    Problem whit Huawei E176 and E160 3G Modems
    1 Posts 1 Posters 1.3k Views
      tixe
      Hi .. i have a little problem with Huawei 3G Modems.
      one E176 and E160, the problem is the same.
      The plataform are a pfSense 2.0.3 on a Soekris Board NET6501
      I put some code to can see
      Jul 5 13:42:15 ppp: [opt2_link0] Link: reconnection attempt 1 in 4 seconds
      Jul 5 13:42:15 ppp: [opt2_link0] LCP: Down event
      Jul 5 13:42:15 ppp: [opt2_link0] Link: DOWN event
      Jul 5 13:42:15 ppp: [opt2_link0] MODEM: chat script failed
      Jul 5 13:42:15 ppp: [opt2_link0] CHAT: The remote modem did not answer.
      Jul 5 13:42:15 ppp: [opt2_link0] CHAT: Dialing server at *99#…
      Jul 5 13:42:15 ppp: [opt2_link0] CHAT: Detected Hayes compatible modem.
      Jul 5 13:42:15 ppp: [opt2_link0] LCP: LayerStart
      Jul 5 13:42:15 ppp: [opt2_link0] LCP: state change Initial –> Starting
      Jul 5 13:42:15 ppp: [opt2_link0] LCP: Open event
      Jul 5 13:42:15 ppp: [opt2_link0] Link: OPEN event
      Jul 5 13:42:15 ppp: [opt2] Bundle: Interface ng0 created
      Jul 5 13:42:15 ppp: web: web is not running
      Jul 5 13:42:15 ppp: process 39143 started, version 5.6 (root@snapshots-8_1-i386.builders.pfsense.org 08:23 7-Mar-2013)
      Jul 5 13:42:15 ppp:
      Jul 5 13:42:15 ppp: Multi-link PPP daemon for FreeBSD
      These message is a same with both modems !!! … but the E160 i see that is on the Hardware compatibility list, whe i go to Interfaces PPP Edit i see /dev/cuaU0.0 and /dev/cuaU0.1, i choose one or other and the message are the same, what im doing wrong
      The the mdp_x.conf are to next
      startup:
      configure the console
      set console close
      configure the web server
      set web close
      default:
      pppclient:
      create bundle static opt2
      set iface name ppp0
      set iface disable on-demand
      set iface idle 0
      set iface disable tcpmssfix
      set iface up-script /usr/local/sbin/ppp-linkup
      set iface down-script /usr/local/sbin/ppp-linkdown
      set ipcp ranges 0.0.0.0/0 10.64.64.0/0
      set ipcp no vjcomp
      #log -bund -ccp -chat -iface -ipcp -lcp -link
      create link static opt2_link0 modem
      set link action bundle opt2
      set link disable multilink
      set link keep-alive 10 60
      set link max-redial 0
      set link no acfcomp
      set link no protocomp
      set link disable chap pap
      set link accept chap pap eap
      set link disable incoming
      set link mtu 1492
      set auth authname "clarogprs"
      set auth password clarogprs999
      set modem device /dev/cuaU0.1
      set modem script DialPeer
      set modem idle-script Ringback
      set modem watch -cd
      set modem var $DialPrefix "DT"
      set modem var $Telephone "*99#"
      set modem var $APN "igprs.claro.com.ar"
      set modem var $APNum "1"
      open
      Some one can help me ?
      Thanks in advances and regards !!!
      By Tixe
      Sorry for my English, Im not an English speaker.
