smeared on a lot of paste (Arctic Silver). I was much more conservative with the new chip.
                        Could that have anything to do with this?
                          sthames42
                          Spoke too soon. It took 3 hours but mbmon started showing this:
                          I guess I'll look into resetting the chip as you suggested.
                            Are you running bios B8? If so you can also get the temperature via ACPI on the dashboard or sysctl. Does that fail also?
                              sthames42
                              Looks like I'm running B6. Temps not available through ACPI.
                              The superio chip should be a Winbond, right? On other pictures of x550e boards, you can clearly see the Winbond logo. On this machine, the chip is covered with a Phoenix Technologies sticker. How can I determine what chip I have?
                                sthames42
                                This is what I get if I cancel mbmon and restart it:
                                [2.1.5-RELEASE]/root(50): mbmon -d -S
                                SMBus[Intel8XX(ICH/ICH2/ICH3/ICH4/ICH5/ICH6)] found, but No HWM available on it!!
                                InitMBInfo: Device not configured
                                  They all have the Phoenix sticker on the Winbond chip, nothing unusual there. Superiotool will identify the chip.
                                    sthames42
                                    Ok, here's the superiotool dump before the problem:
                                    superiotool r4.0-2827-g1a00cf0
                                    Found Winbond W83627HF/F/HG/G (id=0x52, rev=0x41) at 0x2e
                                    Register dump:
                                    idx 02 20 21 22 23 24 25 26  28 29 2a 2b 2c 2e 2f
                                    val ff 52 41 ff fe c0 00 00  00 00 fc c4 ff 00 ff
                                    def 00 52 NA ff 00 MM 00 00  00 00 7c c0 00 00 00
                                    LDN 0x00 (Floppy)
                                    idx 30 60 61 70 74 f0 f1 f2  f4 f5
                                    val 00 00 00 00 04 0e 00 ff  00 00
                                    def 01 03 f0 06 02 0e 00 ff  00 00
                                    LDN 0x01 (Parallel port)
                                    val 01 03 78 07 04 38
                                    def 01 03 78 07 04 3f
                                    LDN 0x02 (COM1)
                                    idx 30 60 61 70 f0
                                    val 01 03 f8 04 00
                                    def 01 03 f8 04 00
                                    LDN 0x03 (COM2)
                                    idx 30 60 61 70 f0 f1
                                    val 01 02 f8 03 00 00
                                    def 01 02 f8 03 00 00
                                    LDN 0x05 (Keyboard)
                                    idx 30 60 61 62 63 70 72 f0
                                    val 01 00 60 00 64 01 00 80
                                    def 01 00 60 00 64 01 0c 80
                                    LDN 0x06 (Consumer IR)
                                    idx 30 60 61 70
                                    val 00 00 00 00
                                    def 00 00 00 00
                                    LDN 0x07 (Game port, MIDI port, GPIO 1)
                                    idx 30 60 61 62 63 70 f0 f1  f2
                                    val 01 00 00 00 00 00 00 00  00
                                    def 00 02 01 03 30 09 ff 00  00
                                    LDN 0x08 (GPIO 2, watchdog timer)
                                    idx 30 f0 f1 f2 f3 f5 f6 f6  f7
                                    val 00 ff ff ff 00 00 00 00  00
                                    def 00 ff 00 00 00 00 00 00  00
                                    LDN 0x09 (GPIO 3)
                                    idx 30 f0 f1 f2 f3
                                    val 00 ff ff ff 00
                                    def 00 ff 00 00 00
                                    LDN 0x0a (ACPI)
                                    idx 30 70 e0 e1 e2 e3 e4 e5  e6 e7 f0 f1 f3 f4 f6 f7  f9 fe ff
                                    val 00 00 00 00 14 00 00 00  00 00 00 af 32 00 00 00  00 00 00
                                    def 00 00 00 00 NA NA 00 00  00 00 00 00 00 00 00 00  00 00 00
                                    LDN 0x0b (Hardware monitor)
                                    idx 30 60 61 70 f0
                                    val 01 02 90 00 00
                                    def 00 00 00 00 00
                                    After mbmon starts failing as obove, there is only one difference in the dump. A single byte in the hardware monitor:
                                    idx 30 60 61 70 f0
                                    val 01 02 0b 00 00
                                    def 00 00 00 00 00
                                    Steve, how would you go about doing the reset you were talking about?
                                    EDIT: I assume the reset you mentioned was the initialization bit in the configuration register at 40h. I tried writing to this register with your readio/writeio tools but still got nothing back but FF. In fact, all reads are returning FF. Except for the results of the superiotool dump, I would think the chip had simply shut down.
                                    I can live without the temperature if I must. But I have no ability to change the fan speed now. I had it set up to automatically adjust the fan speed based on the CPU temp. Now I can neither determine the temp nor adjust the fans. The only way to fix this appears to be to reboot which is not acceptable.
                                    Would enabling speedstep or powerd make any difference?
                                      sthames42
                                      EUREKA!
                                      Steve, you're gonna love this!
                                      After learning what the output from superiotool actually meant and reviewing the Winbond data sheet, I realized the only change in the two dumps was the hardware monitor base address changed from 0290h to 020Bh. I wrote a little script using your readio/writeio tools to reset the base address. I never expected this to work but lo' and behold it did! Everything started working again.
                                      I guess I should modify WGXepc to check for and correct this but I don't have a FreeBSD platform to do it on. Maybe I'll try and do it on one of my Fireboxes.
                                        Nice work. That seems odd though. I'll have to read the data sheet myself unless you can enlighten me. How was anything able to be read if the base address had changed? Only the extended registers changed? Why did it change?  :-
                                        Like you say it should be relatively easy to check that and set it back.  :)
                                        Hmm, just wondering if the base address changed due to some other piece of hardware requiring access to that address space. I didn't think it could change except at boot on the ISA bus but really I don't know. Perhaps even our own script is trying to access the space twice causing the shift.
                                        It might be better to read the base address and just use it rather than trying to change it back.
                                          sthames42
                                          Nothing was able to read from the hardware monitor but everything else seems to have been okay. I've been doing some thinking about that and looking at the WGXepc code.
                                          As I said, the only difference in the registers was device 0x0b (Hardware Monitor) register 0x61 changed from 0x90 to 0x0b. I run a daemon that uses WGXepc to continually check the temp and adjust the fan speed accordingly. The basic script came from https://forum.pfsense.org/index.php?topic=66129.msg360358#msg360358. bigramon was doing the same thing which started this topic.
                                          I'm working on the theory that WGXepc is writing 0x0b to the 0x61 register for device 0x0b. I can see how this could happen if port_out(EFDR, 0x0b) was done after a call to get_w83627_addr_port() but it does not look like that is whats happening.
                                          Any thoughts?
                                            sthames42
                                            I decided I didn't want to modify WGXepc. It's not my code and I really don't know where any repository for it is. I believe this problem is caused by a bug in it, though. There is one issue I saw: get_w83627_addr_port() leaves the chip in Extended Function mode. The result of subsequent port I/O might be unpredictable at times.
                                            What I did instead, Steve, was to modify my daemon script to check for a temp of 255 and then use your writeio tool to reset the base address for the hardware monitor. Not the most elegant solution but it works reliably, so far.
                                            For anyone interested in this solution, here is the relevant section of the script:
                                               cpu_temp=`/usr/local/bin/WGXepc -t | sed '1,2d'`
                                               # Temperature of 255 means Winbond chip hardware monitor base address
                                               # has been hosed. Use writeio to reset the address. This has only been
                                               # tested on the X550e.
                                               if [ $cpu_temp -ge 255 ]
                                               then
                                                /usr/local/bin/writeio 0x2e 0x87 > /dev/null # Put Winbond into
                                                /usr/local/bin/writeio 0x2e 0x87 > /dev/null #   Extended Function mode.
                                                /usr/local/bin/writeio 0x2e 0x07 > /dev/null # Set logical device number
                                                /usr/local/bin/writeio 0x2f 0x0b > /dev/null #   to Hardware Monitor.
                                                /usr/local/bin/writeio 0x2e 0x60 > /dev/null # Reset
                                                /usr/local/bin/writeio 0x2f 0x02 > /dev/null #   monitor base
                                                /usr/local/bin/writeio 0x2e 0x61 > /dev/null #   address to
                                                /usr/local/bin/writeio 0x2f 0x90 > /dev/null #   0290h.
                                                /usr/local/bin/writeio 0x2e 0xaa > /dev/null # Exit Extended Function mode.
                                                continue
                                              fi
                                            The writeio tool you can get from Steve's google site. There is a link to it earlier in this topic.
                                            Thanks again for your help, Steve.
