How to assign Virtual IP for outbound to LAN Device?
Hello,
My ISP provides me a /29 for main IP address of my WAN and they also forward me a block of /27 IPs which I use as Virtual IPs in pfsense. My LAN devices are set to 192.168.0.0/24 and Virtual IPs are port forward for inbound to device behind LAN and it work beautifully.
***However, when a LAN device is browsing the internet it shows it's source IP as my main pfSense router IP which is the one from block of /29. How can I get them to use and show themselves as one of the IPs from block of /27 IPs?
My LAN devices are all on Proxmox.
You should be able to do that using outbound NAT rules.
http://doc.pfsense.org/index.php/Outbound_NATSteve
Thanks for the input.
I am very afraid to touch that as I may loose my VPN connection or loose my remote access to the router. Right now it's set to Automatic outbound.
Is there any way that I can do this? maybe by assigning the public IP directly to interface of device? or some other way which doesn't involve scarring the heck out of me? I have got my OpenVPN access blocked right when I enabled manual NAT last time.P.S. Where are the automatic outbound rules set? I don't see a specific location for those.
Do you have the pfSense book? If so, see section 6.7.
It's pointing to outbound NAT. Let's say I want to do it, what preparations should I take before to not block my access? What are some things that can break right when I turn on Outbound NAT? and what are some things that I should look for to do manually in future if Outbound NAT is enabled.
Thanks,
When you first switch outbound NAT from automatic to manual the existing auto-generated rules are filled into the table. Thus the NAT functionality should not change at all until you change the rule set.
Since NAT only deals with internal address if you have access to the box via the WAN you should be safe enough. That's directly on the WAN not via a VPN which is probably NATed.
With outbound NAT set to manual you have to remember to add rules yourself if you add any further interfaces and to modify the existing rule if you make major changes to an interface.Ultimately if you don't have physical access to the box you could end up locked out. ;)
Stenphen, thanks for the input.
Can you please clarify the following:
1- Where I can check the current automatic rules set by pfSense so I get a better feel of it? Are these just the rules that are visible to me like the greyed-out anti-lock rules, and LAN lockout rule?
2- What interface outbound NAT rules do I need to set when I add another interface (when I am set to Manual Outbound NAT)?With outbound NAT set to manual you have to remember to add rules yourself if you add any further interfaces and to modify the existing rule if you make major changes to an interface.
If you select manual NAT the current rules are filled into the table. You don't need to apply the changes so nothing should happen. You can then set it back to auto and save/apply and the rules will remain in the table for you to look at. This should result in no change to your box but there's always a risk.
See attached screenshot for rules on my test box, very simple WAN and LAN setup.
If I added another interface, OPT1, I would have to add equivqlent rules in order for the box to NAT between that new interface and WAN.
Stephen, thanks again.
1- So, you see these rules as your NAT is set to Automatic? Mine doesn't have any. Can I keep Automatic ON and still add rules there and expect them to work? or once Manual is turned on then the list of rules take effect?
2- Since my Router doesn't have any rules in list and is set to Automatic if I set it quickly to Manual should I expect it to not work as it does to the outside world now? If so, is there a way I can reset the Automatic Outbound NAT rules so that I have a fail-safe strategy to fall back to?
When you switch to manual the table is automatically filled with whatever rules are currently being used by the auto script. If you change back to auto the rules remain in the table but won't do anything unless you go back to manual.
Since the rules are created from the existing auto-rules there should be no difference to the operation of the box changing to manual. However, as I said, there is always s risk. ;)Steve
Suggestion to Devs: I think a better option for both features would be to then keep everything Automatic unless a Manual rule is defined. In that case, there is no need for two modes and worrying about the risk of switching.
IMHO I prefer Manual outbound NAT in all cases because if you make a rule for everything that is passing out through WAN (and its easy) then you know for sure its all working and you can make little tweaks to them individually according to their purpose. Automatic outbound feels nice and safe, but now I wouldn't want anything other than manual.
Again… Its really not hard.
All it is a a simple statement of each subnet you want to be able to pass to the internet and you can omit any you don't want to have internet access.
That list is probably the loop-back address, each LAN and VPN subnet and thats all. -
I'm pretty sure you want to Make a pretty normal looking outbound NAT rule and then Stipulate the source as your LAN and then translation as one of your virtual IPs you have set up from your /27. (Move those rules to the top)
Anyone?
Exactly. Put in rules above the whole LAN subnet rule that catch traffic from specific internal IPs and translate it to specific external IPs.
It should be quite easy but I completely understand why Torotob is nervous if he doesn't have physical access to the box.Steve
I only administer 1 locally and the rest are all flung to the 4 corners. Literally.
I do not experiment with package loading and unloading like crazy on those and I only run release versions.But, I do update users, rules etc. Haven't had a lockout in years. Not one.
If you use the KISS approach with pfsense, its very very reliable.
But yeah - Locked out of a box on another continent would suck.
I assume that he has SSH enabled for access on the WAN? I really don't think he will break his box so bad even SSH can't get him a pfsense menu?
Not with a button press to switch to manual outbound NAT? -
I wish there was a roll-back (e.g. press the reset button on Alix to reset back the config to last 10 minutes for example) - then one could kiss good by to lockouts.
So, it seems that Manual outbound gives more control so why not MERGE automatic and manual together in future versions and allow the user to change rules when it's needed. So, what I am purposing is that DO CREATE an automatic rule every time but then allow the user to modify that without switch between Automatic and Manual. Just name it as OUTBOUND RULES.
Cheers
If only it were that simple… though if you have console access to the alix, on 2.1 there is an option to restore an older config on the shell/console menu. It gives you a list and offers choices to restore.
Already planned for 2.2: http://redmine.pfsense.org/issues/2416
It can't merge exactly as you say since that would be impossible to accurately track. If you changed your LAN subnet, or added an interface, the rules would need to change and it would need to know which were yours and which were automatic. The ticket above has a good compromise in functionality.
Thanks Jim. Has Alix reset button feature ever been considered or tested to work on pfSense? I wonder if something can be hacked together as a script to trigger a reload and restart of pfsense from a stored config template file.
At a quick look, if you copy some config.xml to /etc/conf.default/config.xml (overwriting the default one) and press the reset button, it should do exactly what you want. (Obviously make a backup before testing :P)
The reset button is only probed during boot. If you press and hold the reset button while it's booting, it will reset to factory defaults.
As doktornotor mentioned you can hijack that to replace the default config with your own, but then you could never actually do a true factory reset again (until you do a firmware upgrade and that default config goes back to a stock version)
