    Dual WAN with Failover Not Working
    34 Posts 4 Posters 17.8k Views
      kejianshi
      Nothing works better for fail-over than two of the same ISP…
        kathampy
        @kejianshi:
        …from the same modem.
          rober1sf
          :( Ok. I understand that one doesn't want dual WAN from the same ISP/modem in a production environment but I have to TEST this in a lab environment before I can put it in a production setting where it doesn't work! This "unnecessarily complicated" network as you say is essentially the exact same setup as having 2 modems from 2 ISPs.
          Why does the pfSense NOT fail over to WAN2 when the Internet traffic on WAN1 goes out? And for proof of concept, I used a Cisco RV042 in the same "unnecessarily complicated" network and the Cisco worked.
          I think there is a software flaw with pfSense and the dual WAN failover. You guys using it say it works, but are you dropping physical link for it to fail, because that does work. Dropping Internet packets does not work though!!!!!
          I'm begging for help from you guys, so please help if you can; I don't need the sarcasm or rude comments.
            kejianshi
            So, you are saying failover from packet loss doesn't work?
            How are you simulating packetloss?
              kathampy
              Failover pased on a packet loss threshold does work. It works by default.
                kejianshi
                If failover isn't working based on simulation of packet loss then:
                Either its broken or
                The settings are wrong or
                Packet loss is not being done effectively to cause a failover.
                Thats why I'm asking how are the packets being dropped.
                  rober1sf
                  On router 1 in my diagram above, I have an outbound firewall rule that blocks all outbound Internet traffic, thus creating Internet packet loss on WAN 1. I know the packet loss is happening too because the pfSense diag ping tool will have 100% loss, but gateway status will still show it pinging.
                  In a "real" production setting, I would test this by removing the coax cable from the cable modem because simply unplugging the power to the modem would be link state down, which doesn't happen when the Internet goes down.
                    kejianshi
                    Are you sure those packets you are blocking are being dropped silently and not rejected with a reply?
                    REJECT
                        Prohibit a packet from passing. Send an ICMP destination-unreachable back to the source host [unless the icmp would not normally be permitted, eg. if it is to/from the broadcast address].
                    DROP (aka DENY, BLACKHOLE)
                        Prohibit a packet from passing. Send no response.
                      rober1sf
                      When I ping from the workstation behind the pfSense I get response timed out, 100% loss. I believe that is correct, right?
                        kejianshi
                        Do you own a server on the net anywhere?
                        What I would do is maybe set up a couple Centos boxes with public IP you can ping.
                        Use those IPs as your monitor IPs.
                        If you shut down the Centos box (no blocking anything), then that will be for sure packet loss.
                        You and a buddy could set up one at your home and one at his if you want to have control over two "gateway" IPs to use.
                        I know this sounds like unnecessary work, and it may be, but at least you will know its not your method of inducing packet loss that is flawed.
                        I suppose you could do the same thing entirely in lab environment with no outside internet.
                        I don't know if pfsense would know the difference in a packet dropped silently, rejected, or an unreachable offline server. It might.
                        Since you didn't tell me if you are dropping packets silently, I assume you aren't sure.
                          rober1sf
                          @kejianshi:
                          I'm doing a DENY rule in the firewall. I don't think that I need to switch to pinging 2 of my own servers on the Internet (unless you are thinking about something that I'm not) because this setup works in the exact same setup with the Cisco RV042, and the RV042 fails over.
                          ![Router 1 Firewall Rule.JPG](/public/imported_attachments/1/Router 1 Firewall Rule.JPG)
                          ![Router 1 Firewall Rule.JPG_thumb](/public/imported_attachments/1/Router 1 Firewall Rule.JPG_thumb)
                            kejianshi
                            When it works for others, but not for you, I'd suggest changing your methods or recheck your settings.  That would be a pretty big bug if it really doesn't work.
                              rober1sf
                              Ok, so I added a laptop on the same LAN as Router 1 (see attached Visio) and changed my monitor IP on WAN1 to that latptop's IP address. Physically unplugging the cable from the laptop keeps the physical link on WAN1 but allowed for packet loss and a failover to WAN2. Reconnecting the cable to the laptop allowed the pings to begin again and the connection to WAN1 was then automatically restore as well.
                              WORKED like it should! Still confused by the Cisco RV042 worked with the other setup, but all I can say is that maybe the pfSense "sees" the pings differently from the Router 1 firewall block rule than the Cisco??
                              At any rate, ready to try in a REAL production environment (see attached Visio for the "UNCOMPLICATED" network you all were looking for ;D ).
                              Thanks to all for helping. If anyone stumbles across this and needs help, I've also created a step-by-step setup from initial boot/configuration to setup a Dual WAN with Failover… just PM me for a copy.
                              Thanks again!!
                              ![Dual WAN Test 2.jpg](/public/imported_attachments/1/Dual WAN Test 2.jpg)
                              ![Dual WAN Test 2.jpg_thumb](/public/imported_attachments/1/Dual WAN Test 2.jpg_thumb)
                              ![Production Dual WAN.jpg](/public/imported_attachments/1/Production Dual WAN.jpg)
                              ![Production Dual WAN.jpg_thumb](/public/imported_attachments/1/Production Dual WAN.jpg_thumb)
                                kejianshi
                                Yeah - I wasn't trying to waste your time.  I'm glad its working now.
                                I hope your actual install goes well also.
